ESP32 Bluetooth communcation with 2 Slaves
Hello everyone! I have a programming question. I am currently working on this project where I have several ESP32 talking to each other over Bleutooth.
My problem:
When I connect one Master and one Slave the code works, but when I try to connect more then 1 Slave it doesn´t work anymore.
The way I tried to connect the second Slave was by adding another BluetoothSerial stream for Slave 2. Like this:
BluetoothSerial Slave1;
BluetoothSerial Slave2;
//Setup bluetooth
String name1 = "ESP32_Pod_2"; //                  <------- set this to be the name of the other ESP32!!!!!!!!!
bool connect_1;
String name2 = "ESP32_Pod_3"; //                  <------- set this to be the name of the other ESP32!!!!!!!!!
bool connect_2;
I am not sure if this is the correct way, beacuse I can´t find any documentation on how to connect more than 1 Slave to a master over Bluetooth.
My code:
In the following code you will see how I tried to connect the Master with 2 Slaves.
So basically what the code does is that the Master sends a number to each Slave, the Slaves check, if the number is their ID-number and act based on that. The master waits until one of the Slaves returns a value to him.
Master code:
#include <Arduino.h>
#include "BluetoothSerial.h"
#define PIN 26
//Setup bluetooth
bool connect_1;
bool connect_2;
//Identification for POD Number
const int pod_ID = 1;
//data to send
int pod;
// data to recieve
int reactiontime = 0;
  //Setup BLuetooth
  Slave1.begin("ESP32_Pod_1", true);
  Slave2.begin("ESP32_Pod_1", true);
  connect_1 = Slave1.connect("ESP32_Pod_2");
  connect_2 = Slave2.connect("ESP32_Pod_3");
  if(connect_1 && connect_2)
    Serial.println("Connected Succesfully!");
    while(!Slave1.connected(10000))
      Serial.println("Failed to connect to POD 1");
    while(!Slave2.connected(10000))
      Serial.println("Failed to connect to POD 2");
  pod = random(1,4);
  //Send POD to all slaves
  Slave1.write(pod);
  Slave2.write(pod);
  if(pod == pod_ID)
    Serial.println("");
    Serial.println("-----------------------------------");
    Serial.println("Master");
    Serial.println("");
    //Wait for Slave1 or Slave2
    while(!(Slave1.available()) || !(Slave2.available()))
      //do nothing
    //Read whatever Slave is there
    if(Slave1.available())
      Serial.println("");
      reactiontime = Slave1.read();
      Serial.println(reactiontime);
      Serial.println("Slave 1");
      Serial.println("");
    else if(Slave2.available())
      Serial.println("");
      reactiontime = Slave2.read();
      Serial.println("Slave 2");
      Serial.println("");
Slave 1 code:
#define PIN 26
const int pod_ID = 2;
//data to send
// data to recieve
int pod;
  Slave1.begin("ESP32_Pod_2");
  //wait for command
  while(!(Slave1.available()))
    //do nothing
  //read the command
  pod = Slave1.read();
  Serial.println(pod);
  if(pod == pod_ID)
    delay(random(1,3001));
    //send data
    reactiontime=random(4000,5001);
    Slave1.write(reactiontime);
    //do nothing
Slave 2 code:
#define PIN 26
const int pod_ID = 3;
//data to send
// data to recieve
int pod;
  Slave2.begin("ESP32_Pod_3");
  //wait for command
  while(!(Slave2.available()))
    //do nothing
  //read the command
  pod = Slave2.read();
  if(pod == pod_ID)
    //send data
    reactiontime = random(9000,10001);
    Slave2.write(reactiontime);
    //do nothing
I hope someone can help me fix my problem here. Any help would be much appreciated!
Best Regards, Markus
2 connections with the same name ?
Is that right ?
I think it is correct this way. The master device in this case is called "ESP32_POD_1" and I connect it to each bluetooth serial stream.
I tried it with different names just to be sure, but unfortunately it didn´t work.
Thanks for the help though!
Classic Bluetooth is meant for 1:1 communication and you can not connect to multiple devices. You may be able to connect and disconnect from two different slaves.
Alternatively, I think you can switch to BLE and deal with multiple services and characteristics.
I second that...
Here are some links to BLE information regarding several clients with ESP32:
https://docs.espressif.com/projects/espressif-esp-faq/en/latest/software-framework/ble-bt.html
and
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/bluetooth/esp-ble-mesh.html
However, I think switching to WiFi TCP or UDP connection would be much easier ...
Ok thank you guys very much!
I solved it now by connecting and disconnecting each slave every time. It might not be the best way to do it but it works for now. :grin:
Thanks for all the suggestions, I will definitly look into BLE to see how I could solve it better.
If anyone interested this is what the master code looks like now:
#define PIN 26
BluetoothSerial Slave;
//Setup bluetooth
bool connect_1;
bool connect_2;
//data to send
int pod;
// data to recieve
  //Setup Bluetooth
  Slave.begin("ESP32_Pod_1", true);
  pod = random(1,4);
  if(pod==2)
    connect_1 = Slave.connect("ESP32_Pod_2");
    while(!Slave.connected(5000))
    Slave.write(pod);
    //Wait for Slave1
    while(!(Slave.available()))
      //do nothing
    Serial.println("");
    reactiontime = Slave.read();
    Serial.println("");
    connect_1 = Slave.disconnect();
  else if(pod==3)
    connect_2 = Slave.connect("ESP32_Pod_3");
      Serial.println("Failed to connect to POD 3");
    Slave.write(pod);
    //Wait for Slave2
      //do nothing
    Serial.println("");
    Serial.println("");
    connect_2 = Slave.disconnect();
  else if(pod == pod_ID)
    Serial.println("");
    Serial.println("");
