Hi there!
Im trying to get a QR-Code scanner sketch to run on my ESP32-Cam.
Im using IDE v1.8.9, ESP32 library v1.0.6 and compiling the sketch for board "AI Thinker ESP32-Cam".
Unfortunately when I try to compile the following libraries:
or
I get the following error:
error: implicit declaration of function 'ps_malloc' [-Werror=implicit-function-declaration]
Here you can find the full error:
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c: In function 'quirc_new':
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:29:20: error: implicit declaration of function 'ps_malloc' [-Werror=implicit-function-declaration]
struct quirc *q = ps_malloc(sizeof(*q));
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:29:20: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c: In function 'quirc_resize':
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:68:10: error: implicit declaration of function 'ps_calloc' [-Werror=implicit-function-declaration]
image = ps_calloc(w, h);
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:68:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:87:10: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
pixels = ps_calloc(newdim, sizeof(quirc_pixel_t));
C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM\src\quirc\quirc.c:93:14: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
row_average = ps_calloc(w, sizeof(int));
cc1.exe: some warnings being treated as errors
Bibliothek ESPIno32CAM in Version 0.1.0 im Ordner: C:\Users\asury\Documents\Arduino\libraries\ESPIno32CAM wird verwendet
Bibliothek FS in Version 1.0 im Ordner: C:\Users\asury\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\FS wird verwendet
Bibliothek SPIFFS in Version 1.0 im Ordner: C:\Users\asury\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\SPIFFS wird verwendet
Bibliothek WiFiClientSecure in Version 1.0 im Ordner: C:\Users\asury\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFiClientSecure wird verwendet
Bibliothek WiFi in Version 1.0 im Ordner: C:\Users\asury\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi wird verwendet
exit status 1
Fehler beim Kompilieren für das Board AI Thinker ESP32-CAM.
I tried the CameraServer example and thats working fine.
Any ideas what could be wrong here?
I think the ps_malloc(), ps_calloc(), and ps_free() functions are only declared when the PSRAM feature (on board SPI RAM) is enabled.
When you turn on "Verbose output during compile" in Preferences, do you see these two defines in the compiler command line?
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
The "AI Thinker ESP32-CAM" has this line in bords.txt:
esp32cam.build.defines=-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-strategy=memw
It was hard to find but this is what I found:
-Wno-unused-variable -Wno-deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -Wno-old-style-declaration -MMD -c -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\Users\asury\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32
So yes I think the board should know it has PSRAM.
What can I do to get it to compile? :\
Maybe you should update your ESP32 support to the current version: 2.0.4. Go to: Tools -> Board: -> Boards Manager... Find the ESP32 boards and click on "Update".
Thanks johnwasser for your help!
Somehow it seems that I have the latest version!?
Im using this source:
https://dl.espressif.com/dl/package_esp32_index.json
Where can I find the latest v2.0.4?
Actually, it should compile with or without PSRAM. See the code in 'esp32-hal-psram.c'. When the compile time flag indicates that PSRAM is not present, then conditional compilation causes stubs to be substituted for the associated functions:
bool psramInit(){
return false;
bool ARDUINO_ISR_ATTR psramFound(){
return false;
void ARDUINO_ISR_ATTR *ps_malloc(size_t size){
return NULL;
void ARDUINO_ISR_ATTR *ps_calloc(size_t n, size_t size){
return NULL;
void ARDUINO_ISR_ATTR *ps_realloc(void *ptr, size_t size){
return NULL;
I was able to update to 2.0.4 now! Thanks!
Unfortunately still no luck
This is the whole output:
Compiling library "ESP32QRCodeReader"
"C:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-472-gc9140caf8c\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/log/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/console" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/button/button/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Wall -Werror=all -Wextra -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\asury\\AppData\\Local\\Temp\\arduino_build_535971/build_opt.h" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4\\cores\\esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4\\variants\\esp32" "-IC:\\Users\\asury\\Documents\\Arduino\\libraries\\ESP32QRCodeReader\\src" "C:\\Users\\asury\\Documents\\Arduino\\libraries\\ESP32QRCodeReader\\src\\ESP32QRCodeReader.cpp" -o "C:\\Users\\asury\\AppData\\Local\\Temp\\arduino_build_535971\\libraries\\ESP32QRCodeReader\\ESP32QRCodeReader.cpp.o"
"C:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-gcc" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-472-gc9140caf8c\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/log/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/console" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/button/button/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c -Wall -Werror=all -Wextra -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\asury\\AppData\\Local\\Temp\\arduino_build_535971/build_opt.h" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4\\cores\\esp32" "-IC:\\Users\\asury\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.4\\variants\\esp32" "-IC:\\Users\\asury\\Documents\\Arduino\\libraries\\ESP32QRCodeReader\\src" "C:\\Users\\asury\\Documents\\Arduino\\libraries\\ESP32QRCodeReader\\src\\openmv\\collections.c" -o "C:\\Users\\asury\\AppData\\Local\\Temp\\arduino_build_535971\\libraries\\ESP32QRCodeReader\\openmv\\collections.c.o"
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_alloc':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:20:23: error: implicit declaration of function 'ps_malloc'; did you mean 'lifo_alloc'? [-Werror=implicit-function-declaration]
ptr->data = (char *)ps_malloc(size * data_len);
lifo_alloc
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_free':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:36:5: error: implicit declaration of function 'free' [-Werror=implicit-function-declaration]
free(ptr->data);
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:36:5: warning: incompatible implicit declaration of built-in function 'free'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:36:5: note: include '<stdlib.h>' or provide a declaration of 'free'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:7:1:
+#include <stdlib.h>
#define CHAR_BITS (sizeof(char) * 8)
free(ptr->data);
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_enqueue':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:62:3: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration]
memcpy(ptr->data + (ptr->len * ptr->data_len), data, ptr->data_len);
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:62:3: warning: incompatible implicit declaration of built-in function 'memcpy'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:62:3: note: include '<string.h>' or provide a declaration of 'memcpy'
+#include <string.h>
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_dequeue':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:71:5: warning: incompatible implicit declaration of built-in function 'memcpy'
memcpy(data, ptr->data + ((ptr->len - 1) * ptr->data_len), ptr->data_len);
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:71:5: note: include '<string.h>' or provide a declaration of 'memcpy'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_poke':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:79:3: warning: incompatible implicit declaration of built-in function 'memcpy'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:79:3: note: include '<string.h>' or provide a declaration of 'memcpy'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c: In function 'lifo_peek':
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:84:3: warning: incompatible implicit declaration of built-in function 'memcpy'
C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader\src\openmv\collections.c:84:3: note: include '<string.h>' or provide a declaration of 'memcpy'
cc1.exe: some warnings being treated as errors
Bibliothek ESP32QRCodeReader in Version 1.1.0 im Ordner: C:\Users\asury\Documents\Arduino\libraries\ESP32QRCodeReader wird verwendet
exit status 1
Any ideas here?
This is very strange as this board seems to have PSRAM and the ESP32 board library seems to be up-to-date now.
It also seems that standart methods like "free", "memcpy" etc. are also not working. What could be the problem here?
Sorry, found it myself: I needed to update the libs and include <Arduino.h> and the c++ std libs.... dont know why this havent happend on the authors side though. Anyway: it works now Thanks for help!
system
Closed
January 12, 2023, 12:34pm
11
