ESP13 shield and remotexy problem
Can anyone assist me with the use of the wifi shield ESP13 which is using the ESP8266 i have installed the shield onto my arduino UNO and can configure the shield through the webpage setup. I have wrote a little android program with remotexy and loaded to the arduino uno. I can find the wifi and remotexy connects but tells me it receives no data. My problem is maybe the connections for rx / tx maybe as it looks like the shield connects rx to rx and tx to tx from shield to arduino. Has anyone used this shield with the uno and remotexy that can give me some help. The code supplied by remotexy is as follows:-
//        RemoteXY include library          //
//     use  library  version 2.2.2 or up    //
//   use ANDROID app version 3.5.1 or up    //
/* RemoteXY select connection mode and include library */
#define REMOTEXY_MODE__ESP8266POINT_SOFTSERIAL
#include <SoftwareSerial.h>
#include <RemoteXY.h>
/* RemoteXY connection settings */
#define REMOTEXY_SERIAL_RX 0
#define REMOTEXY_SERIAL_TX 1
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_WIFI_SSID "Swimming_Pooll"
#define REMOTEXY_WIFI_PASSWORD "12345678"
#define REMOTEXY_SERVER_PORT 9000
/* RemoteXY configurate  */
unsigned char RemoteXY_CONF[] =
  { 1,0,12,0,5,5,0,1,0,34
  ,13,33,33,2,88,0 };
/* this structure defines all the variables of your control interface */
struct {
    /* input variable */
  unsigned char button_1; /* =1 if button pressed, else =0 */
    /* other variable */
  unsigned char connect_flag;  /* =1 if wire connected, else =0 */
} RemoteXY;
//           END RemoteXY include          //
#define PIN_BUTTON_1 13
  RemoteXY_Init ();
  pinMode (PIN_BUTTON_1, OUTPUT);
  // TODO you setup code
  RemoteXY_Handler ();
  digitalWrite(PIN_BUTTON_1, (RemoteXY.button_1==0)?LOW:HIGH);
  // TODO you loop code
  // use the RemoteXY structure for data transfer
