Esp32-s3 sdcard
Hello
I fiddle with my ESP32-S3 board and get my SD Card not to work.
 * pin 1 - not used          |  Micro SD card     |
 * pin 2 - CS (SS)           |                   /
 * pin 3 - DI (MOSI)         |                  |__
 * pin 4 - VDD (3.3V)        |                    |
 * pin 5 - SCK (SCLK)        | 8 7 6 5 4 3 2 1   /
 * pin 6 - VSS (GND)         | ▄ ▄ ▄ ▄ ▄ ▄ ▄ ▄  /
 * pin 7 - DO (MISO)         | ▀ ▀ █ ▀ █ ▀ ▀ ▀ |
 * pin 8 - not used          |_________________|
 * Connections for     ║   ║   ╔═══╩═║═║═══╗   ║  ║    ║
 * full-sized          ║   ║   ║   ╔═╝ ║   ║   ║  ║    ║
 * SD card             ║   ║   ║   ║   ║   ║   ║  ║    ║
 * Pin name         |  -  DO  VSS SCK VDD VSS DI CS    -  |
 * SD pin number    |  8   7   6   5   4   3   2   1   9 /
 *                  |__▍___▊___█___█___█___█___█___█___/
 * Note:  The SPI pins can be manually configured by using `SPI.begin(sck, miso, mosi, cs).`
 *        Alternatively, you can change the CS pin and use the other default settings by using `SD.begin(cs)`.
 * | SPI Pin Name | ESP8266 | ESP32 | ESP32-S2 | ESP32-C3 | ESP32-S3 |
 * | CS (SS)      | GPIO15  | GPIO5 | GPIO5    | GPIO13   | GPIO13   |
 * | DI (MOSI)    | GPIO13  | GPIO23| GPIO24   | GPIO14   | GPIO14   |
 * | DO (MISO)    | GPIO12  | GPIO19| GPIO25   | GPIO15   | GPIO15   |
 * | SCK (SCLK)   | GPIO14  | GPIO18| GPIO19   | GPIO16   | GPIO16   |
 * For more info see file README.md in this library or on URL:
 * https://github.com/espressif/arduino-esp32/tree/master/libraries/SD
#include "FS.h"
#include "SD.h"
#include "SPI.h"
Uncomment and set up if you want to use custom pins for the SPI communication
#define REASSIGN_PINS
int sck = -1;
int miso = -1;
int mosi = -1;
int cs = -1;
void TestLed(int Value);
void listDir(fs::FS &fs, const char * dirname, uint8_t levels);
void createDir(fs::FS &fs, const char * path);
void removeDir(fs::FS &fs, const char * path);
void readFile(fs::FS &fs, const char * path);
void writeFile(fs::FS &fs, const char * path, const char * message);
void appendFile(fs::FS &fs, const char * path, const char * message);
void renameFile(fs::FS &fs, const char * path1, const char * path2);
void deleteFile(fs::FS &fs, const char * path);
void testFileIO(fs::FS &fs, const char * path);
bool testSD();
 * Connect the SD card to the following pins:
 * SD Card | ESP32
 *    D2       -
 *    D3       SS
 *    CMD      MOSI
 *    VSS      GND
 *    VDD      3.3V
 *    CLK      SCK
 *    VSS      GND
 *    D0       MISO
 *    D1       -
#if CONFIG_IDF_TARGET_ESP32
#define SD_SCK  GPIO_NUM_14
#define SD_MISO GPIO_NUM_12
#define SD_MOSI GPIO_NUM_13
#define SD_SS   GPIO_NUM_15
#elif CONFIG_IDF_TARGET_ESP32S3
#define SD_SS   GPIO_NUM_5
#else
#error Board not found!
#endif
//SPIClass * hspi = NULL;
SPIClass fspi = SPIClass(HSPI);
#define SD_SPI_FREQ 1000000
//#define SD_SPI_FREQ 4000000
//#define SD_SPI_FREQ 25000000
void setup(){
    delay(2000);
    //hspi = new SPIClass(HSPI);
    //hspi->begin(SD_SCK, SD_MISO, SD_MOSI, SD_SS);
    fspi.begin(SD_SCK, SD_MISO, SD_MOSI, SD_SS);
    Serial.printf("%d-%d-%d-%d ",MISO, MOSI, SCK, SS );
    pinMode(MISO, OUTPUT);
      pinMode(MOSI, OUTPUT);
        pinMode(SCK, OUTPUT);
          pinMode(SS, OUTPUT);
for (int i= 0;i<200; i++)
   TestLed(7000);
    if(!SD.begin(SD_SS, fspi, SD_SPI_FREQ)){
        Serial.println("Card Mount Failed");
        return;
    testSD();
    SD.end();
void loop(){
  bool ok;
  ok = testSD();
  if (ok) {
    Serial.println("OK");
    Serial.println("FAIL");
  delay(5000);
     digitalWrite(MISO, HIGH);
     Serial.printf("MISO: %d \n", MISO);
     delay(Value);
     digitalWrite(MISO, LOW);
     digitalWrite(MOSI, HIGH);
     Serial.printf("MOSI: %d \n", MOSI);
     delay(Value);
     digitalWrite(MOSI, LOW);
     digitalWrite(SS, HIGH);
     Serial.printf("SS: %d \n", SS);
     delay(Value);
     digitalWrite(SS, LOW);
     digitalWrite(SCK, HIGH);
     Serial.printf("SCK: %d \n", SCK);
     delay(Value);
     digitalWrite(SCK, LOW);
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
    Serial.printf("Listing directory: %s\r\n", dirname);
    File root = fs.open(dirname);
    if(!root){
        Serial.println("Failed to open directory");
        return;
    if(!root.isDirectory()){
        Serial.println("Not a directory");
        return;
    File file = root.openNextFile();
    while(file){
        if(file.isDirectory()){
            Serial.print("  DIR : ");
            Serial.println(file.name());
            if(levels){
                listDir(fs, file.path(), levels -1);
//                listDir(fs, file.name(), levels -1);
            Serial.print("  FILE: ");
            Serial.print(file.name());
            Serial.print("  SIZE: ");
            Serial.println(file.size());
void createDir(fs::FS &fs, const char * path){
    Serial.printf("Creating Dir: %s\r\n", path);
    if(fs.mkdir(path)){
        Serial.println("Dir created");
        Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path){
    Serial.printf("Removing Dir: %s\r\n", path);
    if(fs.rmdir(path)){
        Serial.println("Dir removed");
        Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path){
    Serial.printf("Reading file: %s\r\n", path);
    File file = fs.open(path);
    if(!file){
        Serial.println("Failed to open file for reading");
        return;
    Serial.print("Read from file: ");
    while(file.available()){
        Serial.write(file.read());
    file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Writing file: %s\r\n", path);
    File file = fs.open(path, FILE_WRITE);
    if(!file){
        Serial.println("Failed to open file for writing");
        return;
    if(file.print(message)){
        Serial.println("File written");
        Serial.println("Write failed");
    file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Appending to file: %s\r\n", path);
    File file = fs.open(path, FILE_APPEND);
    if(!file){
        Serial.println("Failed to open file for appending");
        return;
        Serial.println("Message appended");
        Serial.println("Append failed");
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
    Serial.printf("Renaming file %s to %s\r\n", path1, path2);
    if (fs.rename(path1, path2)) {
        Serial.println("File renamed");
        Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char * path){
    Serial.printf("Deleting file: %s\r\n", path);
    if(fs.remove(path)){
        Serial.println("File deleted");
        Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char * path){
    static uint8_t buf[512];
    size_t len = 0;
    uint32_t start = millis();
    uint32_t end = start;
    if(file){
        len = file.size();
        size_t flen = len;
        start = millis();
        while(len){
            size_t toRead = len;
            if(toRead > 512){
                toRead = 512;
            file.read(buf, toRead);
            len -= toRead;
        end = millis() - start;
        Serial.printf("%u bytes read for %u ms\r\n", flen, end);
        file.close();
    if(!file){
        return;
    size_t i;
    start = millis();
    for(i=0; i<2048; i++){
        file.write(buf, 512);
    Serial.printf("%u bytes written for %u ms\r\n", 2048 * 512, end);
    file.close();
bool testSD()
    Serial.printf("Trying mount of SD card at freq %u...\r\n", SD_SPI_FREQ);
    if(!SD.begin(SD_SS, *hspi, SD_SPI_FREQ)) {
        return false;
    uint8_t cardType = SD.cardType();
    if(cardType == CARD_NONE){
        Serial.println("No SD card attached");
        return false;
    Serial.print("SD Card Type: ");
    if(cardType == CARD_MMC){
        Serial.println("MMC");
    } else if(cardType == CARD_SD){
        Serial.println("SDSC");
    } else if(cardType == CARD_SDHC){
        Serial.println("SDHC");
        Serial.println("UNKNOWN");
    uint64_t cardSize = SD.cardSize() / (1024 * 1024);
    Serial.printf("SD Card Size: %lluMB\r\n", cardSize);
    listDir(SD, "/", 0);
    createDir(SD, "/mydir");
    removeDir(SD, "/mydir");
    listDir(SD, "/", 2);
    writeFile(SD, "/hello.txt", "Hello ");
    appendFile(SD, "/hello.txt", "World!\n");
    readFile(SD, "/hello.txt");
    deleteFile(SD, "/foo.txt");
    renameFile(SD, "/hello.txt", "/foo.txt");
    readFile(SD, "/foo.txt");
    testFileIO(SD, "/test.txt");
    Serial.printf("Total space: %lluMB\r\n", SD.totalBytes() / (1024 * 1024));
    Serial.printf("Used space: %lluMB\r\n", SD.usedBytes() / (1024 * 1024));
    return true;
I tried it with FSPI and HSPI no luck. I soldered a simple board with LEDs to check if I use the right GPIOs
I tried also
#define SD_SCK GPIO_NUM_16
#define SD_MISO GPIO_NUM_15
#define SD_MOSI GPIO_NUM_14
#define SD_SS GPIO_NUM_13
on a ESP32-S3-DevKitC-1 running File>Examples/SD/SD_test the following worked for me
// ESP32_S3_DevKit_1 connections
// ESP32_S3 SCK pin GPIO12  to SD card  SCK
// ESP32_S3 MISO pin GPIO13  to SD card  MISO
// ESP32_S3 MOSI pin GPIO11  to SD card  MOSI
// ESP32_S3 SS  pin GPIO 10   to SD card SS
serial monitor output
SD Card Type: SDSC
SD Card Size: 121MB
Listing directory: /
  DIR : System Volume Information
  FILE: data.txt  SIZE: 486
  FILE: test.txt  SIZE: 77824
  FILE: foo.txt  SIZE: 13
Creating Dir: /mydir
Dir created
  DIR : mydir
Thank you I give it a try
Saludos, eh tratado de montar la SD con el codigo de ejemplo con los pines mencionados en el ESP32 s3 y sale error
 * | SPI Pin Name | ESP8266 | ESP32 | ESP32‑S2 | ESP32‑S3 | ESP32‑C3 | ESP32‑C6 | ESP32‑H2 |
 * | CS (SS)      | GPIO15  | GPIO5 | GPIO34   | GPIO10   | GPIO7    | GPIO18   | GPIO0    |
 * | DI (MOSI)    | GPIO13  | GPIO23| GPIO35   | GPIO11   | GPIO6    | GPIO19   | GPIO25   |
 * | DO (MISO)    | GPIO12  | GPIO19| GPIO37   | GPIO13   | GPIO5    | GPIO20   | GPIO11   |
 * | SCK (SCLK)   | GPIO14  | GPIO18| GPIO36   | GPIO12   | GPIO4    | GPIO21   | GPIO10   |
#include "FS.h"
#include "SD.h"
#include "SPI.h"
//Uncomment and set up if you want to use custom pins for the SPI communication
int sck  =  12;
int mosi =  11;
int miso =  13;
int cs   =  10;
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\n", dirname);
  if (!root) {
    return;
  if (!root.isDirectory()) {
    return;
  while (file) {
    if (file.isDirectory()) {
      if (levels) {
        listDir(fs, file.path(), levels - 1);
void createDir(fs::FS &fs, const char *path) {
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path)) {
void removeDir(fs::FS &fs, const char *path) {
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path)) {
void readFile(fs::FS &fs, const char *path) {
  Serial.printf("Reading file: %s\n", path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Writing file: %s\n", path);
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Appending to file: %s\n", path);
  if (!file) {
    return;
  file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
  Serial.printf("Renaming file %s to %s\n", path1, path2);
void deleteFile(fs::FS &fs, const char *path) {
  Serial.printf("Deleting file: %s\n", path);
  if (fs.remove(path)) {
void testFileIO(fs::FS &fs, const char *path) {
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    Serial.printf("%u bytes read for %lu ms\n", flen, end);
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
  Serial.printf("%u bytes written for %lu ms\n", 2048 * 512, end);
  file.close();
  while (!Serial) {
    delay(10);
#ifdef REASSIGN_PINS
  SPI.begin(sck, miso, mosi, cs);
  if (!SD.begin(cs)) {
#else
  if (!SD.begin()) {
#endif
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
  } else if (cardType == CARD_SD) {
  } else if (cardType == CARD_SDHC) {
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
void loop() {}
This is an English language forum.
could you provide a link to the SD card reader (or a photo)
what specific ESP32S3 are you using? give a link?
this is a photo of the ESP32-S3-DevKitC-1 and the SD module
the SD card module is same as in esp32-microsd-card
the pins are
MOSI: 11
MISO: 13
SCK: 12
SS: 10
SDA: 8
SCL: 9
MOSI - Master Out Slave In; MISO - Master In Slave Out; SCK - Clock signal from master
Saludos, esta es la imagen de lo que estoy utilizando
your connections look OK
what Tools>Board have you selected? I use ESP32S3 Dev Module
you should not require
if you have the correct Tools/Board the default SPI pins should be selected automatically
what does the serial monitor display?
what happens if you press the RST button?
Saludos, esto es lo que muestra el monitor serial
That's an SD card adapter for 5V logic level Arduinos.
The ESP32S3 is a 3.3V logic level device.
Greetings, this is the module info
Thank you very much, I tested your point and verified the voltages and now the module works well.
good to hear it is working
worth noting that I have various 16G SD cards the majority work OK but some display "Card Mount Failed" - work OK on PC and a Raspberry Pi
Might be an idea to tell the forum what the solution to your problem was, so others facing the same issue would know ?
Greetings, of course the manufacturer of the module as seen in the image above says that the module works from 3.3v - 5v when looking at the module it has an integrated 3.3v regulator which consumes 1v to operate, when working with an ESP32 S3 only 3.3v is supplied to the module subtracting the operating voltage of the regulator (1v) 2.2v reaches the SD card that is why it gives an error and does not mount to the system, solve this by feeding the SD card module with 5v since this ensures that the regulator supplies the 3.3v to the SD for its correct operation
