ESP32-S3 Use of both USBs as Serial out
Hello
I fiddle to figure out how I can use both USB as Output
I have no success. Any clue how to do it. Seems easy but no.
My Board is the ESP32-S3-DevKidC-1
With the ESP32-S3-DevKitC-1 board, one of the two USB ports is connected to a USB-to-TTL converter, while the second port connects directly to the microcontroller, leveraging the ESP32's ability to act as a host.
When you enable USB CDC on Boot, Serial0 is connected to the converter, while Serial or SerialUSB becomes the CDC device.
I usually set the board options like this:
  • USB CDC on boot → true
  • USB mode → Hardware CDC and JTAG
  • JTAG adapter → Integrated USB JTAG
this works now no 115200 speed for me
#include <Arduino.h>
#include <USB.h>
// 1. Native USB-CDC (erscheint als COM-Port im PC)
USBCDC USBSerial;
// 2. Echter Hardware-UART auf GPIO43 (TX) + GPIO44 (RX)
HardwareSerial ExtSerial(2);   // UART2 → frei auf beliebige Pins legen
  // ───── Native USB für Debug (PlatformIO Monitor) ─────
  USB.begin();
  USBSerial.begin(115200);
  while (!USBSerial) { delay(10); }
  delay(10000);
  // ───── Externer UART auf GPIO43/44 mit deiner funktionierenden Baudrate ─────
  ExtSerial.begin(57600, SERIAL_8N1, 44, 43);   // RX=44, TX=43
  // Beide Ports begrüßen
  USBSerial.println("\n" "==========================================");
  USBSerial.println("   ESP32-S3 DUAL SERIAL – LÄUFT!");
  USBSerial.println("   USB-CDC → dieser Monitor");
  USBSerial.println("   GPIO43 (TX) + GPIO44 (RX) → 9600 Baud");
  USBSerial.println("==========================================\n");
  ExtSerial.println("Hallo vom echten UART auf GPIO43/44!");
  ExtSerial.println("Das siehst du nur am externen Adapter (9600 Baud)");
  static uint32_t last = 0;
  if (millis() - last >= 2000) {
    last = millis();
    // ───── Ausgabe auf BEIDEN Ports gleichzeitig ─────
    String msg = "Dual-Alive: " + String(millis()) +
                 " ms | Heap: " + String(ESP.getFreeHeap());
    USBSerial.println(msg);         // → PlatformIO Monitor
    ExtSerial.println(msg);         // → GPIO43/44 (9600 Baud)
    // Extra Lebenszeichen nur auf externem Port
    ExtSerial.println("<<< Nur auf GPIO43/44 sichtbar >>>");
  // ───── Loopback: was an GPIO44 reinkommt → auf USB ausgeben ─────
  if (ExtSerial.available()) {
    while (ExtSerial.available()) {
      char c = ExtSerial.read();
      USBSerial.write(c);
    USBSerial.println();
  // ───── Optional: was du in PlatformIO eingibst → an externen Port weiterleiten ─────
  if (USBSerial.available()) {
    while (USBSerial.available()) {
      char c = USBSerial.read();
      ExtSerial.write(c);
