i have the following sender/transmitter code, when i send the 1st datagram to it (using a program on the PC), it seems to work well, it sends the data to another esp32 and that esp sends back an awnser as an ACK, but then when the PC program sends the 2nd datagram to the esp using the usb/uart serial connection the esp32 doesn't receive anything, anyone has any idea why?
#include <stdio.h>
#include <sys/time.h>
#include <string.h>
#include <HardwareSerial.h>
#define TAMANHO_MAX_TRAMA 144
#define dataPin 21
#define RX2_PIN 16
#define TX2_PIN 17
#define baudRate 250000
#define RXlink_PIN 9
#define TXlink_PIN 10
#define CHUNK_SIZE 32
HardwareSerial SerialConnect ( 2 );
void sendPacket(byte *data, int length){
bool running = true;
while(running){
byte ack[2];
SerialConnect.write(data, length);
SerialConnect.flush();
while(SerialConnect.available() < 2){}
SerialConnect.read();
SerialConnect.readBytes(ack, 2);
if(char(ack[0]) == '1'){
Serial.write(ack,2);
Serial.flush();
running = false;
void setup(){
Serial.begin(baudRate);
SerialConnect.begin(9600, SERIAL_8N1, 16, 17,true);
//Serial1.begin(9600);
void loop(){
byte buffer[TAMANHO_MAX_TRAMA];
int tamanho_trama = 16; //tamanho header + CRC em bytes
if(Serial.available() >= 12){
Serial.readBytes(buffer, 12); //espera receber o header do pacote
tamanho_trama += (int)buffer[11];
int remainingBytes = tamanho_trama - 12;
int bytesRead = 0;
while (remainingBytes > 0) {
int chunkSize = min(remainingBytes, CHUNK_SIZE);
if (Serial.available() > 0){
int bytesReadThisRound = Serial.readBytes(buffer + 12 + bytesRead, chunkSize);
bytesRead += bytesReadThisRound;
remainingBytes -= bytesReadThisRound;
// Ensure that the entire payload + CRC is read before sending
if (bytesRead == tamanho_trama - 12) {
// Send the complete message
sendPacket(buffer, tamanho_trama);
