Error while setting serial port parameters: 9,600 N 8 1
I keep on getting this error message in my code and don't know how to fix it.
#include <SPI.h>
// Include Libraries
#include "Arduino.h"
#include "LiquidCrystal.h"
#include "RFID.h"
// Pin Definitions
#define LCD_PIN_RS 7
#define LCD_PIN_E 6
#define LCD_PIN_DB4 2
#define LCD_PIN_DB5 3
#define LCD_PIN_DB6 4
#define LCD_PIN_DB7 5
#define RFID_PIN_SDA 10
#define RFID_PIN_RST 8
// Global variables and defines
// object initialization
LiquidCrystal lcd(LCD_PIN_RS,LCD_PIN_E,LCD_PIN_DB4,LCD_PIN_DB5,LCD_PIN_DB6,LCD_PIN_DB7);
RFID rfid(RFID_PIN_SDA,RFID_PIN_RST);
// define vars for testing menu
const int timeout = 10000;       //define timeout of 10 sec
char menuOption = 0;
long time0;
// Setup the essentials for your circuit to work. It runs first every time your circuit is powered with electricity.
    // Setup Serial which is useful for debugging
    // Use the Serial Monitor to view printed messages
    while (!Serial) ; // wait for serial port to connect. Needed for native USB
    Serial.println("start");
    // set up the LCD's number of columns and rows
     lcd.begin(16, 2);
    //initialize RFID module
    rfid.init();
    menuOption = menu();
// Main logic of your circuit. It defines the interaction between the components you selected. After setup, it runs over and over again, in an eternal loop.
    if(menuOption == '1') {
    // LCD 16x2 - Test Code
    // Print a message to the LCD.
    lcd.setCursor(0, 0);
    lcd.print("Circuito Rocks !");
    // Turn off the display:
    lcd.noDisplay();
    // Turn on the display:
    lcd.display();
    else if(menuOption == '2') {
    // RFID - RC522 RF IC Card Sensor Module - Test Code
    //Read RFID tag if present
    String rfidtag = rfid.readTag();
    //print the tag to serial monitor if one was discovered
    rfid.printTag(rfidtag);
    if (millis() - time0 > timeout)
// Menu function for selecting the components to be tested
// Follow serial monitor for instrcutions
char menu()
    Serial.println(F("\nWhich component would you like to test?"));
    Serial.println(F("(1) LCD 16x2"));
    Serial.println(F("(2) RFID - RC522 RF IC Card Sensor Module"));
    Serial.println(F("(menu) send anything else or press on board reset button\n"));
    while (!Serial.available());
    // Read data from serial monitor if received
    while (Serial.available())
        char c = Serial.read();
        if (isAlphaNumeric(c))
            if(c == '1')
     Serial.println(F("Now Testing LCD 16x2"));
     else if(c == '2')
     Serial.println(F("Now Testing RFID - RC522 RF IC Card Sensor Module"));
                Serial.println(F("illegal input!"));
                return 0;
            time0 = millis();
            return c;
*    Circuito.io is an automatic generator of schematics and code for off
*    the shelf hardware combinations.
*    Copyright (C) 2016 Roboplan Technologies Ltd.
*    This program is free software: you can redistribute it and/or modify
*    it under the terms of the GNU General Public License as published by
*    the Free Software Foundation, either version 3 of the License, or
*    (at your option) any later version.
*    This program is distributed in the hope that it will be useful,
*    but WITHOUT ANY WARRANTY; without even the implied warranty of
*    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*    GNU General Public License for more details.
*    You should have received a copy of the GNU General Public License
*    along with this program.  If not, see <http://www.gnu.org/licenses/>.
*    In addition, and without limitation, to the disclaimers of warranties
*    stated above and in the GNU General Public License version 3 (or any
*    later version), Roboplan Technologies Ltd. ("Roboplan") offers this
*    program subject to the following warranty disclaimers and by using
*    this program you acknowledge and agree to the following:
*    THIS PROGRAM IS PROVIDED ON AN "AS IS" AND "AS AVAILABLE" BASIS, AND
*    WITHOUT WARRANTIES OF ANY KIND EITHER EXPRESS OR IMPLIED.  ROBOPLAN
*    HEREBY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING BUT
*    NOT LIMITED TO IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, FITNESS
*    FOR A PARTICULAR PURPOSE, NON-INFRINGEMENT, AND THOSE ARISING BY
*    STATUTE OR FROM A COURSE OF DEALING OR USAGE OF TRADE.
*    YOUR RELIANCE ON, OR USE OF THIS PROGRAM IS AT YOUR SOLE RISK.
*    ROBOPLAN DOES NOT GUARANTEE THAT THE PROGRAM WILL BE FREE OF, OR NOT
*    SUSCEPTIBLE TO, BUGS, SECURITY BREACHES, OR VIRUSES. ROBOPLAN DOES
*    NOT WARRANT THAT YOUR USE OF THE PROGRAM, INCLUDING PURSUANT TO
*    SCHEMATICS, INSTRUCTIONS OR RECOMMENDATIONS OF ROBOPLAN, WILL BE SAFE
*    FOR PERSONAL USE OR FOR PRODUCTION OR COMMERCIAL USE, WILL NOT
*    VIOLATE ANY THIRD PARTY RIGHTS, WILL PROVIDE THE INTENDED OR DESIRED
*    RESULTS, OR OPERATE AS YOU INTENDED OR AS MAY BE INDICATED BY ROBOPLAN.
*    YOU HEREBY WAIVE, AGREE NOT TO ASSERT AGAINST, AND RELEASE ROBOPLAN,
*    ITS LICENSORS AND AFFILIATES FROM, ANY CLAIMS IN CONNECTION WITH ANY OF
*    THE ABOVE.
the full error message was:
avrdude: ser_open(): can't set com-state for "\.\COM3"
An error occurred while uploading the sketch
Yes. It says port 3 (Arduino Uno) and I am using the Arduino Uno
What says that?
Unplug the Arduino from the PC. Close the IDE.
Open the IDE. Make a list of available ports. These are the one that the Arduino is NOT connected to.
Close the IDE. Connect the Arduino. Open the IDE. Make a list of available ports. The ones on this list that are not on the first list (almost certainly only zero or one) are the ones that the Arduino might be connected to.
I did what you said PaulS and it worked. I restarted IDE and I unplugged and plugged back inthe arduino and it started working. Thanks! :wink: :wink: :wink:
