ESP32 -C3-DevKitM-1-V1.0 VS ESP32_DevkITc_v4
I have a ESP32-C3_KitM1-v1.0 (SPARKFUN)with a SD card usinf SPI on pins CS=7,MOSI =6, MISO=5, CLK=4.
I am running the following code and it compiles and runs;
/*  6/15/2023 Created by combining ESP32_Down_Up_SD_WJL with DATALOGGER_H1_PROMATIC_2
 6/14/2023 Downloaded ESP32_SD from https://drive.google.com/drive/folders/1CN8U-VyOMm5EoAAntuFtYXbBFIAb3Kog
 SPI PINS = mosi=6,miso=5,sck=4,cs=x
 I2C PINS = scl=  ,sda=
#include <WiFi.h>              //Built-in
#include <ESP32WebServer.h>    //https://github.com/Pedroalbuquerque/ESP32WebServer download and place in your Libraries folder
#include <ESPmDNS.h>
#include "CSS.h" //Includes headers of the web and de style file
#include <SD.h>
#include <SPI.h>     //MOSI PIN=6,MISO PIN=5,SCK PIN=4, SS(CS) PIN=7(PIN 5 FOR SPARKFUN)
#include <Wire.h>   //added for RTC i2c
//#define I2C_SDA 2  //added for RTC i2c
//#define I2C_SCL 3  //added for RTC i2c
//from DATALOGGER_H1_PROMATIC_2 thru lines 23
#include "RTClib.h"
RTC_PCF8523 rtc;   //original file used RTC_DS1307 rtc
int targetPin = 3;
int target;
int count;
int counter;
int counterPin = 1;
int reset = 0;
ESP32WebServer server(80);
#define servername "MCserver" //Define the name to your server...
#define SD_pin 7 //PIN 7 FOR ESP323 S3 DEV, PIN 5 FOR SPARKFUN ESP32 Thing Plus C ``````````
  bool   SD_present = false; //Controls if the SD card is present or not
/*********  SETUP  **********/
void setup(void)
  Wire.begin();  //added for RTC i2c
//from DATALOGGER_H1_PROMATIC_2 thru lines 64
  pinMode(targetPin,INPUT);
  pinMode(counterPin,INPUT);
  Serial.println("BOOTING");
  if (! rtc.begin())
      Serial.println("Couldn't find RTC");
      Serial.flush();
      while (1) delay(10);
  if (! rtc.isrunning())
    Serial.println("RTC is NOT running, let's set the time!");
    // When time needs to be set on a new device, or after a power loss, the
    // following line sets the RTC to the date & time this sketch was compiled
    //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2023, 2, 19, 19, 0, 0));
  // When time needs to be re-set on a previously configured device, the
  // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  // rtc.adjust(DateTime(2023, 4, 11, 8, 1, 0));
  WiFi.softAP("MyCircuits", "12345678"); //Network and password for the access point genereted by ESP32
  //Set your preferred server name, if you use "mcserver" the address would be http://mcserver.local/
  if (!MDNS.begin(servername))
    Serial.println(F("Error setting up MDNS responder!"));
    ESP.restart();
  Serial.print(F("Initializing SD card..."));
  //see if the card is present and can be initialised.
  //Note: Using the ESP32 and SD_Card readers requires a 1K to 4K7 pull-up to 3v3 on the MISO line, otherwise may not work
  if (!SD.begin(SD_pin))
    Serial.println(F("Card failed or not present, no SD Card data logging possible..."));
    SD_present = false;
    Serial.println(F("Card initialised... file access enabled..."));
    SD_present = true;
  /*********  Server Commands  **********/
  server.on("/",         SD_dir);
  server.on("/upload",   File_Upload);
  server.on("/fupload",  HTTP_POST,[](){ server.send(200);}, handleFileUpload);
  server.begin();
  Serial.println("HTTP server started");
  Serial.println("FILE NAME = DATALOGGER_ESP32_PROMATIC");
/*********  LOOP  **********/
void loop(void)
  server.handleClient(); //Listen for client connections
  //from DATALOGGER_H1_PROMATIC_2 thru lines 177
  counter = digitalRead(counterPin);
  if (counter == HIGH)
    Serial.println("counter == HIGH");
    count = 0;
  target = digitalRead(targetPin);
  if (target == HIGH && reset == 0)
    reset = 1;
    Serial.print("RESET = ");
    Serial.println(reset);
  if (target == LOW  && reset == 0)
    return;
  if (target == LOW)
      Serial.println("target == LOW");
      DateTime now = rtc.now();
      count = count + 1;
      Serial.print("Count = ");
      Serial.println(count);
      Serial.print(now.month(), DEC);
      Serial.print('-');
      Serial.print(now.day(), DEC);
      Serial.print('-');
      Serial.print(now.year(), DEC);
      Serial.print(';');
      Serial.print(now.hour(), DEC);
      Serial.print('-');
      Serial.print(now.minute(), DEC);
      Serial.print('-');
      Serial.println(now.second(), DEC);
      Serial.println("opening data fiLe");
      File dataFile = SD.open("HIGH_1.txt", FILE_WRITE);
      // if the file is available, write to it:
      if (dataFile)
          Serial.println(F("Writing to SD card"));
          dataFile.print(count);
          dataFile.print('-');
          dataFile.print(now.month(), DEC);
          dataFile.print(now.day(), DEC);
          dataFile.print(now.year(), DEC);
          dataFile.print(now.hour(), DEC);
          dataFile.print(now.minute(), DEC);
          dataFile.print(now.second(), DEC);
          //dataFile.print(':');
          dataFile.print("\n");  //new line
          dataFile.close();
          delay(5000);
        // if the file isn't open, pop up an error:
          Serial.println("error opening HIGH_1.txt");
/*********  FUNCTIONS  **********/
//Initial page of the server web, list directory and give you the chance of deleting and uploading
void SD_dir()
  if (SD_present)
    //Action acording to post, dowload or delete, by MC 2022
    if (server.args() > 0 ) //Arguments were received, ignored if there are not arguments
      Serial.println(server.arg(0));
      String Order = server.arg(0);
      Serial.println(Order);
      if (Order.indexOf("download_")>=0)
        Order.remove(0,9);
        SD_file_download(Order);
      if ((server.arg(0)).indexOf("delete_")>=0)
        Order.remove(0,7);
        SD_file_delete(Order);
    File root = SD.open("/");
    if (root) {
      root.rewindDirectory();
      SendHTML_Header();
      webpage += F("<table align='center'>");
      webpage += F("<tr><th>Name/Type</th><th style='width:20%'>Type File/Dir</th><th>File Size</th></tr>");
      printDirectory("/",0);
      webpage += F("</table>");
      SendHTML_Content();
      root.close();
      SendHTML_Header();
      webpage += F("<h3>No Files Found</h3>");
    append_page_footer();
    SendHTML_Content();
    SendHTML_Stop();   //Stop is needed because no content length was sent
  } else ReportSDNotPresent();
//Upload a file to the SD
void File_Upload()
  append_page_header();
  webpage += F("<h3>Select File to Upload</h3>");
  webpage += F("<FORM action='/fupload' method='post' enctype='multipart/form-data'>");
  webpage += F("<input class='buttons' style='width:25%' type='file' name='fupload' id = 'fupload' value=''>");
  webpage += F("<button class='buttons' style='width:10%' type='submit'>Upload File</button><br><br>");
  webpage += F("<a href='/'>[Back]</a><br><br>");
  server.send(200, "text/html",webpage);
//Prints the directory, it is called in void SD_dir()
void printDirectory(const char * dirname, uint8_t levels)
  File root = SD.open(dirname);
  if(!root){
    return;
  if(!root.isDirectory()){
    return;
  File file = root.openNextFile();
  int i = 0;
  while(file){
    if (webpage.length() > 1000) {
      SendHTML_Content();
    if(file.isDirectory()){
      webpage += "<tr><td>"+String(file.isDirectory()?"Dir":"File")+"</td><td>"+String(file.name())+"</td><td></td></tr>";
      printDirectory(file.name(), levels-1);
      webpage += "<tr><td>"+String(file.name())+"</td>";
      webpage += "<td>"+String(file.isDirectory()?"Dir":"File")+"</td>";
      int bytes = file.size();
      String fsize = "";
      if (bytes < 1024)                     fsize = String(bytes)+" B";
      else if(bytes < (1024 * 1024))        fsize = String(bytes/1024.0,3)+" KB";
      else if(bytes < (1024 * 1024 * 1024)) fsize = String(bytes/1024.0/1024.0,3)+" MB";
      else                                  fsize = String(bytes/1024.0/1024.0/1024.0,3)+" GB";
      webpage += "<td>"+fsize+"</td>";
      webpage += "<td>";
      webpage += F("<FORM action='/' method='post'>");
      webpage += F("<button type='submit' name='download'");
      webpage += F("' value='"); webpage +="download_"+String(file.name()); webpage +=F("'>Download</button>");
      webpage += "</td>";
      webpage += "<td>";
      webpage += F("<button type='submit' name='delete'");
      webpage += F("' value='"); webpage +="delete_"+String(file.name()); webpage +=F("'>Delete</button>");
      webpage += "</td>";
      webpage += "</tr>";
    i++;
  file.close();
//Download a file from the SD, it is called in void SD_dir()
void SD_file_download(String filename)
  if (SD_present)
    File download = SD.open("/"+filename);
    if (download)
      server.sendHeader("Content-Type", "text/text");
      server.sendHeader("Content-Disposition", "attachment; filename="+filename);
      server.sendHeader("Connection", "close");
      server.streamFile(download, "application/octet-stream");
      download.close();
    } else ReportFileNotPresent("download");
//Handles the file upload a file to the SD
File UploadFile;
//Upload a new file to the Filing system
void handleFileUpload()
  HTTPUpload& uploadfile = server.upload(); //See https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266WebServer/srcv
                                            //For further information on 'status' structure, there are other reasons such as a failed transfer that could be used
  if(uploadfile.status == UPLOAD_FILE_START)
    String filename = uploadfile.filename;
    if(!filename.startsWith("/")) filename = "/"+filename;
    Serial.print("Upload File Name: "); Serial.println(filename);
    SD.remove(filename);                         //Remove a previous version, otherwise data is appended the file again
    UploadFile = SD.open(filename, FILE_WRITE);  //Open the file for writing in SD (create it, if doesn't exist)
    filename = String();
  else if (uploadfile.status == UPLOAD_FILE_WRITE)
    if(UploadFile) UploadFile.write(uploadfile.buf, uploadfile.currentSize); // Write the received bytes to the file
  else if (uploadfile.status == UPLOAD_FILE_END)
    if(UploadFile)          //If the file was successfully created
      UploadFile.close();   //Close the file again
      Serial.print("Upload Size: "); Serial.println(uploadfile.totalSize);
      webpage = "";
      webpage += F("<h3>File was successfully uploaded</h3>");
      webpage += F("<h2>Uploaded File Name: "); webpage += uploadfile.filename+"</h2>";
      webpage += F("<h2>File Size: "); webpage += file_size(uploadfile.totalSize) + "</h2><br><br>";
      server.send(200,"text/html",webpage);
      ReportCouldNotCreateFile("upload");
//Delete a file from the SD, it is called in void SD_dir()
void SD_file_delete(String filename)
  if (SD_present) {
    SendHTML_Header();
    File dataFile = SD.open("/"+filename, FILE_READ); //Now read data from SD Card
    if (dataFile)
      if (SD.remove("/"+filename)) {
        Serial.println(F("File deleted successfully"));
        webpage += "<h3>File '"+filename+"' has been erased</h3>";
        webpage += F("<h3>File was not deleted - error</h3>");
    } else ReportFileNotPresent("delete");
    SendHTML_Content();
    SendHTML_Stop();
//SendHTML_Header
void SendHTML_Header()
  server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate");
  server.sendHeader("Pragma", "no-cache");
  server.sendHeader("Expires", "-1");
  server.setContentLength(CONTENT_LENGTH_UNKNOWN);
  server.send(200, "text/html", ""); //Empty content inhibits Content-length header so we have to close the socket ourselves.
  server.sendContent(webpage);
  webpage = "";
//SendHTML_Content
void SendHTML_Content()
  webpage = "";
//SendHTML_Stop
void SendHTML_Stop()
  server.sendContent("");
  server.client().stop(); //Stop is needed because no content length was sent
//ReportSDNotPresent
void ReportSDNotPresent()
  SendHTML_Header();
  webpage += F("<h3>No SD Card present</h3>");
  SendHTML_Content();
  SendHTML_Stop();
//ReportFileNotPresent
void ReportFileNotPresent(String target)
  SendHTML_Header();
  webpage += F("<h3>File does not exist</h3>");
  webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>";
  SendHTML_Content();
  SendHTML_Stop();
//ReportCouldNotCreateFile
void ReportCouldNotCreateFile(String target)
  SendHTML_Header();
  webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>");
  SendHTML_Content();
  SendHTML_Stop();
//File size conversion
String file_size(int bytes)
  String fsize = "";
  else if(bytes < (1024*1024))      fsize = String(bytes/1024.0,3)+" KB";
  else if(bytes < (1024*1024*1024)) fsize = String(bytes/1024.0/1024.0,3)+" MB";
  return fsize;
}type or paste code here
I changed the ESP card to a ESP32_DevKitc_V4(MOUSER par# 356-ESP32-DEVKITC32E) with SPI pins CS=5, MOSI=23,MISO=19,SCK=18. and the module repeatedly reboots on startup with the following error;
20:35:16.399 -> ELF file SHA256: b700041a655d2db4
20:35:16.399 ->
20:35:16.399 -> E (318) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
20:35:16.399 -> Rebooting...
20:35:16.399 -> ets Jul 29 2019 12:21:46
20:35:16.399 ->
20:35:16.399 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
20:35:16.399 -> configsip: 0, SPIWP:0xee
20:35:16.399 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
20:35:16.438 -> mode:DIO, clock div:1
20:35:16.438 -> load:0x3fff0030,len:1344
20:35:16.438 -> load:0x40078000,len:13924
20:35:16.438 -> ho 0 tail 12 room 4
20:35:16.438 -> load:0x40080400,len:3600
20:35:16.438 -> entry 0x400805f0
20:35:16.692 -> E (295) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed.
20:35:16.692 ->
20:35:16.692 -> assert failed: do_core_init startup.c:326 (flash_ret == ESP_OK)
20:35:16.727 ->
20:35:16.727 ->
20:35:16.727 -> Backtrace: 0x40083b25:0x3ffe3aa0 0x4008d155:0x3ffe3ac0 0x40092eb1:0x3ffe3ae0 0x400e8376:0x3ffe3c10 0x4008322a:0x3ffe3c40 0x40079276:0x3ffe3c90 |<-CORRUPTED.
I am obviously missing something when I switch modules.
Any help appreciated.
Thanks
Bill
I changed the Flash Mode from "QIO" to "DIO"(under Tools Tab band now I get the folowing reboot message:
21:24:50.780 -> rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 21:24:50.780 -> configsip: 0, SPIWP:0xee 21:24:50.780 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 21:24:50.780 -> mode:DIO, clock div:1 21:24:50.780 -> load:0x3fff0030,len:1184 21:24:50.780 -> load:0x40078000,len:13220 21:24:50.780 -> ho 0 tail 12 room 4 21:24:50.780 -> load:0x40080400,len:3028 21:24:50.780 -> entry 0x400805e4 21:24:51.857 -> ets Jul 29 2019 12:21:46!
help appreciated.
Bill
(i am new to this community and I saw the same thing happen to me thought this might help)
i had the same bootup message when i added a pin to the code that couldn't be used for IO operations.
Check the pinout diagram to see if you used one!
Changed targetPin from 3 to 17
Changed counterPin from 1 to 17
Changed SD PIN to 5(it was 7 for some reason)
Seems to work now
Thanks for help
