I inherited a project for a Feather Huzzah ESP8266 and wanted to use a Feather Huzzah ESP32.
However I have found (so far), that the sketch is using 2 .h files that are not found.
ESP8266WiFi
ESP8266WebServer
I have found what I think is the ESP32 equivalent for the ESP8266WiFi, named WiFi.
but, there is nothing similar for the ESP8266WebServer.
Does anyone know what it is ?
I tried WebServer and ESP32WebServer but no love.
Is this an Arduino issue ? I posted it on the ESP32 forum and have had no responses.
hextejas:
ESP8266WiFi
ESP8266WebServer
These are libraries that come bundled with the ESP8266 boards platform you install via the Arduino IDE's Boards Manager (or manually if you feel like making things difficult for yourself). Libraries bundled with a boards platform are only available when you have one of the boards of that platform selected from the Arduino IDE's Tools > Board menu
hextejas:
That's correct. The ESP32 boards platform comes with a bundled library named WiFi that is the equivalent of the ESP8266 boards platform's bundled ESP8266WiFi library. Note that there are multiple Arduino libraries named "WiFi", so don't get confused. The WiFi library you need is automatically installed along with the ESP32 boards platform and, as long as you don't go installing some random WiFi libraries you find online, will be automatically selected by the Arduino IDE when you have an ESP32 board selected.
hextejas:
The ESP32 boards platform comes with a bundled library named "WebServer". If you select an ESP32 board from the ARduino IDE's Tools > Board menu and then study the nice example sketches you will find under the File > Examples > WebServer menu, you'll see how to use it.
hextejas:
How did you try it?
hextejas:
You haven't provided enough information for us to say whether there is even an issue. From what I can see, the ESP32 platform developers have been kind enough to provide a WebSErver library with examples along with their boards platform and the Arduino IDE is recognizing this library just fine.
pert:
If yes, please provide a detailed description of the problem you had.
So, I need to try and fine a suitable replacement for the missing .h files. I am hoping that I will not have to do too much re-coding to get it to work, cause this looks messy.
pert:
Did you try what I told you to do?
If no, why not?
I am looking at the WebServer examples now and there are quite a few of them.
Would anyone like to take a look at my .cpp file and tell me which WebServer example comes the closest ?
