ESP32 - Connection Issues with DFPlayer Mini
Hi there,
I'm trying to connect my ESP32-Wroom-32 (az-delivery-devkit-v4) to an DFPlayer Mini however I'm missing something as I cannot get it to work.
Here you can see my current wiring. The resistor is 1k.
To get it started, I'm using the official example code for the dfplayer:
#include "Arduino.h"
#include "DFRobotDFPlayerMini.h"
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266))   // Using a soft serial port
#include <SoftwareSerial.h>
SoftwareSerial softSerial(/*rx =*/23, /*tx =*/18);
#define FPSerial softSerial
#else
#define FPSerial Serial1
#endif
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
#if (defined ESP32)
  FPSerial.begin(9600, SERIAL_8N1, /*rx =*/23, /*tx =*/18);
#else
  FPSerial.begin(9600);
#endif
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(FPSerial, /*isACK = */true, /*doReset = */true)) {  //Use serial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true){
      delay(0); // Code to compatible with ESP8266 watch dog.
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(20);  //Set volume value. From 0 to 30
  Serial.println(F("Volume set, start playing track 0"));
  myDFPlayer.play(0);  //Play the first mp3
  Serial.println(F("Start playing track 1"));
  myDFPlayer.play(1);  //Play the first mp3
  Serial.println(F("Start playing track 2"));
  myDFPlayer.play(2);  //Play the first mp3
  static unsigned long timer = millis();
  if (millis() - timer > 3000) {
    timer = millis();
    Serial.println(F("Playing next song"));
    myDFPlayer.next();  //Play next mp3 every 3 second.
  if (myDFPlayer.available()) {
    printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerUSBInserted:
      Serial.println("USB Inserted!");
    case DFPlayerUSBRemoved:
      Serial.println("USB Removed!");
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
It always runs into the "Unable to begin:" block. I've also checked all connections with a multimeter and tried it with another ESP32 and also another DFPlayer mini without any result.
I would be really happy If anyone has an Idea of what I'm doing wrong :slight_smile:
Try Rx = pin 16, Tx = 17.
I can just about decipher the wiring connections from your annotated photo, but a schematic would be much better.
I moved your topic to a more appropriate forum category @espfriend24.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
