Esp-wroom-32 doesn't connect to arduino 2.3.1 windows 10
i selected “ESP32-WROOM-DA Modue” in the board manager of the arduino
i'm trying to use esp-wroom-32 and it refuses to show up in the ide
i've tried two different modules, all the 3 port on my laptop and all possible cables, that all worked on arduino uno board normally
sorry for the dumb ask but what could be the problem?
I moved your topic to an appropriate forum category @ebnragab.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Does your PC Operating System recognise the board when you plug it in ?
Try DOIT ESP32 DEVKIT V1 from board manager. It may even say devkit v1 on the bottom of the board.
If the IDE does not recognise the board, you will have to look, as mentioned by @UKHeliBob, at the operating system level. Which operating system are you using? If it's Windows, any yellow exclamation marks in the device manager? If Windows, did you install the driver for the CP2102 serial-to-usb converter?
I've never seen an Uno with the same USB connector as your ESP32-WROOM module shows.
