Hello everyone, hope this comment finds you keeping well. Currently, I'm working on a project to predict the power output from a photovoltaic plant. Thus, I need to read the power from a Fronius Primo 3.0 inverter. For that, I'm using the ESP32 DEVKIT V1 and the MAX3485 module. In the inverter, the configuration the DATCOM status is interface with 9600 baud rate and the serial configuration on the ESP32 is 9600 bauds with 8N1 configuration.
The Modbus configuration is the next one (screenshot from the inverter PA web). Sorry about the spanish language but I supose you can guess by the numbers which field is each one:
About the Fronius String direction compensation is 100 not 101. I've tried everything that has pop up to my mind but idk I still can't read nothing from the inverter. I also leave you the hardware connections and the code I'm running at the moment.
#include <Arduino.h>
#include <ModbusMaster.h>
#include <Wire.h>
// ── Configuracion Modbus ──────────────────────────────────────
#define MODBUS_ID 100 // Cambiar a 100 si no responde
#define PIN_RX2 16
#define PIN_TX2 17
#define MODBUS_BAUD 9600UL
// ── Timing ───────────────────────────────────────────────────
#define POLL_INTERVAL_MS 5000UL
#define MODBUS_TIMEOUT_MS 1000UL
#define MAX_RETRIES 3
// ── Registros Modbus (base-0 = mapa Fronius - 1) ─────────────
#define REG_MPPT_SF_BASE 40265 // DCA_SF, DCV_SF, DCW_SF
#define REG_MPPT1_BASE 40282 // I, V, P string 1
#define REG_MPPT2_BASE 40302 // I, V, P string 2
#define REG_AC_BASE 40071 // Bloque AC completo (47 regs)
#define REG_AC_COUNT 47
// Offsets en el buffer del bloque AC (en registros de 16-bit)
// offset = fronius_reg - 40072
#define OFF_AC_CURRENT 0 // 40072-40073 A float32
#define OFF_AC_VOLTAGE 14 // 40086-40087 PhVphA float32
#define OFF_AC_POWER 20 // 40092-40093 W float32
#define OFF_STATE 46 // 40118 St uint16
// ── OLED SSD1306 128x64 ───────────────────────────────────────
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
#define OLED_ADDR 0x3C
#define OLED_RESET -1
// ── Objetos globales ──────────────────────────────────────────
ModbusMaster modbus;
// ── Estructura de datos del inversor ─────────────────────────
struct InverterData {
float Idc1, Vdc1, Pdc1; // DC string 1 [A, V, W]
float Idc2, Vdc2, Pdc2; // DC string 2 [A, V, W]
float PdcTotal; // Potencia DC total [W]
float Iac, Vac, Pac; // AC [A, V, W]
uint16_t state; // Estado SunSpec enum16
bool valid; // Ciclo de lectura exitoso
InverterData inv = {};
// Scale factors Multiple MPPT (int16, sunsssf)
// Valor por defecto -2 -> x0.01 (confirmado en TFG y mapa regs)
int16_t sf_DCA = -2;
int16_t sf_DCV = -2;
int16_t sf_DCW = -2;
// ── Prototipos ────────────────────────────────────────────────
float applyScaleFactor(uint16_t raw, int16_t sf);
float regsToFloat(uint16_t hi, uint16_t lo);
bool readMPPTScaleFactors();
bool readMPPTString(uint8_t str, float &I, float &V, float &P);
bool readACBlock();
void runReadCycle();
//void updateOLED();
void printDebug();
void preTransmission();
void postTransmission();
const char* stateStr(uint16_t st);
// 1. Iniciamos UART2 (Modbus) con sus pines (16 y 17)
Serial2.begin(MODBUS_BAUD, SERIAL_8N1, PIN_RX2, PIN_TX2);
// 2. Aplicamos el timeout a Serial2 (MUY IMPORTANTE)
//Serial2.setTimeout(MODBUS_TIMEOUT_MS);
// 3. Vinculamos la librería ModbusMaster a Serial2
modbus.begin(MODBUS_ID, Serial2);
modbus.preTransmission(preTransmission);
modbus.postTransmission(postTransmission);
// 4. UART0 (Serial) queda libre para ver mensajes en el PC
Serial.println("Comunicacion con Fronius iniciada en UART2...");
delay(100);
static uint32_t lastPoll = 0;
if (millis() - lastPoll < POLL_INTERVAL_MS) return;
lastPoll = millis();
runReadCycle();
//updateOLED();
printDebug();
void preTransmission() {
// Flush cualquier byte residual antes de transmitir
while (Serial2.available()) Serial2.read();
void postTransmission() {
// Dar tiempo al módulo para volver a RX y vaciar el eco
delay(2);
while (Serial2.available()) Serial2.read(); // descartar eco propio
// Ciclo completo: SF -> MPPT1 -> MPPT2 -> Bloque AC
void runReadCycle() {
inv.valid = false;
// Scale factors (si fallan, continua con valores por defecto)
if (!readMPPTScaleFactors()) {
Serial.println("[WARN] SF no leidos, usando sf=-2 (x0.01)");
// String 1 — obligatorio
if (!readMPPTString(1, inv.Idc1, inv.Vdc1, inv.Pdc1)) {
Serial.println("[ERR] Fallo MPPT1 — abortando ciclo");
return;
// String 2 — no fatal (puede haber un solo string activo)
if (!readMPPTString(2, inv.Idc2, inv.Vdc2, inv.Pdc2)) {
Serial.println("[WARN] Fallo MPPT2 — asumiendo 0");
inv.Idc2 = inv.Vdc2 = inv.Pdc2 = 0.0f;
inv.PdcTotal = inv.Pdc1 + inv.Pdc2;
// Bloque AC — obligatorio
if (!readACBlock()) {
Serial.println("[ERR] Fallo bloque AC — abortando ciclo");
return;
inv.valid = true;
// Scale factors del modelo Multiple MPPT
// FC03, 3 registros desde 40265 (base-0)
bool readMPPTScaleFactors() {
for (int r = 0; r < MAX_RETRIES; r++) {
uint8_t res = modbus.readHoldingRegisters(REG_MPPT_SF_BASE, 3);
if (res == ModbusMaster::ku8MBSuccess) {
sf_DCA = (int16_t)modbus.getResponseBuffer(0);
sf_DCV = (int16_t)modbus.getResponseBuffer(1);
sf_DCW = (int16_t)modbus.getResponseBuffer(2);
Serial.printf("[SF] DCA=%d DCV=%d DCW=%d\n", sf_DCA, sf_DCV, sf_DCW);
return true;
Serial.printf("[SF] retry %d err=0x%02X\n", r + 1, res);
delay(150);
return false;
// Lectura de un string MPPT (I, V, P)
// str: 1 o 2 | FC03, 3 registros contiguos
bool readMPPTString(uint8_t str, float &I, float &V, float &P) {
uint16_t base = (str == 1) ? REG_MPPT1_BASE : REG_MPPT2_BASE;
uint8_t res = modbus.readHoldingRegisters(base, 3);
uint16_t rawI = modbus.getResponseBuffer(0);
uint16_t rawV = modbus.getResponseBuffer(1);
uint16_t rawW = modbus.getResponseBuffer(2);
// 0xFFFF = dato invalido (arranque/parada)
// Documentado en TFG seccion 5.6 y mapa de registros
I = (rawI == 0xFFFF) ? 0.0f : applyScaleFactor(rawI, sf_DCA);
V = (rawV == 0xFFFF) ? 0.0f : applyScaleFactor(rawV, sf_DCV);
P = (rawW == 0xFFFF) ? 0.0f : applyScaleFactor(rawW, sf_DCW);
Serial.printf("[MPPT%d] I=%.3fA V=%.2fV P=%.1fW\n", str, I, V, P);
return true;
Serial.printf("[MPPT%d] retry %d err=0x%02X\n", str, r + 1, res);
delay(150);
return false;
// Bloque AC: 47 registros desde 40071 (base-0)
// Decodifica float32 big-endian y el estado uint16
bool readACBlock() {
uint8_t res = modbus.readHoldingRegisters(REG_AC_BASE, REG_AC_COUNT);
// float32: word alto en offset N, word bajo en N+1
inv.Iac = regsToFloat(
modbus.getResponseBuffer(OFF_AC_CURRENT),
modbus.getResponseBuffer(OFF_AC_CURRENT + 1));
inv.Vac = regsToFloat(
modbus.getResponseBuffer(OFF_AC_VOLTAGE),
modbus.getResponseBuffer(OFF_AC_VOLTAGE + 1));
inv.Pac = regsToFloat(
modbus.getResponseBuffer(OFF_AC_POWER),
modbus.getResponseBuffer(OFF_AC_POWER + 1));
inv.state = modbus.getResponseBuffer(OFF_STATE);
Serial.printf("[AC] I=%.3fA V=%.2fV P=%.1fW St=%s\n",
inv.Iac, inv.Vac, inv.Pac, stateStr(inv.state));
return true;
Serial.printf("[AC] retry %d err=0x%02X\n", r + 1, res);
delay(150);
return false;
// Scale factor SunSpec: valor_fisico = raw * 10^sf
float applyScaleFactor(uint16_t raw, int16_t sf) {
float v = (float)raw;
if (sf >= 0) {
for (int i = 0; i < sf; i++) v *= 10.0f;
for (int i = 0; i < -sf; i++) v *= 0.1f;
return v;
// Reconstruir float32 IEEE-754 big-endian desde dos uint16
float regsToFloat(uint16_t hi, uint16_t lo) {
uint32_t raw = ((uint32_t)hi << 16) | (uint32_t)lo;
float f;
memcpy(&f, &raw, sizeof(f));
return f;
// Nombre del estado SunSpec enum16
const char* stateStr(uint16_t st) {
switch (st) {
case 1: return "OFF";
case 2: return "SLEEPING";
case 3: return "STARTING";
case 4: return "MPPT";
case 5: return "THROTTLE";
case 6: return "SHUTTING";
case 7: return "FAULT";
case 8: return "STANDBY";
default: return "UNKNOWN";
// Resultados por Serial1 (debug)
void printDebug() {
if (!inv.valid) {
Serial.println("[!] Error Modbus: El inversor no responde.");
return;
Serial.println("\n+---------------------------------------+");
Serial.printf("| FRONIUS ID: %-3d | ESTADO: %-10s |\n", MODBUS_ID, stateStr(inv.state));
Serial.println("+---------------------------------------+");
Serial.printf("| AC Power: %7.1f W | VAC: %5.1f V |\n", inv.Pac, inv.Vac);
Serial.printf("| DC Total: %7.1f W | IAC: %5.2f A |\n", inv.PdcTotal, inv.Iac);
I tried different MODBUS_ID like 1, 100 or 101 and nothing. In case you need smthn more, just ask for it! ;)
