Arduino:1.8.8 (Windows 10), Kort"ATmega328 on a breadboard (8 MHz internal clock)"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): unknown response=0x12
Feil oppstod under skriving av oppstartslaster.
option enabled in File -> Preferences.
I have checked the wiring, testet the cables, tried another Atmega328-AU chip, and tried to use another Arduino as the programmer.
This is how I connected the Arduion Nano to the new Atmega328-AU chips:
it is nice to have decoupling capacitors .1uF, close to power pins,
the reset circuit must be, at least pull-up resistor cca 10k,
AREF via 0.1uF cap. to the GND.
Thanks!
All VCCs and GND pins are connected (just not shown in the picture above).
I have tried with the 10K resistor, but that didtn work either, so I will try using the capacitors aswell.
Can the capacitors be > than 0.1uF? I have 0.1uF capacitors on order, and some 22nF capacitors laying around.
Budvar10:
I read again and, if you use Nano as programmer with Arduino v1.8.8, you have to connect cca 10uf capacitor between RESET and GND pins on Nano.
I just tried to add the following:
On the prgogrammer (Arduino Nano):
A 10K resistor between RESET and GND
On the new Atmega328-AU target chip:
A 0.1uF capacitor between AREF and GND
A 10K resistor between RESET and VCC
A 10uF capacitor between VCC and GND
(All SMD components 0603/0805)
I still get the same error message. All connections are double checked.
Measuring 4.6v at the target Atmega328-AU VCC pins.
I also tried to unconnect all wires to the Atmega328-AU chip... still get the exact same error code.
As an alternative, can I solder the new Atmega328-AU chip to another Arduino Nano (switch the cips) and burn the bootloader that way (burning a 8MHz bootloader to the chip with the 16MHZ crystal and all that still on the board)?
HansiFansi:
You can do that. It's fine to run off the internal oscillator even with an external crystal connected.
Wrong. It should be 10uF capacitor. We need to disable the the reset during bootloading by keeping the RESET high on the programmer. See the reply #4 again.
Budvar10:
My mistake. I will try to change this and try again. Thanks!
