Error when uploading sketch on chinese clone
Hello! First of all I'm new at this forum, so I'm not sure if this is the right place to make this question.
I bought a cheap 2 wheel robot kit and it came with an arduino uno chinese clone. It works, but my arduino IDE does not recognize it and when I try to upload an sketch it says it has an error reading.
I tried with an original Arduino UNO and it works just fine, but I want to use the cheap one from the kit for my project. By the way, the clone works. I upload an sketch, error occur but the clone executes the sketch.
I want to rid of this error. What can I do? Should I download some drivers?
I'm currently using Linux Mint Mate 20.2 64-bit and Arduino IDE 1.8.15
arduinounofromchina
In the image it says: "BN: unknown board"
Arduino:1.8.15 (Linux), Tarjeta:"Arduino Uno"
/home/smaydana/Descargas/arduino-1.8.15/arduino-builder -dump-prefs -logger=machine -hardware /home/smaydana/Descargas/arduino-1.8.15/hardware -tools /home/smaydana/Descargas/arduino-1.8.15/tools-builder -tools /home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -built-in-libraries /home/smaydana/Descargas/arduino-1.8.15/libraries -libraries /home/smaydana/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10815 -build-path /tmp/arduino_build_513965 -warnings=none -build-cache /tmp/arduino_cache_474763 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -verbose /tmp/untitled1954015874.tmp/sketch_jul21a/sketch_jul21a.ino
/home/smaydana/Descargas/arduino-1.8.15/arduino-builder -compile -logger=machine -hardware /home/smaydana/Descargas/arduino-1.8.15/hardware -tools /home/smaydana/Descargas/arduino-1.8.15/tools-builder -tools /home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -built-in-libraries /home/smaydana/Descargas/arduino-1.8.15/libraries -libraries /home/smaydana/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10815 -build-path /tmp/arduino_build_513965 -warnings=none -build-cache /tmp/arduino_cache_474763 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr -verbose /tmp/untitled1954015874.tmp/sketch_jul21a/sketch_jul21a.ino
Using board 'uno' from platform in folder: /home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr
Detecting libraries used...
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/cores/arduino -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/variants/standard /tmp/arduino_build_513965/sketch/sketch_jul21a.ino.cpp -o /dev/null
Generating function prototypes...
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/cores/arduino -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/variants/standard /tmp/arduino_build_513965/sketch/sketch_jul21a.ino.cpp -o /tmp/arduino_build_513965/preproc/ctags_target_for_gcc_minus_e.cpp
/home/smaydana/Descargas/arduino-1.8.15/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_513965/preproc/ctags_target_for_gcc_minus_e.cpp
Compilando programa...
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/cores/arduino -I/home/smaydana/Descargas/arduino-1.8.15/hardware/arduino/avr/variants/standard /tmp/arduino_build_513965/sketch/sketch_jul21a.ino.cpp -o /tmp/arduino_build_513965/sketch/sketch_jul21a.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_474763/core/core_arduino_avr_uno_c616ea477e7ffa1fd7ca778a53c97ebf.a
Linking everything together...
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_513965/sketch_jul21a.ino.elf /tmp/arduino_build_513965/sketch/sketch_jul21a.ino.cpp.o /tmp/arduino_build_513965/../arduino_cache_474763/core/core_arduino_avr_uno_c616ea477e7ffa1fd7ca778a53c97ebf.a -L/tmp/arduino_build_513965 -lm
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_513965/sketch_jul21a.ino.elf /tmp/arduino_build_513965/sketch_jul21a.ino.eep
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_513965/sketch_jul21a.ino.elf /tmp/arduino_build_513965/sketch_jul21a.ino.hex
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_513965/sketch_jul21a.ino.elf
El Sketch usa 444 bytes (1%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 2039 bytes para las variables locales. El máximo es 2048 bytes.
/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/bin/avrdude -C/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_513965/sketch_jul21a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/smaydana/Descargas/arduino-1.8.15/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/smaydana/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfc
         Hardware Version: 4238814
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_513965/sketch_jul21a.ino.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.09s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_513965/sketch_jul21a.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_513965/sketch_jul21a.ino.hex:
avrdude: input file /tmp/arduino_build_513965/sketch_jul21a.ino.hex contains 444 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_recv(): programmer is not responding
############avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude done.  Thank you.
el puerto seleccionado
 no existe o tu placa no esta conectada
The last part is in spanish, it says: "the selected port does not exist or the board is not connected"
But it is connected!
Linux Mint 20.2 seems to be from Jule 8, 2021, that is very recent.
Maybe there is a bug in it.
If you type 'groups', do you see the 'dialout' ?
Can you see the board with lsusb ?
I think the the upload was okay, but then the board is lost and the verification failed.
Maybe they put a bad bootloader on it. Do you have a programmer to burn a new bootloader ?
Maybe to board is too cheap. Maybe the USB cable is no good. Can you try another USB cable and connect it to another serial port ?
Can you try Windows 10 ? Or another linux (Ubuntu, Manjaro) form a LiveUSB ?
"dialout" is in my groups. The upload is OK, just the verification is what fails.
I'm not sure about having a programmer to burn a new bootloader. If you mean those things where you put the chip and flashes it, I don't have.
The USB cable I'm using is not the one that comes with the board (It is too short), I'm using a cable that works with my original Arduino UNO.
I tried in windows 10 but it displays the same error, althrow it says "done, thank you".
Arduino:1.8.15 (Windows 10), Tarjeta:"Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Santy\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\Santy\AppData\Local\Temp\arduino_build_465912 -warnings=none -build-cache C:\Users\Santy\AppData\Local\Temp\arduino_cache_419571 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Santy\Desktop\MiRobot-210721a\MiRobot\MiRobot.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Santy\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\Santy\AppData\Local\Temp\arduino_build_465912 -warnings=none -build-cache C:\Users\Santy\AppData\Local\Temp\arduino_cache_419571 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Santy\Desktop\MiRobot-210721a\MiRobot\MiRobot.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp" -o nul
Alternatives for Servo.h: [Servo@1.1.7]
ResolveLibrary(Servo.h)
  -> candidates: [Servo@1.1.7]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp" -o nul
Alternatives for NewPing.h: [NewPing@1.9.1]
ResolveLibrary(NewPing.h)
  -> candidates: [NewPing@1.9.1]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\avr\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\mbed\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\megaavr\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\nrf52\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\sam\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\samd\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\stm32f4\\Servo.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src\\NewPing.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp.o"
Compiling library "Servo"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\avr\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\avr\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\mbed\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\mbed\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\megaavr\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\megaavr\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\nrf52\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\nrf52\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\sam\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\sam\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\samd\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\samd\\Servo.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\stm32f4\\Servo.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\stm32f4\\Servo.cpp.o"
Compiling library "NewPing"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src" "C:\\Users\\Santy\\Documents\\Arduino\\libraries\\NewPing\\src\\NewPing.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\NewPing\\NewPing.cpp.o"
Compiling core...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_shift.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\wiring_shift.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\core.a" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\core\\new.cpp.o"
Archivando el núcleo construido (cacheado) en: C:\Users\Santy\AppData\Local\Temp\arduino_cache_419571\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.elf" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\sketch\\MiRobot.ino.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\avr\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\mbed\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\megaavr\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\nrf52\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\sam\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\samd\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\Servo\\stm32f4\\Servo.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912\\libraries\\NewPing\\NewPing.cpp.o" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/core\\core.a" "-LC:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.elf" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.elf" "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.hex"
Usando librería Servo con versión 1.1.7 en la carpeta: C:\Program Files (x86)\Arduino\libraries\Servo
Usando librería NewPing con versión 1.9.1 en la carpeta: C:\Users\Santy\Documents\Arduino\libraries\NewPing
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Santy\\AppData\\Local\\Temp\\arduino_build_465912/MiRobot.ino.elf"
El Sketch usa 3292 bytes (10%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 74 bytes (3%) de la memoria dinámica, dejando 1974 bytes para las variables locales. El máximo es 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Santy\AppData\Local\Temp\arduino_build_465912/MiRobot.ino.hex:i
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         SCK period      : 3.3 us
avrdude: reading input file "C:\Users\Santy\AppData\Local\Temp\arduino_build_465912/MiRobot.ino.hex"
avrdude: writing flash (3292 bytes):
Writing | ################################################## | 100% 0.55s
avrdude: 3292 bytes of flash written
avrdude: verifying flash memory against C:\Users\Santy\AppData\Local\Temp\arduino_build_465912/MiRobot.ino.hex:
avrdude: load data flash data from input file C:\Users\Santy\AppData\Local\Temp\arduino_build_465912/MiRobot.ino.hex:
avrdude: input file C:\Users\Santy\AppData\Local\Temp\arduino_build_465912/MiRobot.ino.hex contains 3292 bytes
Reading | #######avrdude: stk500_recv(): programmer is not responding
el puerto seleccionado avrdude: failed to read all of flash memory, rc=-2
Beste advice: Throw it away, it is bad.
Second best advice: Buy a programmer or use an Arduino Uno as a programmer to burn a new bootloader. I think there is 50% chance that the problem will be solved with a good bootloader.
I use a USBasp and a 10 to 6 pin adapter. You can use the Arduino IDE to select the programmer and burn the bootloader.
A Arduino Uno as programmer is also called "Arduino ISP": https://www.arduino.cc/en/Tutorial/BuiltInExamples/ArduinoISP
Nick Gammon: https://www.gammon.com.au/bootloader
I can't throw it away, it wasn't that cheap.
I have an original made in Italy Arduino UNO, meaby I can use it to burn the bootloader and try to salvage the chinese clone.
Thank you very much for your advice.
It works! I can't believe it, but it works.
I used my original Arduino Board as an ISP to burn the bootloader into the clone and it worked just fine. No more errors shown.
Thank you very very much!! :partying_face:
I'm glad it is working :grinning: You were on the good side of the 50%.
Perhaps they put an old bootloader in it, or a wrong bootloader, or the voltage was too low when the bootloader was programmed into it.
When I buy a clone, I always put the newest Arduino bootloader in it. Sometimes a bootloader has bug fixes or are changed to a better bootloader. I even put a label on the Arduino that says which version of the Arduino IDE was used to burn the new bootloader into it.
