I'm having some struggles with a time stamp.
As part of my irrigation project, I've got another side project going for temp and humidity control in my greenhouse. On start up I create a timestamp so I know when the system was last started and I also provide a time now stamp that is created each time the 'webpage' is accessed.
The issue I keep getting is that the 'esp time started' timestamp keeps putting itself in the past as per the screenshot below, even though it's created during the setup stage. I just don't get what's going on.
I've just reuploaded the code using OTA and took a screenshot as soon as it was back online and as you can see, it thinks it started 20:27, but in fact it had only just started, and that can also be seen by how many times it's been though the do stuff loop by looking at the loop count.
I think I'm going a bit code blind here so any help would be greatly appeciated.
The code is long ish, and still WIP...
#include <Arduino.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
#include "time.h"
#include "Wire.h"
#include "Adafruit_SHT31.h"
#include <SPI.h>
#include <WebSerial.h>
int count = 0; // Loop counter
#define WIFI_RETRY 5 // How many times should the WiFi try to connect?
#define NTP_RETRY 5 // How many times should the NTP server try to sync?
bool DEBUG = true; // Used for dubug messages
// Fan stuff
const int circulationFanPWMPin = 32; // PWM Control pin
const int fanRelaySignalPin = 19; // Relay control pin
int fanSpeed = 0;
String Circulation_fanStatus = "Setting up";
// Setting PWM properties
const int freq = 5000;
const int circulationFanChannel = 0;
const int intakeFanChannel = 1;
const int resolution = 8;
// Temp & Humidity Sensor
Adafruit_SHT31 sht31 = Adafruit_SHT31();
float currentTemp = 0;
float currentHumid = 0;
float averageDailyTemp = 0;
float averageDailyHumidity = 0;
float tempRunningTotal = 0;
float humidRunningTotal = 0;
String shtConnected;
bool enableHeater = false;
unsigned long heaterTimer = 0;
unsigned long heaterTimeStart = 0;
unsigned long heaterTimeFinish = 0;
// Wifi stuff
const char *ssid = "The Internet";
const char *password = "Password";
AsyncWebServer server(80); // OTA Async webserver
// Time from NTP server
const char *ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 3600;
// Date & Time variables
int yr = 0;
int mt = 0;
int dy = 0;
int hr = 0;
int mi = 0;
int se = 0;
char dateTime[24];
String dateTimeStamp = "null";
String espStartTimeStamp = "null";
uint8_t miCount = 1;
uint8_t nowMi = 0;
uint8_t nowDy = 0;
// Millis varariables
unsigned long millisNow = 0;
unsigned long millisPrev = 0;
unsigned long minuteCheck = 60000; // check time every 1 min
// Process bools
bool greenhouseProcess = true;
bool circulationFanStatus = false;
// Measure PV voltage
double voltage = 0;
//**fwd declerations**//
void setupTempHumid();
void pmwFanSetup();
void wifiSetup();
void fanStatus();
void setDateTime();
void checkTime();
void checkTempHumid();
void setupOtaUpdateandServer();
void requestTimeStamp();
void recvMsg(uint8_t *data, size_t len);
void setupWebSerial();
void sensorHeater();
void readPvVoltage();
void restart();
wifiSetup(); // Initiate wifi
setDateTime(); // Set date and time from NTP server
pmwFanSetup(); // Set up fan control stuff
setupTempHumid(); // Set up temp and humidity sensor
setupOtaUpdateandServer(); // Set up OTA updates
setupWebSerial();
delay(10);
checkTime(); // Check if 1 min has passed and start & check greenhouse processes
// sensorHeater();
if (greenhouseProcess == true)
count++;
checkTempHumid();
fanStatus();
readPvVoltage();
greenhouseProcess = false; // reset greenHouse Processes
void wifiSetup()
// Connect to Wi-Fi
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print("Connecting to WiFi..");
delay(10000);
int wifi_retry_cnt = 0;
char wifi_retry_message[50];
if ((WiFi.status() == WL_CONNECTED))
Serial.println("...Connected!");
Serial.print("IP Address: ");
if (WiFi.status() != WL_CONNECTED)
Serial.println("...Can't connect to WiFi..trying again"); // Try again
while ((WiFi.status() != WL_CONNECTED) && (wifi_retry_cnt < WIFI_RETRY))
sprintf(wifi_retry_message, "Attempt %i of %i", wifi_retry_cnt, WIFI_RETRY);
Serial.println(wifi_retry_message);
wifi_retry_cnt++;
delay(2000);
void setupTempHumid() // Start Temp & Humidity Sensor
if (!sht31.begin(0x44))
shtConnected = "not connected";
shtConnected = "connected";
currentTemp = (sht31.readTemperature());
currentHumid = (sht31.readHumidity());
sht31.heater(enableHeater);
void setDateTime()
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
struct tm timeinfo;
getLocalTime(&timeinfo);
yr = timeinfo.tm_year + 1900;
int ntp_retry_cnt = 0;
char ntp_retry_message[50];
if (yr == 1970)
Serial.println("Failed to retrieve NTP server time"); // Try again
while ((yr == 1970) && (ntp_retry_cnt < NTP_RETRY))
Serial.print(".");
sprintf(ntp_retry_message, "Attempt %i of %i", ntp_retry_cnt, NTP_RETRY);
Serial.println(ntp_retry_message);
//struct tm timeinfo;
ntp_retry_cnt++;
if (yr != 1970)
mt = timeinfo.tm_mon + 1;
dy = timeinfo.tm_mday;
hr = timeinfo.tm_hour;
mi = timeinfo.tm_min;
nowMi = mi;
nowDy = dy;
se = timeinfo.tm_sec;
sprintf(dateTime, "%02i/%02i/%02i, %02i:%02i:%02i", dy, mt, yr, hr, mi, se);
espStartTimeStamp = dateTime;
Serial.println("NTP server sync successful");
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
{ requestTimeStamp();
request->send(200, "text/plain",
("Esp32 start date & time: " + espStartTimeStamp +
"\nEsp32 date & time now: " + dateTimeStamp +
"\n\nThe circulations fans are: " + Circulation_fanStatus +
"\nFan speed set at :" + fanSpeed +
"\n\nThe temp & humidity sensor is: " + shtConnected +
"\nThe temperature is: " + currentTemp + " C"+
"\nThe humidity is: " + currentHumid + " RH"+
"\nHumidity sensor heater is : " + enableHeater +
"\n\nThe average daily temperature is: " + String(averageDailyTemp,2) + " C (Updated every minute)"+ //updated houly & reset at midnight
"\nThe average daily Humidity is: " + String(averageDailyHumidity,2) + " %RH (Updated every minute)"+ //updated houly & reset at midnight
"\nThe PV charging voltage is currently: " + String(voltage,2) + "v" +
"\n\nLoop count: " + count +
"\nFree heap: " + ESP.getFreeHeap()
AsyncElegantOTA.begin(&server); // Start ElegantOTA
server.begin();
Serial.println("HTTP server started");
void checkTime()
millisNow = millis();
if ((millisNow - millisPrev) >= 200)
{ // check to see if it's a new minute every 200ms
millisPrev = millis();
struct tm timeinfo;
if (mi != nowMi)
nowMi = mi;
void pmwFanSetup()
pinMode(fanRelaySignalPin, OUTPUT); // Pin to control circulation fan relay
digitalWrite(fanRelaySignalPin, LOW);
// configure circulation PWM functionalitites
ledcSetup(circulationFanChannel, freq, resolution);
// attach the channel to the GPIO to be circulation fan
ledcAttachPin(circulationFanPWMPin, circulationFanChannel);
void fanStatus()
// Check time and turn air circulation fans on or off
if (hr >= 10 && hr <= 19)
digitalWrite(fanRelaySignalPin, HIGH);
circulationFanStatus = true;
Circulation_fanStatus = "ON";
// Check temp and adjust intake fan
if (currentTemp > 25 && currentTemp < 27)
ledcWrite(circulationFanChannel, 50);
fanSpeed = 50;
else if (currentTemp > 27 && currentTemp < 29)
ledcWrite(circulationFanChannel, 100);
fanSpeed = 100;
else if (currentTemp >= 30)
ledcWrite(circulationFanChannel, 190);
fanSpeed = 190;
else if (currentTemp <= 25)
Circulation_fanStatus = "OFF";
if ((hr > 19) || (hr < 10))
void checkTempHumid() // Get Temp & Humidity Data
tempRunningTotal += currentTemp;
humidRunningTotal += currentHumid;
averageDailyTemp = (tempRunningTotal / count); // update average daily temp every min
averageDailyHumidity = (humidRunningTotal / count); // update average daily humidity every min
if (dy != nowDy) // midinght reset hour counter
miCount = 1;
count = 1;
nowDy = dy;
tempRunningTotal = currentTemp; // reset temp running total
humidRunningTotal = currentHumid; // reset humid running total
void sensorHeater() // turn on humidity evaporation heater every 10 min for 30sec (built innto sensor)
heaterTimer = millis();
if (((mi % 10 == 0) && (enableHeater == false)) || ((currentHumid >= 85) && (enableHeater == false))) // turn on every 10 mins
enableHeater = true;
heaterTimeStart = millis();
if (DEBUG)
Serial.println("Heater on");
if (((heaterTimer - heaterTimeStart) >= 30000) && (enableHeater == true)) // turn off after 30 seconds
heaterTimeFinish = millis();
if ((heaterTimer - heaterTimeFinish >= 30000) && (enableHeater == true))
if (DEBUG)
Serial.println("Heater off");
voltage = analogRead(33); // Voltage at pin as analoge value
voltage = (-0.000000000000016 * pow(voltage, 4) + 0.000000000118171 * pow(voltage, 3) - 0.000000301211691 * pow(voltage, 2) + 0.001109019271794 * voltage + 0.034143524634089); // Voltage at pin using polynomial equation to adjust ESP32 ADC linearity for better accuracy
voltage = (4095 / 3.3) * voltage; // Convert adjusted voltage back to analoge value
voltage = (voltage) / 4095 * 30 * 247.191 / 220; // Convert to PV voltage
WebSerial.begin(&server);
WebSerial.msgCallback(recvMsg);
struct tm timeinfo;
// Assign vaules to variables used to set RTC below
dateTimeStamp = dateTime;
WebSerial.println("Received Data...");
String inputString = "";
for (int i = 0; i < len; i++)
inputString += char(data[i]);
WebSerial.println(inputString);
if (inputString == "restart")
WebSerial.println("ESP Restarting");
restart();
WebSerial.println("Unknown command");
void restart()
ESP.restart();
