Error when I add two codes in void setup ()
So am writing a code for a Bluetooth car
And I want the back light to be on on startup
So I have this in the
void setup ()
Here the it is the braud rate of the Bluetooth module and the car works fine with the rest of the code (not mentioned) it goes forward, backward, etc
But when I do this to have the led on
void setup ()
digitalWrite (backlight, HIGH);
The rest of the code (not mentioned) does not work and the car does not go forward, backward, etc but the backlight turns on
Please help me resolve this
All you have done there is enabled the pull up resistor.
Please post your full sketch
Could you be more specific
Like what should I do to resolve it
How can I be more specific?
You enabled the pull up resistor on the pin "backlight".
I don't know if that's what you intended, and I don't know what "backlight" is.
ok so here is the full sketch
Note:- in this i am routing the backlight negative pole through arduino as it is of 12 volt so it is high that is positive and low that is negative
#include <AFMotor.h>
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
int val;
int Speeed = 255;
int frontight = 11;
int horn = 9;
int parking = 10;
int backlight = 7;
void loop(){
  if(Serial.available() > 0){
    val = Serial.read();
    Stop(); //initialize with motors stoped
          if (val == 'F'){
          forward();
          if (val == 'B'){
          back();
          if (val == 'L'){
          left();
          if (val == 'R'){
          right();
          if (val == 'I'){
          topright();
          if (val == 'J'){
          topleft();
          if (val == 'K'){
          bottomright();
          if (val == 'M'){
          bottomleft();
          if (val == 'T'){
          Stop();
           if (val == 'W'){
          frontightson();
           if (val == 'w'){
          frontightsoff();
           if (val == 'U'){
          backightson();
           if (val == 'u'){
          backightsoff();
            if (val == 'V'){
          hornon();
           if (val == 'v'){
          hornoff();
            if (val == 'X'){
          parkingon();
           if (val == 'x'){
          parkingoff();
void forward()
  motor1.setSpeed(Speeed); //Define maximum velocity
  motor1.run(FORWARD); //rotate the motor clockwise
  motor2.setSpeed(Speeed); //Define maximum velocity
  motor2.run(FORWARD); //rotate the motor clockwise
  motor3.setSpeed(Speeed);//Define maximum velocity
  motor3.run(FORWARD); //rotate the motor clockwise
  motor4.setSpeed(Speeed);//Define maximum velocity
  motor4.run(FORWARD); //rotate the motor clockwise
void back()
  motor1.run(BACKWARD); //rotate the motor anti-clockwise
  motor2.run(BACKWARD); //rotate the motor anti-clockwise
  motor3.setSpeed(Speeed); //Define maximum velocity
  motor3.run(BACKWARD); //rotate the motor anti-clockwise
  motor4.setSpeed(Speeed); //Define maximum velocity
  motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void topleft(){
  motor3.setSpeed(Speeed/3.1);//Define maximum velocity
  motor4.setSpeed(Speeed/3.1);//Define maximum velocity
void topright()
  motor1.setSpeed(Speeed/3.1); //Define maximum velocity
  motor2.setSpeed(Speeed/3.1); //Define maximum velocity
void bottomleft()
  motor3.setSpeed(Speeed/3.1); //Define maximum velocity
  motor4.setSpeed(Speeed/3.1); //Define maximum velocity
void bottomright()
void Stop()
  motor1.setSpeed(0); //Define minimum velocity
  motor1.run(RELEASE); //stop the motor when release the button
  motor2.setSpeed(0); //Define minimum velocity
  motor2.run(RELEASE); //rotate the motor clockwise
  motor3.setSpeed(0); //Define minimum velocity
  motor3.run(RELEASE); //stop the motor when release the button
  motor4.setSpeed(0); //Define minimum velocity
  motor4.run(RELEASE); //stop the motor when release the button
void frontightson()
digitalWrite (frontight, HIGH);
digitalWrite (horn, LOW);
digitalWrite (parking, LOW);
void frontightsoff()
digitalWrite (frontight, LOW);
void hornon()
digitalWrite (horn, HIGH);
void hornoff()
void parkingon()
digitalWrite (parking, HIGH);
void parkingoff()
void backightson()
digitalWrite (backlight, LOW);
void backightsoff()
Not very clear.
Please confirm that twelve volts goes nowhere near your Arduino
What has that code got to do with backlight?
Have you ever heard of pinMode()?
No what's that
Useful for configuring pins as outputs.
The backlight is of 12 volt and I can not get 12 volt directly from Arduino so what i did is connected + ve of the backlight to the battery and routed it's negative through Arduino that is when the Arduino will give High / + ve that will turn off the led but when it is low / - ve that will turn on the led giving the current a negative path
Ok that's good but how can I use it to resolve this
Did you imagine that these are automagically outputs?
Don't put twelve volts anywhere near your Arduino's I/O pins.
ok thanks for your help but if i am connecting 5 volts then also it is not working
anyways thats not the question it is when i add two statements in void setup () the rest of the code does not work
(refer the main question for more information)
You're joking, surely?
It took until reply #6 before you even posted the code, and we've yet to see a schematic, two hours later.
No i thought that you might say that it is not clear :grinning::grinning::grinning::grinning:
anyways is there a solution
Yes, of course there's a solution, but it's
can someone please help
Have you updated your sketch since it was pointed out that your output pins were not specifically set to be outputs ?
