Playing audio with ESP32CAM and MAX98357A
So I am trying to play audio files '16bit 16khz wav file' stored in the flash of ESP32CAM using LittleFS. I am using MAX98357A for this. I know the camera already uses I2S pins in ESP32CAM, but according to what I have found, the pins can be redefined. Can I use I2S to make all of this work? Or is there any other way? Even after making all the connections, the audio is not playing!! Help plss
This contains sketches for the devices you mention...
Verify your wiring and your code.
