ESP32 Audio: Max98357
Im new to esp32 world.
I have esp32, and max98357 amplifier and 0.5w speaker.
I am able to the radio streaming.
But I want to play the audio file real-time, that ".wav" audio file will get generated at the server on time interval of half or one second.(every time new file will get generated).
I want to play it on the esp32 on every new file generation.
How can I do this?
Is it possible?
If other components are needed to do this?(I can buy)
Thanks
OMGGGGGG. Buddy pls reply. II have the same component. Same problem.
CAN u tell me did it work, how u did it. Pls reply and help. I cant stress thins enough how tired and tensed I am. Please brother
Welcome! The term "ESP32" has almost become as generic as "car." Without knowing the specific model you’re using or how you’ve wired it, it’s difficult to provide detailed assistance.
To help us help you, please provide an annotated schematic showing your wiring setup and include links to the technical documentation for the hardware components.
If you don’t have all the details at hand, the best I can do is share what I found using a search engine. I used the search term "max98357 with ESP32 music" and found several links that might be helpful. Here’s the first result:
ESP32-S3-I2S-MAX98357 GitHub Repository
