ESP32 CAM module
Hello Everyone, in my project I'm using ESP32 cam module as controller with USART camera, while in usart function I'm using 38400 buffer for receiving the data, the problem is DAM memory allocation fails, and cam will not Init properly, Whenever i reduces the buffer size means camera i will init properly.
From my application i want use 38400 buffer.
Far too few details to help you.
To the best of my recollection a cam is a mechanical thing. Post an annotated schematic of what you have or are trying. Also explain what a 38400 buffer is, I am sort of new at this and it is not familiare to me. A Dam is a thing water runs over in a creek when you forget your paddle. After you post the schematic also post links to technical information on each of the hardware items in the project. You might want to read the Arduino Cookbook so you can understand the spelling and meaning for the terms you are trying to use.
