Error when uploading my sketch
I was making an RFID lock with my Arduino Nano but when I try to upload the code to get the card ID it it said;
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x55
Failed uploading: uploading error: exit status 1
this is my code
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9
#define SS_PIN  10
MFRC522 mfrc522(SS_PIN, RST_PIN);
  while (!Serial);
  SPI.begin();
  mfrc522.PCD_Init();
  delay(4);
  mfrc522.PCD_DumpVersionToSerial();
  Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
I didn't write this I was following a tutorial
This means that you have not chosen the correct type of Arduino from the tools menu.
What type of Arduino Nano do you have, there are seven types of Nano.
Also try and select the "old Boot loader" in the Tools menu.
Okey it works now
Great, which one solved the problem?
