ESP12 not working with Arduino IDE
I am a beginner in using the ESP12 board with Arduino IDE,
After learning from Installation · ESP8266 Arduino Core
as per their suggestion in Arduino IDE -> File-> Preferences-> Additional Boards manager URL -> added URL :http://arduino.esp8266.com/stable/package_esp8266com_index.json ->pressed ok
After this in
Tools-> Board: "Arduino","Genuino"->Board manager->searching ESP8266
But after searching nothing appears on board manager search, I have attached the snapshot also,
Please suggest avoiding this kind of issue. Looking forward to your advice
After you close Boards Manager, you'll see a bunch of text in the black console window at the bottom of the Arduino IDE window. Please copy all off that text (you may need to scroll the window up to see it all) and then paste it in a reply here using code tags (</> button on the toolbar).
Hello Pert
Thank for Reply the error is :
Error downloading http://downloads.arduino.cc/packages/package_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:150)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:139)
	at cc.arduino.contributions.packages.ContributionInstaller.download(ContributionInstaller.java:333)
	at cc.arduino.contributions.packages.ContributionInstaller.downloadIndexAndSignature(ContributionInstaller.java:307)
	at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:285)
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:146)
	... 1 more
Caused by: java.net.SocketException: Address family not supported by protocol family: connect
	at java.net.DualStackPlainSocketImpl.connect0(Native Method)
	at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:83)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
	at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
	at sun.net.www.http.HttpClient.New(HttpClient.java:339)
	at sun.net.www.http.HttpClient.New(HttpClient.java:357)
	at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1220)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1199)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1050)
	at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:984)
	at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:181)
	at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:132)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:137)
	... 5 more
The sketch name had to be modified.
Sketch names must start with a letter or number, followed by letters,
numbers, dashes, dots and underscores. Maximum length is 63 characters.
	... 1 more
	... 5 more
	... 1 more
	... 5 more
There is a bunch of information of your error:
here:
It has been reported to be caused by having spyware running on your computer.
@OP
Please, post the pictorial view (or link) of your ESP12 Board. There are many varieties of boards; but, all are generally called ESP8266 Boards. Mine one is NodeMCU1.0-12E Module. It is working fine with Arduino IDE.
This issue has absolutely nothing to do with the ESP12 board. It's a problem with downloading the Boards Manager JSON file. The same error would occur even if frank75 hadn't added the ESP8266 Additional Boards Manager URL because it's not even getting past the download of the official Arduino JSON file that is done before downloading the 3rd party JSON files.
Hi, Yes by using these different ways I am able to install the ESP8266 board in Arduino code by
-open the preferences menu,
  • Navigate to the "More preferences can navigate directly" .Arduino15 folder clicking on the preferences path.
  • open the folder staging/packages and try to delete all the archive you have there.
If Still won't work then
-Open cmd prompt.
  • type "setx _JAVA_OPTIONS -Djava.net.preferIPv4Stack=true"
  • Click enter
If Still Issue occurs then:
  • search for "Network proxy settings"
  • turn off the automatic proxy setup
Note: after every step mentioned above do Restart Arduino IDE again.
Thanks a lot for everyone help :smiley:
I'm glad to hear you got it installed. Enjoy!
Per
