Can you connect the esp32cam to an arduino mega? if so how? and how much power does it need?
Do not use the fritzing
May it be your last. Learn to make simple pen and paper drawings, you will never regret it.
are the pins in the correct position
The correct position for what? You said absolutely nothing about what it is supposed to do.
Also you posted in the Showcase forum. Why?
I think you must have skipped over this guide:
Do you mean connecting the camera module directly to the Arduino Mega 2560 R3? Or do you connecting the Mega to an ESP32 with a camera? I think either is possible. Connecting the camera directly you will need 1.2V and 2.8V power supplies. If you run your Mega at 5V you will probably need a bunch of level shifters.
You need to explain what you mean by 'connect' as it what you are actually wanting to do.
