Esp 01 wifi car
Hi, I need some advice and maybe make a code, I'm trying to make a car with wifi control in front of an arduino mega and esp 01, I got to the point where I have motors connected via h bridges and I can program the esp 01 as an access point and send some commands via the web via buttons, which has the problem that it's only one command and the motor just shake little bit
If you read the pinned post re 'How to get the most from the forum,' you will learn what you need to do to get some help.
Mate what i did wrong? I just asked
If You t´read the advicing reply You will know: How to get the best out of this forum - Development Tools / IDE 1.x - Arduino Forum
Yeah i read that but still i dont undestand sorry, if the problem is my code the code is completly useless and i delte like half of it
In that case, finish your code, and if/when it fails, do the things outlined in the pinned post regarding the wiring diagram and code. Also, if there is any serial output, post it in code tags also. Good luck.
No, you did not. The text also says to show and describe the specifications of the hardware, make a wiring diagram showing the hardware connections, and the code used to control the hardwre.
Yeah i know but i alrady specified my hardware and i said i delete my code
@PerryBebbington hi can you please selete this post i want to star again
