Habe einen ESP32-DMX Library heruintergeladen und nutze ein ESP32vn iot UNO Board aber es scheitert schon beim Beispielscetch. (2 andere Librarys auch ohne erfolg)
Hier der CODE:
#include <dmx.h>
int readcycle = 0;
DMX::Initialize(input);
if(millis() - readcycle > 1000)
readcycle = millis();
Serial.print(readcycle);
if(DMX::IsHealthy())
Serial.print(": ok - ");
Serial.print(": fail - ");
Serial.print(DMX::Read(1));
Serial.print(" - ");
Serial.print(DMX::Read(110));
Serial.println(DMX::Read(256));
Hier die Fehlermeldung:
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp: In static member function 'static void DMX::Initialize(DMXDirection)':
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:61:5: warning: missing initializer for member 'uart_config_t::rx_flow_ctrl_thresh' [-Wmissing-field-initializers]
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:61:5: warning: missing initializer for member 'uart_config_t::<anonymous>' [-Wmissing-field-initializers]
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:21:33: error: 'GPIO_NUM_17' was not declared in this scope
#define DMX_SERIAL_OUTPUT_PIN GPIO_NUM_17 // pin for dmx tx
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:66:32: note: in expansion of macro 'DMX_SERIAL_OUTPUT_PIN'
uart_set_pin(DMX_UART_NUM, DMX_SERIAL_OUTPUT_PIN, DMX_SERIAL_INPUT_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:21:33: note: suggested alternative: 'UART_NUM_1'
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:20:33: error: 'GPIO_NUM_16' was not declared in this scope
#define DMX_SERIAL_INPUT_PIN GPIO_NUM_16 // pin for dmx rx
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:66:55: note: in expansion of macro 'DMX_SERIAL_INPUT_PIN'
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:20:33: note: suggested alternative: 'UART_NUM_1'
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:22:33: error: 'GPIO_NUM_4' was not declared in this scope
#define DMX_SERIAL_IO_PIN GPIO_NUM_4 // pin for dmx rx/tx change
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:75:26: note: in expansion of macro 'DMX_SERIAL_IO_PIN'
gpio_pad_select_gpio(DMX_SERIAL_IO_PIN);
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:22:33: note: suggested alternative: 'UART_NUM_0'
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:75:5: error: 'gpio_pad_select_gpio' was not declared in this scope
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:76:43: error: 'GPIO_MODE_OUTPUT' was not declared in this scope
gpio_set_direction(DMX_SERIAL_IO_PIN, GPIO_MODE_OUTPUT);
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:76:43: note: suggested alternative: 'DMX_OUTPUT'
DMX_OUTPUT
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:76:5: error: 'gpio_set_direction' was not declared in this scope
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:76:5: note: suggested alternative: 'direction'
direction
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:81:9: error: 'gpio_set_level' was not declared in this scope
gpio_set_level(DMX_SERIAL_IO_PIN, 1);
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:81:9: note: suggested alternative: '_xtos_set_intlevel'
_xtos_set_intlevel
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:89:9: error: 'gpio_set_level' was not declared in this scope
gpio_set_level(DMX_SERIAL_IO_PIN, 0);
/home/arbeit/Arduino/libraries/ESP32-DMX-master/src/dmx.cpp:89:9: note: suggested alternative: '_xtos_set_intlevel'
_xtos_set_intlevel
Bibliothek ESP32-DMX-RX in Version 0.1.0 im Ordner: /media/DATEIEN/Eigene Dateien/Arduino/libraries/ESP32-DMX-master wird verwendet
exit status 1
Compilation error: exit status 1
Von wo?
Das erste is ne Warnung, das da der Abschluss fehtl. Das geht noch durch, aber den Rest muss man schaun...
Sorry das ich den Link zum Download vergessen habe!!!
agmue
April 21, 2023, 10:02pm
5
Bei mir werden auch viele Fehler angezeigt. Da das Programm in #1 ein Beispiel aus der Bibliothek ist, scheint es mit der Bibliothek nicht zum Besten bestellt zu sein. Dürfte es auch eine andere Bibliothek sein?
Ich mache nichts mit DMX, daher kann ich Dir leider keine empfehlen. Aber das Beispiel DMXWrite der Bibliothek esp_dmx Version 2.0.2 läuft ohne Beanstandung durch den Compiler.
Mit deiner version bekomme ich diese fehlermeldung:
In file included from /tmp/.arduinoIDE-unsaved2023323-153060-1eb6g03.rsk8/sketch_apr23a/sketch_apr23a.ino:16:
/tmp/.arduinoIDE-unsaved2023323-153060-1eb6g03.rsk8/sketch_apr23a/sketch_apr23a.ino: In function 'void setup()':
/home/arbeit/Arduino/libraries/esp_dmx-2.0.1/src/esp_dmx.h:29:69: warning: missing initializer for member 'dmx_config_t::source_clk' [-Wmissing-field-initializers]
{ .baud_rate = DMX_TYP_BAUD_RATE, .break_num = 44, .idle_num = 3, }
/tmp/.arduinoIDE-unsaved2023323-153060-1eb6g03.rsk8/sketch_apr23a/sketch_apr23a.ino:63:28: note: in expansion of macro 'DMX_DEFAULT_CONFIG'
dmx_config_t dmxConfig = DMX_DEFAULT_CONFIG;
und ändere ich den dmxport auf alles auser 1 gibts einen Dauerreset
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13192
load:0x40080400,len:3028
entry 0x400805e4
E (10) dmx: dmx_param_config(410): dmx_num error
E (11) dmx: dmx_set_pin(396): dmx_num error
E (11) dmx: dmx_driver_install(114): dmx_num error
assert failed: xQueueReceive queue.c:1382 (( pxQueue ))
Backtrace: 0x40083691:0x3ffb20a0 0x40088269:0x3ffb20c0 0x4008d5bd:0x3ffb20e0 0x40088e7a:0x3ffb2210 0x400d13dd:0x3ffb2250 0x400d2e79:0x3ffb2290
ELF file SHA256: 32ca25a2e86d64e7
Rebooting...
agmue
April 23, 2023, 3:31pm
7
Ich verwende Win10, IDE 1.8.19, ESP32 Core 2.0.6, ESP32 Dev Module, wie sieht es bei Dir aus?
ubuntu linux ide 2.0.0 ESP32 Core 2.0.8 esp32 von espressif systems
Hast du mich vergessen???
agmue
April 25, 2023, 12:40pm
11
rumpl-x1:
ide 2.0.0
Vermutlich kein Glücksgriff, versuche mal eine ältere.
hatte noch die 1.8.10 aufm Rechner gleicher effekt.
hab mir deien version geholt, es hagelt fehlermeldungen:
In file included from /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/hal/include/hal/dac_types.h:4:0,
from /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/driver/include/driver/dac_common.h:16,
from /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/cores/esp32/esp32-hal-dac.c:22:
/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/hal/include/hal/adc_types.h:90:27: error: expected ',' or '}' before '__attribute__'
ADC_DIGI_FORMAT_12BIT __attribute__((deprecated)), /*!<ADC to DMA data format, [15:12]-channel, [11: 0]-12 bits ADC data (`adc_digi_output_data_t`). Note: For single convert mode. */
cc1: warning: unrecognized command line option '-Wno-frame-address'
In file included from /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/driver/include/driver/adc.h:14:0,
from /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/cores/esp32/esp32-hal-adc.c:16:
/home/arbeit/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.4\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/newlib/platform_include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/freertos/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/freertos/port/xtensa/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/freertos/include/esp_additions -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hw_support/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hw_support/include/soc -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/heap/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/log/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/lwip/include/apps -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/lwip/include/apps/sntp -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/lwip/lwip/src/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/lwip/port/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/soc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/soc/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/soc/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/hal/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/hal/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/hal/platform_port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_rom/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_rom/include/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_rom/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_system/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_system/port/soc -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_system/port/public_compat -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/xtensa/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/xtensa/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/driver/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/driver/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_pm/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_ringbuf/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/efuse/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/efuse/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/vfs/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_wifi/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_event/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_netif/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_eth/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/tcpip_adapter/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_phy/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_phy/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_ipc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/app_trace/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_timer/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/mbedtls/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/app_update/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/spi_flash/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bootloader_support/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/nvs_flash/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/pthread/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_gdbstub/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espcoredump/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/wpa_supplicant/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/wpa_supplicant/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/ieee802154/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/console -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/asio/asio/asio/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/asio/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/common/osi/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/include/esp32/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/common/api/include/api -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/cbor/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/unity/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/unity/unity/src -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/cmock/CMock/src -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/coap/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/coap/libcoap/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/nghttp/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-tls -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_adc_cal/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_hid/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/tcp_transport/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_http_client/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_http_server/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_https_ota/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_https_server/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_lcd/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_lcd/interface -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/protocomm/include/common -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/protocomm/include/security -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/protocomm/include/transports -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/mdns/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_local_ctrl/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/sdmmc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_serial_slave_link/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_websocket_client/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/expat/expat/expat/lib -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/expat/port/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/wear_levelling/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/fatfs/diskio -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/fatfs/vfs -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/fatfs/src -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/idf_test/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/idf_test/include/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/jsmn/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/json/cJSON -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/libsodium/port_include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/openssl/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/perfmon/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/spiffs/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/ulp/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/wifi_provisioning/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/rmaker_common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_diagnostics/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/rtc_store/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_insights/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/json_parser/upstream/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/json_parser/upstream -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/json_generator/upstream -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_schedule/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_rainmaker/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/gpio_button/button/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/qrcode/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/ws2812_led -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp_littlefs/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/tool -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/typedef -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/image -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/math -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/nn -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/layer -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/detect -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-sr/src/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp-sr/include/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp32-camera/driver/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/esp32-camera/conversions/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/include/fb_gfx/include -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/tools/sdk/esp32/dio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c -Wall -Werror=all -Wextra -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_esp32vn_iot_uno -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"esp32vn_iot_uno\"" "-DARDUINO_VARIANT=\"esp32vn-iot-uno\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @/tmp/arduino_build_521417/build_opt.h -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/cores/esp32 -I/home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/variants/esp32vn-iot-uno /home/arbeit/.arduino15/packages/esp32/hardware/esp32/2.0.8/cores/esp32/libb64/cdecode.c -o /tmp/arduino_build_521417/core/libb64/cdecode.c.o
Bibliothek esp_dmx-2.0.2 in Version 2.0.2 im Ordner: /home/arbeit/Arduino/libraries/esp_dmx-2.0.2 wird verwendet
exit status 1
Fehler beim Kompilieren für das Board ESP32vn IoT Uno.
Vorhergehender Fehler behoben (zusätzliches Install-Script musste ausgeführt werden) die IDE läuft aber der Fehler mit der DXX-Library bleibt
Habe jetzt Version 2.1.0 und 1.8.19 am laufen aber der Fehler bleibt (die Arduino Linuxversionen sind parallel Installierbar)
agmue
April 25, 2023, 3:28pm
16
Wenn Du mir nicht antwortest, dann sehe ich nicht, daß Du mir antwortest.
rumpl-x1:
ESP32vn IoT Uno.
Ich verwende ESP32 Dev Module, könnte einen Unterschied machen.
habe doch geantwortet!!!
Hast du diese fehlermeldung auch und wenn ja was bedeutet sie????
In file included from /media/DATEIEN/Eigene Dateien/Arduino/DMX-RECIVED-DMX/DMX-RECIVED-DMX.ino:16:
/media/DATEIEN/Eigene Dateien/Arduino/DMX-RECIVED-DMX/DMX-RECIVED-DMX.ino: In function 'void setup()':
/home/arbeit/Arduino/libraries/esp_dmx-2.0.2/src/esp_dmx.h:29:69: warning: missing initializer for member 'dmx_config_t::source_clk' [-Wmissing-field-initializers]
/media/DATEIEN/Eigene Dateien/Arduino/DMX-RECIVED-DMX/DMX-RECIVED-DMX.ino:60:28: note: in expansion of macro 'DMX_DEFAULT_CONFIG'
Habe das esp32 dev modul ausgewählt und es läuft auch durch mit obiger fehlermeldung und wie gehabt.
agmue
April 25, 2023, 5:12pm
19
rumpl-x1:
Inhaltlich ja, aber vermutlich hast Du nicht auf den Antwortenknopf geklickt, denn sonst hätte ich rechts oben eine Markierung gesehen.
Sowas kann ich auch mal übersehen, aber auch in meiner Historie tauchst Du nicht auf. Unglücklicherweise hat der blaue Rand, der Deinen eigenen Beitrag markiert, dieselbe Färbung wie der blaue Kreis von Deinem Avatarbild. Das könntest Du ändern, das Bild kannst Du tauschen, so wie meine gelb-blauen LEDs.
Ja, ist aber nur eine Warnung und eine Anmerkung, Du erhälst dennoch ein lauffähiges Programm, das sagt der weiße Text.
Eventuell sind die Meldungen in der Beta-Version beseitigt.
system
Closed
October 22, 2023, 5:12pm
20
