ESP32 errore compilazione IDE
Buona sera a tutti, sto cercando di caricare uno sketch su ESP32, in fase di compilazione, IDE mi da questo errore:
C:\Users\ryzen\Desktop\0\VFO_ESP32-20-Mem\VFO_ESP32-20-Mem.ino: In function 'void setup()':
C:\Users\ryzen\Desktop\0\VFO_ESP32-20-Mem\VFO_ESP32-20-Mem.ino:375:23: error: too many arguments to function 'hw_timer_t* timerBegin(uint32_t)'
  375 |     timer = timerBegin(0, 80, true); //use Timer0, div80 for 1us clock
In file included from C:\Users\ryzen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32/esp32-hal.h:84,
                 from C:\Users\ryzen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32/Arduino.h:36,
                 from C:\Users\ryzen\AppData\Local\Temp\arduino\sketches\D8AF4026D8B96FF83EBB8328D37947AE\sketch\VFO_ESP32-20-Mem.ino.cpp:1:
C:\Users\ryzen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32/esp32-hal-timer.h:35:13: note: declared here
   35 | hw_timer_t *timerBegin(uint32_t frequency);
C:\Users\ryzen\Desktop\0\VFO_ESP32-20-Mem\VFO_ESP32-20-Mem.ino:376:25: error: too many arguments to function 'void timerAttachInterrupt(hw_timer_t*, void (*)())'
  376 |     timerAttachInterrupt(timer, &onTimer, true);
C:\Users\ryzen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32/esp32-hal-timer.h:50:6: note: declared here
   50 | void timerAttachInterrupt(hw_timer_t *timer, void (*userFunc)(void));
C:\Users\ryzen\Desktop\0\VFO_ESP32-20-Mem\VFO_ESP32-20-Mem.ino:377:5: error: 'timerAlarmWrite' was not declared in this scope; did you mean 'timerWrite'?
  377 |     timerAlarmWrite(timer, 10000, true); // T=10000us
      |     timerWrite
C:\Users\ryzen\Desktop\0\VFO_ESP32-20-Mem\VFO_ESP32-20-Mem.ino:378:5: error: 'timerAlarmEnable' was not declared in this scope; did you mean 'timerAlarm'?
  378 |     timerAlarmEnable(timer); // Start Timer
      |     timerAlarm
exit status 1
Compilation error: too many arguments to function 'hw_timer_t* timerBegin(uint32_t)'
le righe a cui fa riferimento sono queste:
type or paste code here
//--------- Set up Interrupt Timer -------------------------------
Prementto che è la prima volta che carico uno scketch complesso che contiene alcune librerie, e che L' ESP32 non è connesso a nessuna perfiferica prevista nel progetto e che fanno riferimento alle librerie, come ad esempio il display ed altro.
potrebbe eesere dovuto a questo?
Grazie a tutti, buona serata.
Dovresti mettere lo sketch completo perché cosi andiamo un po' a caso...
Può essere che stai usando del codice scritto con la versione precedente del core ESP32 (2.XX), nella nuova versione (3.XX) alcune cose sono cambiate e non sono retro-compatibili. Esempio timerBegin() ora prende un solo parametro, da li l'errore che riporti.
Ciao, Ale.
ecco lo schtch completo:
   VFO System for ESP32-DevKitC  Ver 1.00
        by T.Uebo / JF3HZB
          Feb. 10, 2019
/*------Hard ware Configuration ---------------------
<<ESP32-DevKitC>>
pin No.  Connection
  16 :  Rotary Encoder A
  17 :  Rotary Encoder B
  22 :  si5351A SCL
  21 :  si5351A SDA
  18 :  SCK    / ST7735,SEPS525(128x160 display)
  23 :  MOSI   / ST7735,SEPS525(128x160 display)
   5 :  CS     / ST7735,SEPS525(128x160 display)
   2 :  DC(A0) / ST7735,SEPS525(128x160 display)
  15 :  RESET  / ST7735,SEPS525(128x160 display)
<<si5351A>>
CLK0 : Car Signal (I)
CLK1 : Car Signal (Q)
CLK2 : Lo Signal
// Libraries
#include <EEPROM.h>  // https://github.com/espressif/arduino-esp32/tree/master/libraries/EEPROM
   Frequency settings
  #define init_freq  14230000    // Initial Frequncy[Hz]
  int32_t offset_frq = 0;    // Offset Frequency[Hz]in + o in - per oscillatore locale LO
  int32_t    car_frq = 0;   // 19000000 frequenza BFO  calcolare + o - 1500 Hz per usb o lsb  // Carrier Frequency[Hz]
  unsigned char f_carON = 1; // ON/OFF Car signal
  int32_t  freq_step;
  float readParam;
#define fmax 225000000       // Max frequency[ 225 MHz]
#define fmin   100000        // Min frequency[100 KHz]
#define EEPROM_SIZE 50       // 20
    Control flags
uint8_t f_fchange;  // if frequency changed, set this flag to 1
uint8_t f_cchange;  // if Car frequency and/or "f_carON" changed, set this flag to 1
uint8_t f_dchange;  // if need to renew display, set this flag to 1
   pin assign
//#define LED_BUILTIN 13
  #define PULSE_INPUT_PIN 17 // Rotaty Encoder A  // orig16
  #define PULSE_CTRL_PIN 16  // Rotaty Encoder B  // orig17
#define NAME "VFO System"
#define VERSION "Ver. 1.00"
#define ID "by JF3HZB"
#include "driver/pcnt.h"
#include "display.h"
#include "graph.h"
#include "dial.h"
#include "si5351.h"
 *       Global
float dacc=0.0;
float Maxdacc=500.0;
long frq=init_freq;
int16_t RE_Count = 0;
uint8_t f_redraw;
extern char f_rev;
extern uint32_t cl_BG;
int press;
int cnt=2;
int mem, mem_old;
int cnt_old;
long step;
int address;
        Timer ISR
hw_timer_t * timer = NULL;
void IRAM_ATTR onTimer(){}
void loop() {    // (core1)
 press = digitalRead(27);  // con pulsante  Step -
  if(press==LOW)
  cnt = cnt-1;
  if(cnt<0) { cnt=6 ; }
  Serial.println(cnt);
  delay(300);
 press = digitalRead(26);  //  pulsante Step +
  if(press==LOW)
  cnt = cnt+1;
  if(cnt>6) { cnt=0 ; }  // cnt=6 se si usano i due pulsanti S+ e S-.... cnt=0 se si una un solo pulsante Step +
  delay(300);
 press = digitalRead(25);  //  pulsante Memorie +
  if(press==LOW)
  mem = mem+1;
  if(mem>20) { mem=0 ; }  // numero memorie
//  Serial.println(mem);
  delay(300);
  press = digitalRead(14);  //  pulsante Memorie -
  if(press==LOW)
  mem = mem-1;
  if(mem<0) { mem=20 ; }  // numero memorie
  delay(300);
  if(cnt==0) { step=10; freq_step=2.5;         }
  if(cnt==1)  { step=100; freq_step=25;        }
  if(cnt==2) { step=1000; freq_step=250;       }
  if(cnt==3)  { step=10000; freq_step=2500;    }
  if(cnt==4) { step=100000; freq_step=25000;   }
  if(cnt==5) { step=1000000; freq_step=250000; }
  if(cnt==6) { step=10000000; freq_step=2500000; }
  if(mem!=mem_old)
  if(mem==0) { frq=init_freq;      }
  if(mem==1) { frq=1830000;   }
  if(mem==2) { frq=3600000;   }
  if(mem==3) { frq=3850000;   }
  if(mem==4) { frq=5505000;   }
  if(mem==5) { frq=6070000;   }
  if(mem==6) { frq=7130000;   }
  if(mem==7) { frq=7878100;   }
  if(mem==8) { frq=8957000;   }
  if(mem==9) { frq=10100000;  }
  if(mem==10) { frq=14100000;  }
  if(mem==11) { frq=17100000;  }
  if(mem==12) { frq=21100000;  }
  if(mem==13) { frq=24100000;  }
  if(mem==14) { frq=27100000;  }
  if(mem==15) { frq=28000000;  }
  if(mem==16) { frq=70000000;  }
  if(mem==17) { frq=100000000;  }
  if(mem==18) { frq=200000000;  }
  if(mem==19) { frq=145000000;  }
  if(mem==20) { frq=220000000;  }
  set_freq( frq + offset_frq );  // alla Lo viene aggiunto il valore di offset - la lettura a display resta la stessa
//  Serial.println(frq);
 press = digitalRead(32);  // pulsante Store
  if(press==LOW)
  EEPROM.begin(EEPROM_SIZE);
  // Write data into eeprom
  address = 0;
  int boardId = 18;
  EEPROM.write(address, boardId);    //EEPROM.put(address, boardId);
  address += sizeof(boardId);        //update address value
  double param = frq;
  Serial.print("Write to  EEPROM = ");
  Serial.println(param,0);
  EEPROM.writeFloat(address, param); //EEPROM.put(address, param);
  EEPROM.commit();
  delay(300);
    char str[64];
    if(f_dchange==1||cnt!=cnt_old||mem!=mem_old)
        f_dchange=0;
        //GRAM_clr();
        boxfill(0,0,Nx-1,Ny-1,cl_BG);
        //Display Dial
        Dial(frq);
        box(0,100,160,126, 0xa0a0a0); // 0x00efff   - 0xa0a0a0 colore riquadri display frequenza
        box(1,99,159,127, 0xa0a0a0);
  sprintf(str, "STEP"); disp_str8(str,73, 85, 0xFF0000);
  if(cnt==0) { sprintf(str, " 10 Hz"); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==1) { sprintf(str, " 100 Hz"); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==2) { sprintf(str, " 1 KHz" ); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==3) { sprintf(str, " 10 KHz" ); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==4) { sprintf(str, "100 KHz" ); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==5) { sprintf(str, " 1 MHz" ); disp_str12(str,100, 85, 0xffff00); }
  if(cnt==6) { sprintf(str, " 10 MHz" ); disp_str12(str,100, 85, 0xffff00); }
  if(mem==0) { sprintf(str, "VFO"); disp_str16(str,8, 80, 0x00bb2d); }
  if(mem==1) { sprintf(str, "Mem.01");  disp_str12(str,1, 85, 0xff8000); }
  if(mem==2) { sprintf(str, "Mem.02" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==3) { sprintf(str, "Mem.03" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==4) { sprintf(str, "Mem.04" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==5) { sprintf(str, "Mem.05" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==6) { sprintf(str, "Mem.06" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==7) { sprintf(str, "Mem.07" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==8) { sprintf(str, "Mem.08" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==9) { sprintf(str, "Mem.09" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==10) { sprintf(str, "Mem.10" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==11) { sprintf(str, "Mem.11" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==12) { sprintf(str, "Mem.12" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==13) { sprintf(str, "Mem.13" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==14) { sprintf(str, "Mem.14" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==15) { sprintf(str, "Mem.15" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==16) { sprintf(str, "Mem.16" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==17) { sprintf(str, "Mem.17" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==18) { sprintf(str, "Mem.18" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==19) { sprintf(str, "Mem.19" ); disp_str12(str,1, 85, 0xff8000); }
  if(mem==20) { sprintf(str, "Mem.20" ); disp_str12(str,1, 85, 0xff8000); }
        //-------- Display Digital Frquency ---------------------------------------
        sprintf(str, "%3d.%03d,%02d",  frq/1000000, (frq/1000)%1000, (frq/10)%100 );
        disp_str20(str,7, 105, 0x00ffff);        // 0xffd080  - 0x00efff   colore cifre freq
        sprintf(str, "MHz" );
        disp_str12(str,127, 106, 0xf80000); // 0xffd080     colore Mhz
        if(f_redraw==0){
          trans65k();
          f_redraw=1;
        cnt_old=cnt;
        mem_old=mem;
    //digitalWrite(LED_BUILTIN, 1^digitalRead(LED_BUILTIN) ); //  Toggle LED
        Alternative Loop (core0)
void task0(void* arg)
     while (1)
         pcnt_get_counter_value(PCNT_UNIT_0, &RE_Count);
         int count=RE_Count;
         pcnt_counter_clear(PCNT_UNIT_0);
         if(f_rev==1) count=-count;
         if(count!=0){
            f_dchange=1;
            f_fchange=1;
            frq+= count * freq_step;
            if(frq>fmax) frq=fmax;
            if(frq<fmin) frq=fmin;
         if(f_fchange==1){
            f_fchange=0;
            // Output Lo freq
         if(f_cchange==1){
            f_cchange=0;
            // Output Car freq
            set_car_freq(car_frq, f_carON, 0);
         if(f_redraw==1){
            Transfer_Image();
            f_redraw=0;
         delay(1);
    Serial.println("Start");
    delay(100);
    pinMode(25,INPUT_PULLUP);
    pinMode(26,INPUT_PULLUP);
    pinMode(27,INPUT_PULLUP);
    pinMode(32,INPUT_PULLUP);
    pinMode(14,INPUT_PULLUP);
// Init EEPROM
// Read data from eeprom
  address = 0;
  int readId;
  readId = EEPROM.read(address);  // EEPROM.get(address,readId);
  address += sizeof(readId);      // update address value
  EEPROM.get(address, readParam); // readParam=EEPROM.readFloat(address);
  Serial.print("Read from EEPROM = ");
  Serial.println(readParam,0);
  EEPROM.end();
  if(readParam!=0) { frq=readParam; }
    char str[64];
    //--------- create tasks on core0 --------------------------------
    xTaskCreatePinnedToCore(task0, "Task0", 4096, NULL, 1, NULL, 0);
    //pinMode(LED_BUILTIN, OUTPUT);   //LED
    //--- Counter setup for Rotary Encoder ---------------------
    pcnt_config_t pcnt_config_A;// structure for A
    pcnt_config_t pcnt_config_B;// structure for B
    pcnt_config_A.pulse_gpio_num = PULSE_INPUT_PIN;
    pcnt_config_A.ctrl_gpio_num = PULSE_CTRL_PIN;
    pcnt_config_A.lctrl_mode = PCNT_MODE_REVERSE;
    pcnt_config_A.hctrl_mode = PCNT_MODE_KEEP;
    pcnt_config_A.channel = PCNT_CHANNEL_0;
    pcnt_config_A.unit = PCNT_UNIT_0;
    pcnt_config_A.pos_mode = PCNT_COUNT_INC;
    pcnt_config_A.neg_mode = PCNT_COUNT_DEC;
    pcnt_config_A.counter_h_lim = 10000;
    pcnt_config_A.counter_l_lim = -10000;
    pcnt_config_B.pulse_gpio_num = PULSE_CTRL_PIN;
    pcnt_config_B.ctrl_gpio_num = PULSE_INPUT_PIN;
    pcnt_config_B.lctrl_mode = PCNT_MODE_KEEP;
    pcnt_config_B.hctrl_mode = PCNT_MODE_REVERSE;
    pcnt_config_B.channel = PCNT_CHANNEL_1;
    pcnt_config_B.unit = PCNT_UNIT_0;
    pcnt_config_B.pos_mode = PCNT_COUNT_INC;
    pcnt_config_B.neg_mode = PCNT_COUNT_DEC;
    pcnt_config_B.counter_h_lim = 10000;
    pcnt_config_B.counter_l_lim = -10000;
    pcnt_unit_config(&pcnt_config_A);//Initialize A
    pcnt_unit_config(&pcnt_config_B);//Initialize B
    pcnt_counter_pause(PCNT_UNIT_0);
    pcnt_counter_resume(PCNT_UNIT_0); //Start
    display_init();
    GRAM_clr();
    sprintf(str,  NAME  ); disp_str16(str,20, 90, 0xefff00);
    sprintf(str,    ID  ); disp_str12(str,40, 70, 0x00ff2a);
    sprintf(str, "- Mod. By IU4ALH -"); disp_str8(str,28, 5, 0xffd080);
    trans65k();
    f_redraw=1;
    delay(1500);
    init_Dial();
    GRAM_clr();
    si5351_init();
    f_fchange = 1;
    f_cchange = 1;
    f_dchange = 1;
    f_redraw=0;
grazie
quindi come posso correggerlo?
grazie
ho provato ad usare chat gpt, la quale mi ha dato la tua stessa risposta. con il suggerimento di correggere in questo modo:
volatile int counter = 0;  // Variabile per contare gli interrupt
void IRAM_ATTR onTimer() {
  counter++;  // Incrementa il contatore ad ogni interrupt
  delay(100);
  // Inizializzazione del timer
  timer = timerBegin(0, 80);  // Timer0, prescaler 80 per 1µs
  // Attacco dell'interrupt
  timerAttachInterrupt(timer, &onTimer);  // Associa la funzione all'interrupt
  // Configurazione dell'allarme (ogni 10 ms = 10000µs)
  timerAlarmWrite(timer, 10000, true);  // Impostazione allarme per 10000µs (10ms)
  timerAlarmEnable(timer);  // Abilitazione dell'allarme
  // Altri setup
  // Mostra il valore del contatore ogni secondo
  Serial.print("Counter: ");
  Serial.println(counter);
@fox_mulder:
... fosse anche per una sola riga, come richiesto al punto 7 del REGOLAMENTO, il codice va racchiuso tra i tag CODE, per cui, cortesemente edita il tuo post qui sopra (quindi NON scrivendo un nuovo post, ma utilizzando il bottone a forma di piccola matita :pencil2: che si trova in basso del tuo post), seleziona la parte di codice e premi l'icona <code/> nella barra degli strumenti per contrassegnarla come codice. Inoltre, così com'è, non è molto leggibile ... assicurati di averlo correttamente indentato nell'IDE prima di inserirlo (questo lo si fa premendo ctrlT su un PC o cmd T su un Mac, sempre all'interno del IDE).
Grazie,
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà sistemato il codice come indicato, nel rispetto del regolamento nessuno ti risponderà (eventuali risposte o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farlo al più presto. :wink:
Fatto, grazie e scusate l'errore.
E funziona? Io direi di no, visto che continua ad usare le API del core precedente.
Hai 2 scelte: o riscrivi il codice adeguandolo al nuovo core (qui trovi i dettagli dei cambiamenti), oppure installi la versione precedente del core (2.X) (scelta sconsigliata).
Ciao, Ale.
Terza opzione: usare PlatformIO dove con Arduino ESP32 core sono ancora fermi alla versione v2.0.17 (e dove si può specificare nelle impostazioni di progetto, esattamente quale versione usare).
non ho nemmeno provato se funziona, non avevo dubbi che non avrebbe fuzionato, era un tentativo disperato.
di riscrivere il codice non sono assolutamente in grado, è troppo complesso per me.
come faccio ad insatallare la versione precedente del core e dove la posso trovare? grazie
al posto dell' IDE di arduino?
grazie
Vai nel "board Manager" dell'IDE, selezioni il "core" ESP32 e scegli la versione che vuoi installare ...
Guglielmo
grazie! questa sera provo e poi ti faccio sapere.
grazie mille buona giornata
Niente da fare, ho provato più volte la versione 2.017, adesso mi genera questo errore:
c:/users/ryzen/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\ryzen\AppData\Local\Temp\arduino\sketches\D8AF4026D8B96FF83EBB8328D37947AE/VFO_ESP32-20-Mem.ino.elf section `.dram0.bss' will not fit in region `dram0_0_seg'
c:/users/ryzen/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: DRAM segment data does not fit.
c:/users/ryzen/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `dram0_0_seg' overflowed by 3584 bytes
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
grazie
L'errore indica che si sta provando ad allocare una porzione di memoria superiore a quella disponibile, cosa strana perché l'ESP32 di SRAM ne ha davvero tanta...
Secondo me non ti conviene insistere con questo progetto, ma provare a cercare un'alternativa migliore/più recente.
Ad esempio sempre dello stesso autore c'è anche la versione v2 che sembra essere mantenuta con più frequenza e più recentemente (ma anche in questo caso viene usata ancora la versione 2.0.x del core).
Non so se fa al caso tuo, ma trovo molto interessante anche questo altro progetto.
Grazie per la risposta, mi piaceva questa versione perchè hanno implementato delle funzioni interessanti, tipo il BFO, e mi piaceva l'idea della grafica vintage.
Ti ringrazio dei link vado a vedere come sono. grazie
Buongiorno a tutti, forse ho risolto, ho caricato la versione 1.06 del core, non ha dato errori ne nella complilazione, ne nel caricamento sull'ESP.
Appena ho realizzato il circuito vi do confema.
Grazie a tutti voi dell'aiuto.
A presto e buona giornata.
confermo quanto anticipato, ha funzionanato tutto correttamente.
grazie a tutti per l'aiuto. buona Domenica.
