ESP32 SD_MMC Delete failed / Capture first image with unwanted green tint
I am trying to delete every first picture taken when ESP32 wakes up from sleep, as the first picture taken always have a green tint while all images after that stays normal. Any suggest why the delete file failed or how can offset the green tint or how to skip the first image taken?
#include "esp_camera.h"
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include "time.h"
#include <LittleFS.h>
//#define FORMAT_LITTLEFS_IF_FAILED true
// REPLACE WITH YOUR NETWORK CREDENTIALS
const char* ssid = "xxx";
const char* password = "xxx";
// REPLACE WITH YOUR TIMEZONE STRING: https://github.com/nayarsystems/posix_tz_db/blob/master/zones.csv
String myTimezone ="<+08>-8";
// Pin definition for CAMERA_MODEL_AI_THINKER
// Change pin definition if you're using another ESP32 camera module
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
const char* filename1 = "";
// Stores the camera configuration parameters
camera_config_t config;
// Initializes the camera
void configInitCamera(){
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //YUV422,GRAYSCALE,RGB565,JPEG
  config.grab_mode = CAMERA_GRAB_LATEST;
  // Select lower framesize if the camera doesn't support PSRAM
  if(psramFound()){
    config.frame_size = FRAMESIZE_VGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 5; //0-63 lower number means higher quality
    config.fb_count = 5;
    //Serial.println("Using UXGA Format");
    //return;
    config.jpeg_quality = 10;
    //Serial.println("Using SVGA Format");
    //return;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
// Connect to wifi
void  initWiFi(){
  WiFi.begin(ssid, password);
  Serial.println("Connecting Wifi");
    Serial.print(".");
// Function to set timezone
void setTimezone(String timezone){
  Serial.printf("  Setting Timezone to %s\n",timezone.c_str());
  setenv("TZ",timezone.c_str(),1);  //  Now adjust the TZ.  Clock settings are adjusted to show the new local time
  tzset();
// Connect to NTP server and adjust timezone
void initTime(String timezone){
  struct tm timeinfo;
  Serial.println("Setting up time");
  configTime(0, 0, "pool.ntp.org");    // First connect to NTP server, with 0 TZ offset
  if(!getLocalTime(&timeinfo)){
    Serial.println(" Failed to obtain time");
    return;
  Serial.println("Got the time from NTP");
  // Now we can set the real timezone
  setTimezone(timezone);
// Get the picture filename based on the current time
String getPictureFilename(){
  struct tm timeinfo;
    Serial.println("Failed to obtain time");
    return "";
  char timeString[20];
  strftime(timeString, sizeof(timeString), "%Y-%m-%d_%H-%M-%S", &timeinfo);
  Serial.println(timeString);
  String filename = "/picture_" + String(timeString) +".jpg";
  return filename;
// Initialize the micro SD card
void initMicroSDCard(){
  // Start Micro SD card
  Serial.println("Starting SD Card");
  if(!SD_MMC.begin()){
    Serial.println("SD Card Mount Failed");
    return;
  uint8_t cardType = SD_MMC.cardType();
  if(cardType == CARD_NONE){
    Serial.println("No SD Card attached");
    return;
// Take photo and save to microSD card
void takeSavePhoto(){
  // Take Picture with Camera
  camera_fb_t * fb = esp_camera_fb_get();
  //Uncomment the following lines if you're getting old pictures
  //esp_camera_fb_return(fb); // dispose the buffered image
  //fb = NULL; // reset to capture errors
  //fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
  // Path where new picture will be saved in SD Card
  String path = getPictureFilename();
  Serial.printf("Picture file name: %s\n", path.c_str());
  // Save picture to microSD card
  fs::FS &fs = SD_MMC;
  File file = fs.open(path.c_str(),FILE_WRITE);
  if(!file){
    Serial.printf("Failed to open file in writing mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved: %s\n", path.c_str());
    filename1 = path.c_str();
  file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
  Serial.printf("Renaming file %s to %s\r\n", path1, path2);
  if (fs.rename(path1, path2)) {
    Serial.println("- file renamed");
    Serial.println("- rename failed");
void deleteFile(fs::FS &fs, const char * pathway){
  Serial.printf("Deleting file: %s\r\n", pathway);
  if(fs.remove(pathway)){
    Serial.println("- file deleted");
    Serial.println("- delete failed");
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); // disable brownout detector
  delay(2000);
  // Initialize Wi-Fi
  initWiFi();
  // Initialize time with timezone
  initTime(myTimezone);
  // Initialize the camera
  Serial.print("Initializing the camera module...");
  configInitCamera();
  Serial.println("Ok!");
  // Initialize MicroSD
  Serial.print("Initializing the MicroSD card module... ");
  initMicroSDCard();
  takeSavePhoto();
  deleteFile(SD_MMC, filename1);
  takeSavePhoto();
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 0);
  Serial.println("Going to sleep now");
  esp_deep_sleep_start();
  //renameFile(LittleFS, filename1, "test.jpg");
  Serial.println("Take and delete first picture");
  // Take and Save Photo
  takeSavePhoto();
  //Serial.println(filename1);
  delay(10000);
This code is copy from ESP32-CAM Take Photo and Save to MicroSD Card with Date and Time (timestamp) | Random Nerd Tutorials and I modified it for my own project
