ESP32 UART1 ISSUE
I have ESP32 module,
UART0,UART2 is working both uart transmit and reception.
but uart 1 receive not working(uart1 transmit work).
code is given below .why this happens?
In setup() ,string "started" is come.
#include <HardwareSerial.h>
    Serial2.begin(115200, SERIAL_8N1, 16,17);
    Serial1.begin(115200, SERIAL_8N1,9,10);
     Serial1.println("started");
    while(Serial.available() > 0)
         char byteFromSerial2 = Serial.read();
         Serial.print(byteFromSerial2);
    while (Serial2.available() > 0) {
        char byteFromSerial = Serial2.read();
        Serial2.println(byteFromSerial);
    while (Serial1.available() > 0) {
        char byteFromSerial1 = Serial1.read();
         Serial1.print(byteFromSerial1);
Pins 6 to 11 are used by the ESP32 Flash, not recommended for general use.
if i want to use uart1 ,then how to use?
Perhaps use some other pins that are spare to use.
Format is Serial1.begin(baud-rate, protocol, RX pin, TX pin);
