ESP-32 cannot upload
Hi probably something stupid going on here but cant find it !
I have a bare ESP32-S3 WROOM 1 connected to a USAT/USB board. via TX0 and RX0.
if I use Putty (11520) it communicates fine giving this output when I reset it:
Build:Mar ▒ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot▒ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),▒ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (ESP-ROM:esp32s3-20210327
Build:Mar▒ESP-ROM:esp32s3-2021032▒ESP-ROM:esp32s3-20210327
ESP-ROM▒ESP-ROM:esp32s3-20210327
ESP-ROM:esp32s3-20210327▒ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x0 (DOWNLOAD(USB/UART0))
waiting for download
Build:Mar 27 2021
rst:0x1 (PO▒ESP-ROM:esp32s3-20210327
Build▒ESP-ROM:esp32s3-20210327
Build:▒ESP-ROM:esp32s3-20210327
in the Arduino 1.8
I have this code which I attempt to upload with I00 set to 0v and "EN" briefly set to 0v
The COM port is visable as COM 8 and I have tried upload speed of 921600 and 115200.
TX0 >RX and RX0>TX
Board setting are:
firebeetle -esp32
upload speed - tried 115200 and 921600
Flash freqency 80Mhz
Core debug level none
I also have tried board type as Lolin 32 , sparkfun32, esp32s3devmodule
 Serial.println("ESP working !!");
The error message is
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
the selected serial port For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
 does not exist or your board is not connected
anyone see whats wrong ?
thx
Had a good read and I’ll report back if it works .. apparently it’s connect IO0 to0v then , reset , then release both - by which time the COM port may have changed .
Then upload ..
Fingers crossed !
** Edit** Yes that fixed it - usefully if you have a serial monitor connected (115200) then after this reseting you will get a waiting for upload message.
