I am having an issue uploading code from the Arduino IDE to my ESP32. It keeps showing the error: “Fatal Error: No serial data received.”
I have already downloaded and installed the CP210x driver for Windows, but the error still exists. I also tried the boot button method, but I am getting the same error.
In the Tools menu, which processor did you choose, and does it
match the board you are using?
Does the correct port appear in the Tools > Port menu?
If either of those is incorrect, you have likely found the problem.
When you get this message (not sure which IDE version you are using),
there is usually a window or box that opens with an option to copy the
output. Copy the entire message, then click the < CODE > button in the
forum editor and paste it there.
Posting it that way makes it much easier to read and greatly improves
the chances of getting good help.
When you show us proof you have followed the advice of post 2, 6, and 9 then maybe someone can help.
My 'hunch' is it is a win device mgr issue but without screen shots we can't do a thing.
