ESP32-2432S028R Color problem
Hi can anyone help me i did try everything and no fix esp32-2432s028 2USB :cry:
#include <WiFi.h>
#include <HTTPClient.h>
#include <TJpg_Decoder.h>
#include <TFT_eSPI.h>
#include <SD.h>
#include <SPI.h>
// --- KONFIGURACJA ---
const char* ssid     = "xxxxe";
const char* password = "xxxxx6";
const char* cam_url  = "http://xxxx/cgi-bin/snapshot.sh?res=low&watermark=yes";
// Piny dla karty SD w module ESP32-2432S028 (CYD)
#define SD_CS 5
TFT_eSPI tft = TFT_eSPI();
// Renderowanie obrazu z SD na ekran
bool tft_output(int16_t x, int16_t y, uint16_t w, uint16_t h, uint16_t* bitmap) {
  if (y >= tft.height()) return false;
  tft.pushImage(x, y, w, h, bitmap);
  return true;
  tft.begin();
  tft.setRotation(1);
  tft.fillScreen(TFT_BLACK);
  // ODWRÓCENIE KOLORÓW (Negatyw)
  tft.invertDisplay(1);
  pinMode(21, OUTPUT); digitalWrite(21, HIGH); // Podświetlenie
  // Inicjalizacja Karty SD
  if (!SD.begin(SD_CS)) {
    Serial.println("Błąd karty SD!");
    tft.println("SD Card Error!");
    Serial.println("Karta SD OK.");
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); }
  TJpgDec.setJpgScale(2); // Ustaw 2, jeśli obraz jest większy niż 320x240
  TJpgDec.setCallback(tft_output);
  if (WiFi.status() == WL_CONNECTED) {
    HTTPClient http;
    http.begin(cam_url);
    int httpCode = http.GET();
    if (httpCode == HTTP_CODE_OK) {
      // 1. ZAPIS NA KARTĘ SD
      File file = SD.open("/snap.jpg", FILE_WRITE);
      if (file) {
        http.writeToStream(&file);
        file.close();
        Serial.println("Zapisano na SD.");
        // 2. ODCZYT Z KARTY SD I WYŚWIETLENIE
        TJpgDec.drawSdJpg(0, 0, "/snap.jpg");
        Serial.println("Obraz wyswietlony z SD.");
        Serial.println("Błąd zapisu na SD!");
    http.end();
  Serial.println("Czekam 30s...");
  delay(30000);
color is inverted and everything what i tried not working
My TFT Settings
//                            USER DEFINED SETTINGS
//   Set driver type, fonts to be loaded, pins used and SPI control method etc
//   See the User_Setup_Select.h file if you wish to be able to define multiple
//   setups and then easily select which setup file is used by the compiler.
//   If this file is edited correctly then all the library example sketches should
//   run without the need to make any more changes for a particular hardware setup!
//   Note that some sketches are designed for a particular TFT pixel width/height
// User defined information reported by "Read_User_Setup" test & diagnostics example
#define USER_SETUP_INFO "User_Setup"
// Define to disable all #warnings in library (can be put in User_Setup_Select.h)
// #define DISABLE_ALL_LIBRARY_WARNINGS
// Section 1. Call up the right driver file and any options for it
// Define STM32 to invoke optimised processor support (only for STM32)
// #define STM32
// Defining the STM32 board allows the library to optimise the performance
// for UNO compatible "MCUfriend" style shields
// #define NUCLEO_64_TFT
// #define NUCLEO_144_TFT
// STM32 8 bit parallel only:
// If STN32 Port A or B pins 0-7 are used for 8 bit parallel data bus bits 0-7
// then this will improve rendering performance by a factor of ~8x
// #define STM_PORTA_DATA_BUS
// #define STM_PORTB_DATA_BUS
// Tell the library to use parallel mode (otherwise SPI is assumed)
// #define TFT_PARALLEL_8_BIT
// #defined TFT_PARALLEL_16_BIT // **** 16 bit parallel ONLY for RP2040 processor ****
// Display type -  only define if RPi display
// #define RPI_DISPLAY_TYPE // 20MHz maximum SPI
// Only define one driver, the other ones must be commented out
// #define ILI9341_DRIVER       // Generic driver for common displays
// #define ILI9341_2_DRIVER // Alternative ILI9341 driver, see https://github.com/Bodmer/TFT_eSPI/issues/1172
// #define ST7735_DRIVER      // Define additional parameters below for this display
// #define ILI9163_DRIVER     // Define additional parameters below for this display
// #define S6D02A1_DRIVER
// #define RPI_ILI9486_DRIVER // 20MHz maximum SPI
// #define HX8357D_DRIVER
// #define ILI9481_DRIVER
// #define ILI9486_DRIVER
// #define ILI9488_DRIVER     // WARNING: Do not connect ILI9488 display SDO to MISO if other devices share the SPI bus (TFT SDO does NOT tristate when CS is high)
#define ST7789_DRIVER      // Full configuration option, define additional parameters below for this display
// #define ST7789_2_DRIVER    // Minimal configuration option, define additional parameters below for this display
// #define R61581_DRIVER
// #define RM68140_DRIVER
// #define ST7796_DRIVER
// #define SSD1351_DRIVER
// #define SSD1963_480_DRIVER
// #define SSD1963_800_DRIVER
// #define SSD1963_800ALT_DRIVER
// #define ILI9225_DRIVER
// #define GC9A01_DRIVER
// Some displays support SPI reads via the MISO pin, other displays have a single
// bi-directional SDA pin and the library will try to read this via the MOSI line.
// To use the SDA line for reading data from the TFT uncomment the following line:
// #define TFT_SDA_READ      // This option is for ESP32 ONLY, tested with ST7789 and GC9A01 display only
// For ST7735, ST7789 and ILI9341 ONLY, define the colour order IF the blue and red are swapped on your display
// Try ONE option at a time to find the correct colour order for your display
//  #define TFT_RGB_ORDER TFT_RGB  // Colour order Red-Green-Blue
#define TFT_RGB_ORDER TFT_BGR  // Colour order Blue-Green-Red
// For M5Stack ESP32 module with integrated ILI9341 display ONLY, remove // in line below
// #define M5STACK
// For ST7789, ST7735, ILI9163 and GC9A01 ONLY, define the pixel width and height in portrait orientation
// #define TFT_WIDTH  80
// #define TFT_WIDTH  128
// #define TFT_WIDTH  172 // ST7789 172 x 320
// #define TFT_WIDTH 240 // ST7789 240 x 240 and 240 x 320
// #define TFT_HEIGHT 160
// #define TFT_HEIGHT 128
// #define TFT_HEIGHT 240 // ST7789 240 x 240
// #define TFT_HEIGHT 320 // ST7789 240 x 320
// #define TFT_HEIGHT 240 // GC9A01 240 x 240
// For ST7735 ONLY, define the type of display, originally this was based on the
// colour of the tab on the screen protector film but this is not always true, so try
// out the different options below if the screen does not display graphics correctly,
// e.g. colours wrong, mirror images, or stray pixels at the edges.
// Comment out ALL BUT ONE of these options for a ST7735 display driver, save this
// this User_Setup file, then rebuild and upload the sketch to the board again:
// #define ST7735_INITB
// #define ST7735_GREENTAB
// #define ST7735_GREENTAB2
// #define ST7735_GREENTAB3
// #define ST7735_GREENTAB128    // For 128 x 128 display
// #define ST7735_GREENTAB160x80 // For 160 x 80 display (BGR, inverted, 26 offset)
// #define ST7735_ROBOTLCD       // For some RobotLCD arduino shields (128x160, BGR, https://docs.arduino.cc/retired/getting-started-guides/TFT)
// #define ST7735_REDTAB
// #define ST7735_BLACKTAB
// #define ST7735_REDTAB160x80   // For 160 x 80 display with 24 pixel offset
// If colours are inverted (white shows as black) then uncomment one of the next
// 2 lines try both options, one of the options should correct the inversion.
#define TFT_INVERSION_ON
//#define TFT_INVERSION_OFF
// Section 2. Define the pins that are used to interface with the display here
// If a backlight control signal is available then define the TFT_BL pin in Section 2
// below. The backlight will be turned ON when tft.begin() is called, but the library
// needs to know if the LEDs are ON with the pin HIGH or LOW. If the LEDs are to be
// driven with a PWM signal or turned OFF/ON then this must be handled by the user
// sketch. e.g. with digitalWrite(TFT_BL, LOW);
#define TFT_BL 21             // LED back-light control pin
#define TFT_BACKLIGHT_ON HIGH // Level to turn ON back-light (HIGH or LOW)
// We must use hardware SPI, a minimum of 3 GPIO pins is needed.
// Typical setup for ESP8266 NodeMCU ESP-12 is :
// Display SDO/MISO  to NodeMCU pin D6 (or leave disconnected if not reading TFT)
// Display LED       to NodeMCU pin VIN (or 5V, see below)
// Display SCK       to NodeMCU pin D5
// Display SDI/MOSI  to NodeMCU pin D7
// Display DC (RS/AO)to NodeMCU pin D3
// Display RESET     to NodeMCU pin D4 (or RST, see below)
// Display CS        to NodeMCU pin D8 (or GND, see below)
// Display GND       to NodeMCU pin GND (0V)
// Display VCC       to NodeMCU 5V or 3.3V
// The TFT RESET pin can be connected to the NodeMCU RST pin or 3.3V to free up a control pin
// The DC (Data Command) pin may be labelled AO or RS (Register Select)
// With some displays such as the ILI9341 the TFT CS pin can be connected to GND if no more
// SPI devices (e.g. an SD Card) are connected, in this case comment out the #define TFT_CS
// line below so it is NOT defined. Other displays such at the ST7735 require the TFT CS pin
// to be toggled during setup, so in these cases the TFT_CS line must be defined and connected.
// The NodeMCU D0 pin can be used for RST
// Note: only some versions of the NodeMCU provide the USB 5V on the VIN pin
// If 5V is not available at a pin you can use 3.3V but backlight brightness
// will be lower.
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP8266 SETUP ######
// For NodeMCU - use pin numbers in the form PIN_Dx where Dx is the NodeMCU pin designation
// #define TFT_CS   PIN_D8  // Chip select control pin D8
// #define TFT_DC   PIN_D3  // Data Command control pin
// #define TFT_RST  PIN_D4  // Reset pin (could connect to NodeMCU RST, see next line)
// #define TFT_RST  -1    // Set TFT_RST to -1 if the display RESET is connected to NodeMCU RST or 3.3V
// #define TFT_BL PIN_D1  // LED back-light (only for ST7789 with backlight control pin)
// #define TOUCH_CS PIN_D2     // Chip select pin (T_CS) of touch screen
// #define TFT_WR PIN_D2       // Write strobe for modified Raspberry Pi TFT only
// ######  FOR ESP8266 OVERLAP MODE EDIT THE PIN NUMBERS IN THE FOLLOWING LINES  ######
// Overlap mode shares the ESP8266 FLASH SPI bus with the TFT so has a performance impact
// but saves pins for other functions. It is best not to connect MISO as some displays
// do not tristate that line when chip select is high!
// Note: Only one SPI device can share the FLASH SPI lines, so a SPI touch controller
// cannot be connected as well to the same SPI signals.
// On NodeMCU 1.0 SD0=MISO, SD1=MOSI, CLK=SCLK to connect to TFT in overlap mode
// On NodeMCU V3  S0 =MISO, S1 =MOSI, S2 =SCLK
// In ESP8266 overlap mode the following must be defined
// #define TFT_SPI_OVERLAP
// In ESP8266 overlap mode the TFT chip select MUST connect to pin D3
// #define TFT_CS   PIN_D3
// #define TFT_DC   PIN_D5  // Data Command control pin
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP32 SETUP   ######
// For ESP32 Dev board (only tested with ILI9341 display)
// The hardware SPI can be mapped to any pins
#define TFT_MISO 12
#define TFT_MOSI 13
#define TFT_SCLK 14
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 2  // Data Command control pin
// #define TFT_RST   4  // Reset pin (could connect to RST pin)
#define TFT_RST -1 // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
// For ESP32 Dev board (only tested with GC9A01 display)
// #define TFT_MOSI 15 // In some display driver board, it might be written as "SDA" and so on.
// #define TFT_SCLK 14
// #define TFT_CS   5  // Chip select control pin
// #define TFT_DC   27  // Data Command control pin
// #define TFT_RST  33  // Reset pin (could connect to Arduino RESET pin)
// #define TFT_BL   22  // LED back-light
// #define TOUCH_CS 21     // Chip select pin (T_CS) of touch screen
// #define TFT_WR 22    // Write strobe for modified Raspberry Pi TFT only
// For the M5Stack module use these #define lines
// #define TFT_MISO 19
// #define TFT_MOSI 23
// #define TFT_SCLK 18
// #define TFT_CS   14  // Chip select control pin
// #define TFT_BL   32  // LED back-light (required for M5Stack)
// ######       EDIT THE PINs BELOW TO SUIT YOUR ESP32 PARALLEL TFT SETUP        ######
// The library supports 8 bit parallel TFTs with the ESP32, the pin
// selection below is compatible with ESP32 boards in UNO format.
// Wemos D32 boards need to be modified, see diagram in Tools folder.
// Only ILI9481 and ILI9341 based displays have been tested!
// Parallel bus is only supported for the STM32 and ESP32
// Example below is for ESP32 Parallel interface with UNO displays
// Tell the library to use 8 bit parallel mode (otherwise SPI is assumed)
// The ESP32 and TFT the pins used for testing are:
// #define TFT_CS   33  // Chip select control pin (library pulls permanently low
// #define TFT_DC   15  // Data Command control pin - must use a pin in the range 0-31
// #define TFT_RST  32  // Reset pin, toggles on startup
// #define TFT_WR    4  // Write strobe control pin - must use a pin in the range 0-31
// #define TFT_RD    2  // Read strobe control pin
// #define TFT_D0   12  // Must use pins in the range 0-31 for the data bus
// #define TFT_D1   13  // so a single register write sets/clears all bits.
// #define TFT_D2   26  // Pins can be randomly assigned, this does not affect
// #define TFT_D3   25  // TFT screen update performance.
// #define TFT_D4   17
// #define TFT_D5   16
// #define TFT_D6   27
// #define TFT_D7   14
// ######       EDIT THE PINs BELOW TO SUIT YOUR STM32 SPI TFT SETUP        ######
// The TFT can be connected to SPI port 1 or 2
// #define TFT_SPI_PORT 1 // SPI port 1 maximum clock rate is 55MHz
// #define TFT_MOSI PA7
// #define TFT_MISO PA6
// #define TFT_SCLK PA5
// #define TFT_SPI_PORT 2 // SPI port 2 maximum clock rate is 27MHz
// #define TFT_MOSI PB15
// #define TFT_MISO PB14
// #define TFT_SCLK PB13
// Can use Ardiuno pin references, arbitrary allocation, TFT_eSPI controls chip select
// #define TFT_CS   D5 // Chip select control pin to TFT CS
// #define TFT_DC   D6 // Data Command control pin to TFT DC (may be labelled RS = Register Select)
// #define TFT_RST  D7 // Reset pin to TFT RST (or RESET)
// OR alternatively, we can use STM32 port reference names PXnn
// #define TFT_CS   PE11 // Nucleo-F767ZI equivalent of D5
// #define TFT_DC   PE9  // Nucleo-F767ZI equivalent of D6
// #define TFT_RST  PF13 // Nucleo-F767ZI equivalent of D7
// #define TFT_RST  -1   // Set TFT_RST to -1 if the display RESET is connected to processor reset
//  Use an Arduino pin for initial testing as connecting to processor reset
//  may not work (pulse too short at power up?)
// Section 3. Define the fonts that are to be used here
// Comment out the #defines below with // to stop that font being loaded
// The ESP8366 and ESP32 have plenty of memory so commenting out fonts is not
// normally necessary. If all fonts are loaded the extra FLASH space required is
// about 17Kbytes. To save FLASH space only enable the fonts you need!
#define LOAD_GLCD  // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
// #define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
// Section 4. Other options
// For RP2040 processor and SPI displays, uncomment the following line to use the PIO interface.
// #define RP2040_PIO_SPI // Leave commented out to use standard RP2040 SPI port interface
// For RP2040 processor and 8 or 16 bit parallel displays:
// The parallel interface write cycle period is derived from a division of the CPU clock
// speed so scales with the processor clock. This means that the divider ratio may need
// to be increased when overclocking. I may also need to be adjusted dependant on the
// display controller type (ILI94341, HX8357C etc). If RP2040_PIO_CLK_DIV is not defined
// the library will set default values which may not suit your display.
// The display controller data sheet will specify the minimum write cycle period. The
// controllers often work reliably for shorter periods, however if the period is too short
// the display may not initialise or graphics will become corrupted.
// PIO write cycle frequency = (CPU clock/(4 * RP2040_PIO_CLK_DIV))
// #define RP2040_PIO_CLK_DIV 1 // 32ns write cycle at 125MHz CPU clock
// #define RP2040_PIO_CLK_DIV 2 // 64ns write cycle at 125MHz CPU clock
// #define RP2040_PIO_CLK_DIV 3 // 96ns write cycle at 125MHz CPU clock
// For the RP2040 processor define the SPI port channel used (default 0 if undefined)
// #define TFT_SPI_PORT 1 // Set to 0 if SPI0 pins are used, or 1 if spi1 pins used
// For the STM32 processor define the SPI port channel used (default 1 if undefined)
// #define TFT_SPI_PORT 2 // Set to 1 for SPI port 1, or 2 for SPI port 2
// Define the SPI clock frequency, this affects the graphics rendering speed. Too
// fast and the TFT driver will not keep up and display corruption appears.
// With an ILI9341 display 40MHz works OK, 80MHz sometimes fails
// With a ST7735 display more than 27MHz may not work (spurious pixels and lines)
// With an ILI9163 display 27 MHz works OK.
// #define SPI_FREQUENCY   1000000
// #define SPI_FREQUENCY   5000000
// #define SPI_FREQUENCY  10000000
// #define SPI_FREQUENCY  20000000
// #define SPI_FREQUENCY  27000000
// #define SPI_FREQUENCY  40000000
#define SPI_FREQUENCY 55000000 // STM32 SPI1 only (SPI2 maximum is 27MHz)
// #define SPI_FREQUENCY  80000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY 20000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY 2500000
// The ESP32 has 2 free SPI ports i.e. VSPI and HSPI, the VSPI is the default.
// If the VSPI port is in use and pins are not accessible (e.g. TTGO T-Beam)
// then uncomment the following line:
#define USE_HSPI_PORT
// Comment out the following #define if "SPI Transactions" do not need to be
// supported. When commented out the code size will be smaller and sketches will
// run slightly faster, so leave it commented out unless you need it!
// Transaction support is needed to work with SD library but not needed with TFT_SdFat
// Transaction support is required if other SPI devices are connected.
// Transactions are automatically enabled by the library for an ESP32 (to use HAL mutex)
// so changing it here has no effect
// #define SUPPORT_TRANSACTIONS
Try this user setup for the CYD...
I did try everything no change :neutral_face:
How is the original photo showing this not working?
I doubt this, but if you quit, okay.
Only what i find out that User_Setup.h is correct works fine. I got something wrong in my code
I done it YEY i was missing :smiley:
 tft.setSwapBytes(true);
Please close nad bin
You can close this topic yourself by selecting the post that gave you the clue that lead you to finding a solution.
