internet radio station setup
I have built the internet radio example on an ESP32 from GitHub - baldram/ESP_VS1053_Library: A library for VS1053 MP3 Codec Breakout adapted for Espressif ESP8266 and ESP32 boards..
I have modified the code to hard code station in a struct and added reporting to help see what is going on.
Some stations work, some don't. I'm not sure why. Some urls work when put into a browser but not in the esp32 radio. Some URLs present a user interface where one needs to hit enter to run the station.
e.g. an entry looks like;
title URL Path on site Port
"I love Rio Radio", "eu10.fastcast4u.com", "/iloverio", 80,
client.connect sends "eu10.fastcast4u.com:80" then using a GET we append "/iloverio"
I presume the website sees "eu10.fastcast4u.com:80/iloverio"
This one works.
The BBC entries don't work
"BBC Radio 2", "bbcmedia.ic.llnwd.net", "/stream/bbcmedia_radio2_mf_p", 80,
Although plugging "bbcmedia.ic.llnwd.net:80/stream/bbcmedia_radio2_mf_p" into a browser works.
All but one station says it succeeds in connecting even though they don't play.
Does anyone have ideas for better analysis of the connection.
[1] is there something I'm missing in the info for a station?
[2] how do you figure out the port? I can only assume 80 on new stations.
[3] Any suggestions for how to trigger the user interface on the website to make stations play.
[4] Are there lists or methods for finding the parameters needed to get stations that work?
I love rio had the streaming info on their webpage. https://www.ilove.rio/i-love-rio-radio
The code follows. The code will switch stations every minute for testing.
 Build by CJP 2021-03-02
 from example in VS1053 library https://github.com/baldram/ESP_VS1053_Library
  A simple stream handler to play web radio stations using ESP32 dev board
  Copyright (C) 2018 Vince Gellár (github.com/vincegellar)
  Licensed under GNU GPL v3
  Wiring:
  | VS1053  | ESP8266 |  ESP32   |
  |   SCK   |   D5    |   IO18   |
  |   MISO  |   D6    |   IO19   |
  |   MOSI  |   D7    |   IO23   |
  |   XRST  |   RST   |   EN     |
  |   CS    |   D1    |   D32 XCS
  |   DCS   |   D0    |   D33 XDCS
  |   DREQ  |   D3    |   D35    |
  |   5V    |   5V    |   5V     |
  |   GND   |   GND   |   GND    |
|----vs1053 board--------------per above ------
|   |5v   | 5v   |            VIN   VIN
|   |dgnd | miso |            GND   D19
|   |mosi | sck  |    ==      D23   D18
|   |dreq | xrst |            D35   EN
|   |xcs  | xdcs |            D32   D33
|                    Jack
|                      X
|                      X
|----------------------X------------
  Dependencies:
  -VS1053 library by baldram (https://github.com/baldram/ESP_VS1053_Library)
  -ESP8266Wifi/WiFi
  To run this example define the platformio.ini as below.
  [env:nodemcuv2]
  platform = espressif8266
  board = nodemcuv2
  framework = arduino
  build_flags = -D PIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH
  lib_deps =
    ESP_VS1053_Library
  [env:esp32dev]
  platform = espressif32
  board = esp32dev
  framework = arduino
  lib_deps =
    ESP_VS1053_Library  https://github.com/baldram/ESP_VS1053_Library
  Instructions:
  -Build the hardware
    please find an additional description and Fritzing's schematic here:
    https://github.com/vincegellar/Simple-Radio-Node#wiring
  IDE Settings (Tools):
  -IwIP Variant: v1.4 Higher Bandwidth
  -CPU Frequency: 160Hz
#include "VS1053.h"  //from https://github.com/baldram/ESP_VS1053_Library
// uncomment static_asserts to see what board is used - throws compile time error - so recomment after test
#ifdef ARDUINO_ARCH_ESP8266
//static_assert(-5 / 2 != -2, "ARDUINO_ARCH_ESP8266");
#include <ESP8266WiFi.h>
#define VS1053_CS     D1
#define VS1053_DCS    D0
#define VS1053_DREQ   D3
#endif
#ifdef ARDUINO_ARCH_ESP32
//static_assert(-5 / 2 != -2, "ARDUINO_ARCH_ESP32");
#include <WiFi.h>
#define VS1053_CS     5
#define VS1053_DCS    16
#define VS1053_DREQ   4
#endif
//CJP I have a different ESP32 pinout - overwrite above
#include <WiFi.h>
#define VS1053_CS     32  //XCS label on VS1053
#define VS1053_DCS    33  //XDCS label on VS1053
#define VS1053_DREQ   35
// Default volume
#define VOLUME  99
VS1053 player(VS1053_CS, VS1053_DCS, VS1053_DREQ);
WiFiClient client;
// WiFi settings example, substitute your own
const char *ssid = "EVANOFF24G";
const char *password = "wpawpa987321";
struct station
    char *stationName;
    char *host;
    char *path;
    int   httpPort;
// Few Radio Stations
struct station stations[]={
      "BBC 6 Music",              "bbcmedia.ic.llnwd.net",    "/stream/bbcmedia_6music_mf_p", 80,   //link works in browser-not here
      "Cornucopia Broadcasting",  "8.38.78.173",              "/stream",                      8264, //works
      "Country KX94.7",           "player.listenlive.co/34661", "",                           80,   //need to push play at player.listenlive.co/34661:80/
      "Country KX94.7",           "192.173.28.140",           "/34661",                       80,
      "BBC Radio 1",              "bbcmedia.ic.llnwd.net",    "/stream/bbcmedia_radio1_mf_p", 80,
      "Comet radio",              "http://comet.shoutca.st",  "/1",                           8563, //broken - needs login
      "BBC Radio 2",              "bbcmedia.ic.llnwd.net",    "/stream/bbcmedia_radio2_mf_p", 80,   //this stops cornucopia playing
      "I love Rio Radio",         "eu10.fastcast4u.com",      "/iloverio",                    80,   //nice
      "BBC Radio 4",              "bbcmedia.ic.llnwd.net",    "/stream/bbcmedia_radio4fm_mf_p", 80,
      "BBC World Service",        "bbcwssc.ic.llnwd.net",     "/stream/bbcwssc_mp1_ws-eieuk", 80,
      "Classic FM",               "media-ice.musicradio.com", "/ClassicFMMP3",                80   //working (resets if array size wrong)
int numberOfStations = sizeof(stations)/sizeof(stations[0]);
//CJP suggestions
//https://www.cbc.ca/listen/live-radio?radio_one=toronto&cbc_music=toronto
//for scanning
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 60000;  //1,000= sec 60,000=min
// The buffer size 64 seems to be optimal. At 32 and 128 the sound might be brassy.
uint8_t mp3buff[64];
int stationNumber =-1; //first step is increment to 0
    // Wait for VS1053 and PAM8403 to power up
    // otherwise the system might not start up correctly
    delay(5000);
    // This can be set in the IDE no need for ext library
    // system_update_cpu_freq(160);
    Serial.println("\n\nSimple Radio Node WiFi Radio");
    //startup VS1053
    SPI.begin();
    player.begin();
    player.switchToMp3Mode();
    player.setVolume(VOLUME);
    Serial.print("Connecting to SSID ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        Serial.print(".");
    Serial.println("WiFi connected");
    Serial.print("IP address: ");
    //let loop() connect to wifi - no duplicate code sections
    Serial.print("Number of stations: ");
    Serial.println(numberOfStations);
    startMillis = millis();  //initial start time
    char str3[111]="";
    int rtn=0;
    //if no connection try next station OR for testing if 1 minute is up -note connected still plays
    currentMillis = millis();
    if (!client.connected() || currentMillis - startMillis >= period)
        //if no connection scroll to next one
        stationNumber++;
        if(stationNumber >= numberOfStations) stationNumber=0;
        Serial.print("Requesting stream: ");
        Serial.println(stations[stationNumber].stationName);
        //connect to station else close
        rtn=client.connect(stations[stationNumber].host, stations[stationNumber].httpPort);
        if(rtn==1)
              Serial.println("SUCCESS");
              //send path to website - finish up selection
              client.print(String("GET ") + stations[stationNumber].path + " \r\n\r\n");
        else if(rtn==-1)Serial.println("TIMED_OUT");
        else if(rtn==-2)Serial.println("INVALID_SERVER");
        else if(rtn==-3)Serial.println("TRUNCATED");
        else if(rtn==-4)Serial.println("INVALID_RESPONSE");
          Serial.print("UNKNOWN - Error code: ");
          Serial.println(rtn);
        //scroll through all stations for testing
        if (currentMillis - startMillis >= period)
          rtn=-99; //new station
          Serial.println("1 minute");
          startMillis = millis();  //re-initial start time
        //handle connection errors - close
        if(!rtn)
            sprintf (str3, "GET %s HTTP/1.1\r\nHost:%s \r\nConnection: close\r\n\r\n",
                            stations[stationNumber].stationName,
            client.print(str3);
            Serial.print(str3);
        //this is what is sent by connection
        strcpy(str3,stations[stationNumber].host);
        strcat(str3,":");
        char* ptr = str3 + strlen(str3);
        ultoa(stations[stationNumber].httpPort, ptr, 10);
        strcat(str3,stations[stationNumber].path);
        Serial.print("Trying: ");
        Serial.println(str3);
    //if connected then play
    if (client.available() > 0) {
        uint8_t bytesread = client.read(mp3buff, 64);
        player.playChunk(mp3buff, bytesread);
} //end loop()
I noticed that only MP3 streams were playing so I found an ACC stream and it works.
"Scala Radio", "stream-mz.planetradio.co.uk", "/scalahigh.aac", 80,
