Interesting project. Can You put the working ones together, finding what they have in common, and do the same for the not well working ones?
That's what comes up here. No further knowledge.
@st_4489665 it's a little tricky finding some of the urls but here is an example of one method using the following link.
Press F12 to bring up the "inspection panel" and make sure you have "Network" selected on the menu, choose a mp3 channel and hit play. In the Network panel it will start logging, under Name look for a small green rectangle with a small play button, it should say media under the Type heading. Then copy the url that is in the next column to the right.
The procedure is similar for other channels but sometimes you are looking for "stream" or "media-ice" and a bunch of other things.
I have 10 channels that cover different genres and that is adequate
Ok, so I've done this and found URLs quite easily, fantastic!
Trouble is, some still don't want to play on the device... I might get 0.5 seconds of music followed by a restart.
I wish I knew what the problem is, and wonder whether it's a buffering issue with some streams? I've tried selecting lower quality as possible, but that still doesn't seem to do it.
Yes it can be a little hit and miss, as I said if you can locate 10 or so with a fairly decent cross section of music choice that should be enough.
It's been a while since I did this project so I can't remember exactly how I found all my channels but here are a couple of links to some of them. The first is a list of British channels that receive quite well.
My first though when I read this is power.
Are you sure the battery and/or the boost converter can keep up with the 1A current demand of the PAM amplifier and 0.5A peaks of the ESP. Poor (thin/signal) wiring can be a problem too.
Leo..
