Here's my problem, i have plans on making a DMX Fixture with ESP32, i've got the ESP and the RS485 to TTL converter, and the library. I have a problem with the library since it throws me a bunch of errors when i try to compile even the examples of it. (errors down below)
Library: GitHub - yoann-darche/ESP32-DMX: Example code for receiving and transmitting DMX512 with ESP32 and RS485 transceiver IC like MAX485 or isolated ADM2486
Keep in mind this library version is a reviewed one i found from this guy from youtube, but the errors are quite the same as compared to the original library: GitHub - luksal/ESP32-DMX: Example code for receiving and transmitting DMX512 with ESP32 and RS485 transceiver IC like MAX485 or isolated ADM2486
ESP Model: ESP-WROOM-32
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp: In static member function 'static void DMX::Initialize(DMXDirection)':
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:21:33: error: 'GPIO_NUM_17' was not declared in this scope
#define DMX_SERIAL_OUTPUT_PIN GPIO_NUM_17 // pin for dmx tx
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:66:32: note: in expansion of macro 'DMX_SERIAL_OUTPUT_PIN'
uart_set_pin(DMX_UART_NUM, DMX_SERIAL_OUTPUT_PIN, DMX_SERIAL_INPUT_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:21:33: note: suggested alternative: 'UART_NUM_1'
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:20:33: error: 'GPIO_NUM_16' was not declared in this scope
#define DMX_SERIAL_INPUT_PIN GPIO_NUM_16 // pin for dmx rx
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:66:55: note: in expansion of macro 'DMX_SERIAL_INPUT_PIN'
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:20:33: note: suggested alternative: 'UART_NUM_1'
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:22:33: error: 'GPIO_NUM_4' was not declared in this scope
#define DMX_SERIAL_IO_PIN GPIO_NUM_4 // pin for dmx rx/tx change
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:75:26: note: in expansion of macro 'DMX_SERIAL_IO_PIN'
gpio_pad_select_gpio(DMX_SERIAL_IO_PIN);
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:22:33: note: suggested alternative: 'UART_NUM_0'
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:75:5: error: 'gpio_pad_select_gpio' was not declared in this scope
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:76:43: error: 'GPIO_MODE_OUTPUT' was not declared in this scope
gpio_set_direction(DMX_SERIAL_IO_PIN, GPIO_MODE_OUTPUT);
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:76:43: note: suggested alternative: 'DMX_OUTPUT'
DMX_OUTPUT
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:76:5: error: 'gpio_set_direction' was not declared in this scope
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:76:5: note: suggested alternative: 'direction'
direction
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:81:9: error: 'gpio_set_level' was not declared in this scope
gpio_set_level(DMX_SERIAL_IO_PIN, 1);
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:81:9: note: suggested alternative: '_xtos_set_intlevel'
_xtos_set_intlevel
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:89:9: error: 'gpio_set_level' was not declared in this scope
gpio_set_level(DMX_SERIAL_IO_PIN, 0);
c:\Users\***\Documents\Arduino\libraries\ESP32-DMX-RX\src\dmx.cpp:89:9: note: suggested alternative: '_xtos_set_intlevel'
_xtos_set_intlevel
exit status 1
Compilation error: exit status 1
If nothing works i was thinking about using an Arduino Uno (or nano) (as master, dmx receiver) to send dmx values to variables on ESP32 (as slave, the one who manages PWM outputs), since there IS a perfectly working and straightforward library, which works for me on an Uno, but not on ESP32 since this one works only on AVR micros: https://github.com/mathertel/DMXSerial/blob/master/src/DMXSerial.h
Any help would be REALLY appreciated, thank you.
