Error when using #if or #ifdef
Dear all,
I try to make a sketch in which you can use a variety of display's to do the same task. I try to do this with a #define LCD_TYPE and place all the code between #if (LCD_TYPE == 1) and #endif for all the number of display's. At first this seemed to work just fine. I had #define LCD_TYPE 1 and designed the whole sketch for the first display at hand. Then I tried to move to the second LCD type and canged to #define LCD_TYPE 2 and made code in blocks with #if (LCD_TYPE == 2) #endif. But then I got weird error messages.
speedometer.ino: In function 'void setup()':
speedometer.ino:88:14: error: 'displayInit' was not declared in this scope
speedometer.ino: In function 'void loop()':
speedometer.ino:117:16: error: 'checkInput' was not declared in this scope
speedometer.ino:118:42: error: 'calcSpeed' was not declared in this scope
speedometer.ino:119:21: error: 'displaySpeed' was not declared in this scope
speedometer.ino:141:16: error: 'displayBusy' was not declared in this scope
speedometer.ino:144:16: error: 'displayIdle' was not declared in this scope
speedometer.ino: In function 'bool checkInput()':
speedometer.ino:165:11: error: 'class Adafruit_7segment' has no member named 'setCursor'
At first I thought I did something wrong with an #endif or something. But if I changed back to the firt LCD everything was fine again. So I started a new sketch:
#define TEST 1
#if (TEST == 1)
  byte varname = 1;
#endif
#if (TEST == 2)
  byte varname = 3;
#endif
  delay(2000);
  Serial.println(varname);
If I run this I get a 1 at the serial monitor as expected. But if I change it to #define TEST 2 I get a compile error!
deftest.ino:12:3: error: 'byte' does not name a type
deftest.ino: In function 'void setup()':
deftest.ino:17:13: error: 'delay' was not declared in this scope
deftest.ino:18:3: error: 'Serial' was not declared in this scope
deftest.ino:19:18: error: 'varname' was not declared in this scope
Huh?? Why? And the line number in the error is off by 4 (line 12 is blank, it's line 8 in the sketch).
So I thought, mayby I can't check the value. So I edited to use #ifdef
#define TEST_A
//#define TEST_B
#ifdef TEST_A
  byte varname = 1;
#endif
#ifdef TEST_B
  byte varname = 3;
#endif
  delay(2000);
And again, I get a 1 in serial monitor. But if I change to
//#define TEST_A
#define TEST_B
deftest.ino:14:3: error: 'byte' does not name a type
deftest.ino:19:13: error: 'delay' was not declared in this scope
deftest.ino:20:3: error: 'Serial' was not declared in this scope
deftest.ino:21:18: error: 'varname' was not declared in this scope
Hello again error!
Does anyone why it fails? I think it should just leave out a part of the code and compile the rest.
septillion:
Remove the brackets in the comparison:
#define TEST 1
#if TEST == 1
  byte varname = 1;
#endif
#if TEST == 2
  byte varname = 3;
#endif
The IDE modifies your code when it creates a cpp file for the compiler to compile. Using #if, #ifdef, #endif, etc. confuses it as to WHERE to make the modifications.
Usually adding something like
byte me;
as the first line of the sketch solves the problem.
Modifying my code when making the cpp, that's indeed the idea. Adding byte me; indeed fixes the problem! :o But why? Why does it fix it and why get's the compiler confused?
The compiler isn't confused. The IDE is. It doesn't understand postprocessor directives. It assumes that the # is going to be followed by the word include.
So, what happens is that the IDE adds the #include statement to include Arduino.h, where byte and things like that are defined, after the first non-# statement in the code. In your case, that happens to be in the middle of a #if/#endif block that does not get compiled.
Adding a non-# statement at the top of the code gives the IDE a different (and correct) insertion point.
Thnx Paul! Explains it :smiley: But I really hope they fix it in the future.
