Error while uploading program
I've been trying for so long to get my arduino Uno working now but i can't seem to get it to.
I found out that there was no drivers installed so i did that myself and then i got a lot more text at the bottom which seemed good. But still it isnt working and now i'm getting the error: the selected serial port does not exist or your board is not connected. This is weird to me because after installing the drivers a new port showed up which i know for sure is the one on the arduino. This is because if i remove the usb cable from the uno, this port dissapears.
The error i'm getting right now reads out:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\menno\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x1c
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x03
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4744608
Firmware Version: 0.4611299
Vtarget : 0.4 V
Varef : 0.3 V
Oscillator : 0.531 Hz
SCK period : 10558593.8 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x03
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
The program i am trying to run is just to check if i can even get software on the arduino at all.
It's the built in blink program reading out:
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on
delay(500); // wait for half a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off
I hope someone can help me fix this issue.
Please use the links below to aid you in posting error messages and code etc.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
