Error while verifying a code into Arduino mega board
I'm trying to verify a code which i got from github for my project. When i try to verify it, Im getting an error as
C:\Users\ASUS\AppData\Local\Temp\cckAoUTF.ltrans0.ltrans.o: In function main': C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to loop'
collect2.exe: error: ld returned 1 exit status
Using library CD74HC4067-master at version 1.0.0 in folder: C:\Users\ASUS\AppData\Local\Arduino15\libraries\CD74HC4067-master
Using library TrueRMS-master at version 1.3.0 in folder: C:\Users\ASUS\AppData\Local\Arduino15\libraries\TrueRMS-master
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
I'm hoping for a solution because if I get the code right, I gotta run the simulation in proteus
This is the code:
//library of the multiplexors
#include <CD74HC4067.h>
//library for calculating RMSvalues
#include <TrueRMS.h>
// loop period time in microseconds (time between samples)
#define LPERIOD 1000
// define the used ADC input channel
#define ADC_INPUT 0
// RMS window of 40 samples, means 2 periods at 50Hz
#define RMS_WINDOW 40
unsigned long nextLoop;
int adcVal;
int cnt=0;
// ADC full scale peak-to-peak is 5.00Volts
float VoltRange = 5.00;
// create an instance
Rms readRms ;
CD74HC4067 my_mux(22,23,24,25);
CD74HC4067 my_mux2(26,27,28,29);
CD74HC4067 my_mux3(30,31,32,33);
CD74HC4067 my_mux4(34,35,36,37);
Serial.println("LABEL,v");
Serial.print("DATA, ");
readRms.begin(VoltRange, RMS_WINDOW, ADC_10BIT, BLR_ON,CNT_SCAN);
readRms.start();
// Set the loop timer variable for the next loop interval.
//micros( ) Returns the number of microseconds since the Arduino board began running the current program.
nextLoop = micros() + LPERIOD;
//electrode 0 and 1//electrode 0 and 1
my_mux.channel(0);
my_mux2.channel(1);
for (int k=2;k<15;k++)
my_mux3.channel(k);
my_mux4.channel(k+1);
for(int i=0;i<500;i++)
// Read the ADC and remove the DC-offset
adcVal = analogRead(ADC_INPUT);
//take an instance again
readRms.update(adcVal);
cnt++;
//repeating the readings of one sample
if(cnt >= 500)
// publish every 0.5s
readRms.publish();
Serial.print(readRms.rmsVal,3);
cnt=0;
// wait until the end of the time interval
while(nextLoop > micros());
// set next loop time to current time + LOOP_PERIOD
nextLoop += LPERIOD;
//electrode 1 and 2//electrode 1 and 2
my_mux.channel(1);
my_mux2.channel(2);
for (int k=3;k<15;k++)
my_mux3.channel(k);
cnt++;
if(cnt >= 500)
readRms.publish();
cnt=0;
my_mux3.channel(15);
my_mux4.channel(0);
// Read the ADC and remove the DC-offset.
cnt++;
if(cnt >= 500)
readRms.publish();
cnt=0;
//electrode 2&3//electrode 2&3//electrode 2&3
my_mux.channel(2);
my_mux2.channel(3);
my_mux3.channel(0);
my_mux4.channel(1);
cnt++;
if(cnt >= 500)
readRms.publish();
cnt=0;
for (int k=4;k<15;k++){
my_mux3.channel(k);
cnt++;
if(cnt >= 500)
readRms.publish();
cnt=0;
my_mux4.channel(0);
cnt++;
if(cnt >= 500)
readRms.publish();
cnt=0;
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You don't have a loop() function in your sketch
@sid1901, your topic has been moved to a more suitable location on the forum. This is a compiler / linker error and has nothing to do with Avrdude, stk500 or Bootloader issues.
Hi, @sid1901
Welcome to the forum.
You are doing everything in void setup()
You have no void loop() in your code where most of your repeating code should go.
Have you written any Arduino code before?
What is the application of your code?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Hey! Actually I don't have any experience in coding. I found this code in GitHub. It's for my project caled "Electrical Impedance Tomography". I realized that there is no loop funtion and thought someone might help me with it
Just add an empty loop() at the end. See e.g. the blank (not blink) example.
That will get rid of the linker error.
I actually did this and the error was gone. But I had a doubt that what should be in the loop function? I feel like i the code provided was incomplete so I guess something should've been in the loop function.
Did a circuit diagram come with the code?
Electrical impedance tomography (EIT) is a noninvasive type of medical imaging in which the electrical conductivity, permittivity, and impedance of a part of the body is inferred from surface electrode measurements and used to form a tomographic image of that part.
Not necessarily. You can put everything in setup() if so inclined or if it's needed. I think that that is the case here but because you did not use code tags and I'm using a cell phone it's difficult to be sure.
Please edit your opening post, select all code and click the </> button. That will make it easier to read, prevents misinterpretation by the forum software and makes it easier to copy.
Hey tom! yeah i have a circuit diagram. Its very low quality but i hope it helps.
I also have a pdf with proteus circuit I madeProcessing: diagram.PDF...
Hey! I edited the code and I put it in code tags. Check it if possible
What do you actually want the sketch to do ?
Yes its not the best.
Can you post a link to where you got the code and other information please?
What are the sensors in the array?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
The project is called Electrical Impedance Tomography. It's a medical imaging project. Basically 16 electrodes are attached to a body or a resistor mesh and current is injected and voltages are calculates in a specific pattern. All these voltage differences are fed into EIDORS and image is constructed. Please read this paper to get a better understanding
http://repository.sustech.edu/handle/123456789/24109
Yeah sure this is the link for the research paper that I've been referring.
I actually have a pdf of circuit diagram but Im not yet allowed to upload attachments. I can mail it to you if that's possible
Thanks for the code tags.
I suspected that setup() would be looping forever but it isn't. So the code does a number of readings, sends it over Serial and next stops doing things.
If you want to collect data, you need some form of program on the PC; e.g. Serial Monitor.
When the PC program opens the serial port, your Arduino is restarted and you get the readings.
If you want to collect new readings, either
  1. you close the PC program and open it again
  2. the program closes the serial port and opens it again
I think that this approach was intentionally.
Do you have a link to the github page where you found the code; it might explain why the approach was chosen.
Hey! Actually I mistakenly said that it was from a github page. I was confused with another code which I found on github. I found the above code from a research paper. I posted the link to the paper in above replies. Thanks
Hi, @sid1901
When you have new information, please add it as a new post, don't go back and edit old posts.
When you do update old posts, you make it just about impossible to read the flow of the thread, especially if code has been changed or edited.
Hey! Im sorry this is my 1st time in here so I really don't know stuff
