Hello, I am moving a project from Arduino UNO, to ESP32, but I am having difficulties with the code in ESP32, in this case, when pressing a button, it should play a specific sound, but it does not work. I am basing it on my old Arduino UNO code.
My diagram
Current code:
#include <Arduino.h>
#include "DFRobotDFPlayerMini.h"
bool doneFlag = false;
HardwareSerial mySoftwareSerial(1);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
# define ACTIVATED LOW
int btnpuerta = 35;
int btnwelcome = 34;
mySoftwareSerial.begin(9600, SERIAL_8N1, 16, 17); // speed, type, RX, TX
pinMode(btnpuerta, INPUT);
digitalWrite(btnpuerta, HIGH);
pinMode(btnwelcome, INPUT);
//digitalWrite(btnwelcome, HIGH);
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
//----Set volume----
myDFPlayer.volume(30); //Set volume value (0~30).
myDFPlayer.volumeUp(); //Volume Up
myDFPlayer.volumeDown(); //Volume Down
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
//----Set device we use SD as default----
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
//----Read imformation----
Serial.println(myDFPlayer.readState()); //read mp3 state
Serial.println(myDFPlayer.readVolume()); //read current volume
Serial.println(myDFPlayer.readEQ()); //read EQ setting
Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
if (digitalRead(btnpuerta) == ACTIVATED) {
myDFPlayer.play(1);
delay(2000);
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
My old code, used in Arduino UNO, this code working perfectly
#include "SoftwareSerial.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
int btnpuerta = 7;
int btnwelcome = 6;
mySoftwareSerial.begin(9600);
Serial.println(F("Escanmotor.com"));
while (true);
mySoftwareSerial.listen();
myDFPlayer.play(1);
delay(2000);
if (digitalRead(btnwelcome) == ACTIVATED) {
if (doneFlag == false) // fragmento para repetir el comando una sola vez
myDFPlayer.play (5);
delay (2000);
myDFPlayer.stop ();
doneFlag = true;
/*Restablecemos para que se vuelva activar al desaparecer la señal*/
doneFlag = false;
void printDetail(uint8_t type, int value) {
switch (type) {
case TimeOut:
case WrongStack:
case DFPlayerUSBInserted:
Serial.println("USB Inserted!");
case DFPlayerUSBRemoved:
Serial.println("USB Removed!");
case DFPlayerError:
switch (value) {
case Busy:
case Sleeping:
case FileIndexOut:
case FileMismatch:
case Advertise:
default:
default:
Thnks for u help
