ESP32 C3 supermini - ST7789 - TFT_eSPI
After several days and numerous attempts I finally managed to get the ST7789 1.14" display working.
These are the versions I used.
  • Arduino IDE: 2.3.6
  • TFT_eSPI (bodmer) : 2.5.43
  • ESP32 board (expressif): 3.3.4
  • To compile the sketch use the Board "ESP32C3 dev module"
Some information:
The ESP32 C3 Supermini module differs from other modules in that it has a limited number of GPIOs (for space reasons). This means it has only one way to declare the SPI channel (VSPI = HSPI), which is SPI 2.
The ST7789 monitor used has 8 pins (no MISO) so can work only in Half Duplex:
TFT PIN <-------------------> ESP32C3 PIN
GND 2 (gnd)
VCC 3 (3,3v)
SCL (CLK) 4
SDA (MOSI) 6
RES (RESET) 0 (or any free GPIO)
DC 1 (or any free GPIO)
CS (CHIP SELECT) 7
BLK 3 (3,3v always backlight on) or not connect (its the same)
Replace the User_setup.h (on TFT_eSPI folder) with the follow:
// configuration for ESP32 C3 Super Mini
#define USER_SETUP_INFO "User_Setup"
#define ST7789_DRIVER
#define TFT_RGB_ORDER TFT_BGR // the label monitor show RGB but i dont know why.
#define TFT_WIDTH  135
#define TFT_HEIGHT 240
#define TFT_MISO -1 // mean not present
#define TFT_MOSI 6
#define TFT_SCLK 4
#define TFT_CS   7 // Chip select control pin
#define TFT_DC   1 // Data Command control pin
#define TFT_RST  0 // Reset pin (could connect to RST pin)
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs \~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs \~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs \~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs \~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs \~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs \~3256 bytes in FLASH, only characters 1234567890:-.
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
#define SMOOTH_FONT
#define SPI_FREQUENCY       40000000
#define SPI_READ_FREQUENCY  20000000
SOLUTION 1 (EASY Solution):
install the - ESP32 board (expressif): 2.0.14
SOLUTION 2 (to leave the current ESP32 board version 3.3.4):
For anyone with even a basic understanding of file editing, these are the most important changes in the file
// ESP32 specific SPI port selection - only SPI2_HOST available on C3
#define SPI_PORT 2
// Make sure SPI default pins are assigned if not specified by user or set to -1
#if !defined (TFT_PARALLEL_8_BIT)
#define TFT_MOSI 6
#define TFT_SCLK 4
#endif
REMOVE THE PART WHERE IF MISO = -1 the MISO = MOSI (that is totally wrong)
DOWN BELOW THE FILE (for all that not like lost time),
replace the TFT_eSPI_ESP32_C3.h (on TFT_eSPI/Processor folder) with the follow:
    // TFT_eSPI driver functions for ESP32 processors //
// Temporarily a separate file to TFT_eSPI_ESP32.h until board package low level API stabilises
#ifndef *TFT_eSPI_ESP32H*
#define *TFT_eSPI_ESP32H*
#if !defined(DISABLE_ALL_LIBRARY_WARNINGS)
#warning >>>>------>> DMA is not supported on the ESP32 C3 (possible future update)
#endif
// Processor ID reported by getSetup()
#define PROCESSOR_ID 0x32
// Include processor specific header
#include "soc/spi_reg.h"
#include "driver/spi_master.h"
#include "hal/gpio_ll.h"
#if !defined(CONFIG_IDF_TARGET_ESP32C3) && !defined(CONFIG_IDF_TARGET_ESP32S2) && !defined(CONFIG_IDF_TARGET_ESP32)
#define CONFIG_IDF_TARGET_ESP32
#endif
#ifndef VSPI
#define VSPI FSPI
#endif
// Fix IDF problems with ESP32C3
#if CONFIG_IDF_TARGET_ESP32C3
// Fix ESP32C3 IDF bug for missing definition (VSPI/FSPI only tested at the moment)
#ifndef REG_SPI_BASE
#define REG_SPI_BASE(i) DR_REG_SPI2_BASE
#endif
// Fix ESP32C3 IDF bug for name change
#ifndef SPI_MOSI_DLEN_REG
#define SPI_MOSI_DLEN_REG(x) SPI_MS_DLEN_REG(x)
#endif
#endif
// SUPPORT_TRANSACTIONS is mandatory for ESP32 so the hal mutex is toggled
#if !defined (SUPPORT_TRANSACTIONS)
#define SUPPORT_TRANSACTIONS
#endif
#define SPI_PORT 2
#ifdef RPI_DISPLAY_TYPE
#define CMD_BITS (16-1)
#else
#define CMD_BITS (8-1)
#endif
// Initialise processor specific SPI functions, used by init()
#define INIT_TFT_DATA_BUS // Not used
// Define a generic flag for 8-bit parallel
#if defined (ESP32_PARALLEL) // Specific to ESP32 for backwards compatibility
#define TFT_PARALLEL_8_BIT // Generic parallel flag
#endif
#endif
// Ensure ESP32 specific flag is defined for 8-bit parallel
#if defined (TFT_PARALLEL_8_BIT)
#if !defined (ESP32_PARALLEL)
#define ESP32_PARALLEL
#endif
#endif
// Processor specific code used by SPI bus transaction startWrite and endWrite functions
#if (TFT_SPI_MODE == SPI_MODE1) || (TFT_SPI_MODE == SPI_MODE2)
#define SET_BUS_WRITE_MODE \*\_spi_user = SPI_USR_MOSI | SPI_CK_OUT_EDGE
#define SET_BUS_READ_MODE  \*\_spi_user = SPI_USR_MOSI | SPI_USR_MISO | SPI_DOUTDIN | SPI_CK_OUT_EDGE
#else
#endif
#else
// Not applicable to parallel bus
#endif
// Code to check if DMA is busy, used by SPI bus transaction transaction and endWrite functions
#if !defined(TFT_PARALLEL_8_BIT) && !defined(SPI_18BIT_DRIVER)
#define ESP32_DMA
// Code to check if DMA is busy, used by SPI DMA + transaction + endWrite functions
#define DMA_BUSY_CHECK  dmaWait()
#else
#endif
#if defined(TFT_PARALLEL_8_BIT)
#define SPI_BUSY_CHECK
#else
#define SPI_BUSY_CHECK while (\*\_spi_cmd&SPI_USR)
#endif
// If smooth font is used then it is likely SPIFFS will be needed
#ifdef SMOOTH_FONT
// Call up the SPIFFS (SPI FLASH Filing System) for the anti-aliased fonts
#define FS_NO_GLOBALS
#include <FS.h>
#include "SPIFFS.h" // ESP32 only
#define FONT_FS_AVAILABLE
#endif
// Define the DC (TFT Data/Command or Register Select (RS))pin drive code
#ifndef TFT_DC
#define DC_C // No macro allocated so it generates no code
#define DC_D // No macro allocated so it generates no code
#else
// TFT_DC, by design, must be in range 0-31 for single register parallel write
#if (TFT_DC >= 0) &&  (TFT_DC < 32)
#define DC_C GPIO.out_w1tc.val = (1 << TFT_DC)
#define DC_D GPIO.out_w1ts.val = (1 << TFT_DC)
#elif (TFT_DC >= 32)
#define DC_C GPIO.out_w1tc.val = (1 << (TFT_DC- 32))
#define DC_D GPIO.out_w1ts.val = (1 << (TFT_DC- 32))
#else
#define DC_C
#define DC_D
#endif
#else
#if (TFT_DC >= 32)
#ifdef RPI_DISPLAY_TYPE  // RPi displays need a slower DC change
#define DC_C GPIO.out_w1ts.val = (1 << (TFT_DC - 32));
GPIO.out_w1tc.val = (1 << (TFT_DC - 32))
#define DC_D GPIO.out_w1tc.val = (1 << (TFT_DC - 32));
#else
#define DC_C GPIO.out_w1tc.val = (1 << (TFT_DC - 32))//;GPIO.out_w1tc.val = (1 << (TFT_DC - 32))
#define DC_D GPIO.out_w1ts.val = (1 << (TFT_DC - 32))//;GPIO.out_w1ts.val = (1 << (TFT_DC - 32))
#endif
#elif (TFT_DC >= 0)
#if defined (RPI_DISPLAY_TYPE)
#if defined (ILI9486_DRIVER)
// RPi ILI9486 display needs a slower DC change
#define DC_C GPIO.out_w1tc.val = (1 << TFT_DC);
#define DC_D GPIO.out_w1tc.val = (1 << TFT_DC);
#else
// Other RPi displays need a slower C->D change
#endif
#else
#define DC_C GPIO.out_w1tc.val = (1 << TFT_DC)//;GPIO.out_w1tc.val = (1 << TFT_DC)
#define DC_D GPIO.out_w1ts.val = (1 << TFT_DC)//;GPIO.out_w1ts.val = (1 << TFT_DC)
#endif
#else
#define DC_C
#define DC_D
#endif
#endif
#endif
// Define the CS (TFT chip select) pin drive code
#ifndef TFT_CS
#define TFT_CS -1  // Keep DMA code happy
#define CS_L       // No macro allocated so it generates no code
#define CS_H       // No macro allocated so it generates no code
#else
#if TFT_CS >= 32
#define CS_L GPIO.out_w1tc.val = (1 << (TFT_CS - 32))
#define CS_H GPIO.out_w1ts.val = (1 << (TFT_CS - 32))
#elif TFT_CS >= 0
#define CS_L GPIO.out_w1tc.val = (1 << TFT_CS)
#define CS_H GPIO.out_w1ts.val = (1 << TFT_CS)
#else
#define CS_L
#define CS_H
#endif
#else
#if (TFT_CS >= 32)
#ifdef RPI_DISPLAY_TYPE  // RPi display needs a slower CS change
#define CS_L GPIO.out_w1ts.val = (1 << (TFT_CS - 32));
#define CS_H GPIO.out_w1tc.val = (1 << (TFT_CS - 32));
#else
#define CS_L GPIO.out_w1tc.val = (1 << (TFT_CS - 32)); GPIO.out_w1tc.val = (1 << (TFT_CS - 32))
#define CS_H GPIO.out_w1ts.val = (1 << (TFT_CS - 32))//;GPIO.out_w1ts.val = (1 << (TFT_CS - 32))
#endif
#elif (TFT_CS >= 0)
#define CS_L GPIO.out_w1ts.val = (1 << TFT_CS); GPIO.out_w1tc.val = (1 << TFT_CS)
#define CS_H GPIO.out_w1tc.val = (1 << TFT_CS); GPIO.out_w1ts.val = (1 << TFT_CS)
#else
#define CS_L GPIO.out_w1tc.val = (1 << TFT_CS); GPIO.out_w1tc.val = (1 << TFT_CS)
#define CS_H GPIO.out_w1ts.val = (1 << TFT_CS)//;GPIO.out_w1ts.val = (1 << TFT_CS)
#endif
#else
#define CS_L
#define CS_H
#endif
#endif
#endif
// Define the WR (TFT Write) pin drive code
#if defined (TFT_WR)
#if (TFT_WR >= 32)
// Note: it will be \~1.25x faster if the TFT_WR pin uses a GPIO pin lower than 32
#define WR_L GPIO.out_w1tc.val = (1 << (TFT_WR - 32))
#define WR_H GPIO.out_w1ts.val = (1 << (TFT_WR - 32))
#elif (TFT_WR >= 0)
// TFT_WR, for best performance, should be in range 0-31 for single register parallel write
#define WR_L GPIO.out_w1tc.val = (1 << TFT_WR)
#define WR_H GPIO.out_w1ts.val = (1 << TFT_WR)
#else
#define WR_L
#define WR_H
#endif
#else
#define WR_L
#define WR_H
#endif
// Define the touch screen chip select pin drive code
#ifndef TOUCH_CS
#define T_CS_L // No macro allocated so it generates no code
#define T_CS_H // No macro allocated so it generates no code
#else // XPT2046 is slow, so use slower digitalWrite here
#define T_CS_L digitalWrite(TOUCH_CS, LOW)
#define T_CS_H digitalWrite(TOUCH_CS, HIGH)
#endif
#define TFT_MOSI 6
#define TFT_SCLK 4
#endif
// Macros for all other SPI displays
/\* Old macros
// ESP32 low level SPI writes for 8, 16 and 32-bit values
// to avoid the function call overhead
#define TFT_WRITE_BITS(D, B)
WRITE_PERI_REG(SPI_MOSI_DLEN_REG(SPI_PORT), B-1);
WRITE_PERI_REG(SPI_W0_REG(SPI_PORT), D);
SET_PERI_REG_MASK(SPI_CMD_REG(SPI_PORT), SPI_USR);
while (READ_PERI_REG(SPI_CMD_REG(SPI_PORT))&SPI_USR);
// Write 8 bits
#define tft_Write_8(C) TFT_WRITE_BITS(C, 8)
// Write 16 bits with corrected endianness for 16-bit colours
#define tft_Write_16(C) TFT_WRITE_BITS((C)<<8 | (C)>>8, 16)
// Write 16 bits
#define tft_Write_16S(C) TFT_WRITE_BITS(C, 16)
// Write 32 bits
#define tft_Write_32(C) TFT_WRITE_BITS(C, 32)
// Write two address coordinates
#define tft_Write_32C(C,D) TFT_WRITE_BITS((uint16_t)((D)<<8 | (D)>>8)<<16 | (uint16_t)((C)<<8 | (C)>>8), 32)
// Write same value twice
#define tft_Write_32D(C) TFT_WRITE_BITS((uint16_t)((C)<<8 | (C)>>8)<<16 | (uint16_t)((C)<<8 | (C)>>8), 32)
//* Replacement slimmer macros
#define TFT_WRITE_BITS(D, B) \*\_spi_mosi_dlen = B-1;
\*\_spi_w = D;
*\_spi_cmd = SPI_USR;
while (*\_spi_cmd & SPI_USR);
#else
\*\_spi_w = D;
*\_spi_cmd = SPI_UPDATE;
while (*\_spi_cmd & SPI_UPDATE);
#endif
// Write 8 bits
// Future option for transfer without wait
#define tft_Write_16N(C) \*\_spi_mosi_dlen = 16-1;
\*\_spi_w = ((C)<<8 | (C)>>8);
\*\_spi_cmd = SPI_USR;
#else
#endif
// Write 16 bits
// Write 32 bits
#ifndef tft_Write_16N
#define tft_Write_16N tft_Write_16
#endif
// Macros to read from display using SPI or software SPI
// Read from display using SPI or software SPI
// Use a SPI read transfer
#define tft_Read_8() spi.transfer(0)
#endif
// Concatenate a byte sequence A,B,C,D to CDAB, P is a uint8_t pointer
#define DAT8TO32(P) ( (uint32_t)P\[0\]<<8 | P\[1\] | P\[2\]<<24 | P\[3\]<<16 )
#endif // Header end
I hope that this can help you, but consider that this is only my expeerience, maybe for
other configurations this guide could be not work.
