Hello,
I am using Do-It ESP32 dev kit1 for ESP communication with CAN protocol.
The communication works properly when the communication is healthy.
But if the communication link breaks or receptive device is disconnected the ESP 32 stuck at can tx command after two or three attempt of transmission.
Please find code for reference.
#include <Arduino.h>
#include <ESP32CAN.h>
#include <CAN_config.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <esp_task_wdt.h>
#define LED_INDICATIONS
#define WDT_TIMEOUT 1
WiFiMulti wifiMulti;
//how many clients should be able to telnet to this ESP32
#define MAX_SRV_CLIENTS 1
const char* ssid = "D-Link_DIR-615"; //
const char* password = ""; //"05424993"
IPAddress local_IP(172, 16, 5, 235);
IPAddress gateway(172, 16, 5, 1);
IPAddress subnet(255, 255, 0, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
WiFiServer server(23);
WiFiClient serverClients[MAX_SRV_CLIENTS];
CAN_device_t CAN_cfg; // CAN Config
const int rx_queue_size = 10; // Receive Queue size
uint8_t i;
uint16_t reqId = 0;
uint16_t resId = 0;
uint8_t DLC = 0;
uint8_t SID = 0;
uint8_t resLen = 0;
uint8_t resLenRecv = 0;
uint8_t resp[255];
//indication leds on ESP32
#ifdef LED_INDICATIONS
#define WIFI_COMM_OK_LED 32 //green
#define CLIENT_CONN_LED 22 //blue
#define CAN_RX_LED 23 //blue
#endif
pinMode(CAN_RX_LED, OUTPUT);
pinMode(WIFI_COMM_OK_LED, OUTPUT);
pinMode(CLIENT_CONN_LED, OUTPUT);
digitalWrite(CAN_RX_LED, HIGH);
digitalWrite(WIFI_COMM_OK_LED, HIGH);
digitalWrite(CLIENT_CONN_LED, HIGH);
digitalWrite(CAN_RX_LED,LOW);
digitalWrite(WIFI_COMM_OK_LED,LOW);
digitalWrite(CLIENT_CONN_LED,LOW);
#endif
Serial.println("Starting...");
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println("STA Failed to configure");
wifiMulti.addAP(ssid, password);
//wifiMulti.addAP("ssid_from_AP_2", "your_password_for_AP_2");
//wifiMulti.addAP("ssid_from_AP_3", "your_password_for_AP_3");
Serial.println("Connecting Wifi ");
for (int loops = 10; loops > 0; loops--) {
esp_task_wdt_reset();
if (wifiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected ");
Serial.print("IP address: ");
else {
Serial.println(loops);
if (wifiMulti.run() != WL_CONNECTED)
Serial.println("WiFi connect failed");
ESP.restart();
server.begin();
server.setNoDelay(true);
Serial.print("Ready! Use 'telnet ");
Serial.print(WiFi.localIP());
Serial.println(" 23' to connect");
CAN_cfg.speed = CAN_SPEED_500KBPS;
CAN_cfg.tx_pin_id = GPIO_NUM_5;
CAN_cfg.rx_pin_id = GPIO_NUM_4;
CAN_cfg.rx_queue = xQueueCreate(rx_queue_size, sizeof(CAN_frame_t));
/* esp_task_wdt_init(WDT_TIMEOUT, true);
esp_task_wdt_add(NULL);
esp_task_wdt_reset();*/
// Init CAN Module
ESP32Can.CANInit();
//esp_task_wdt_disable();
Serial.println("CAN Ready");
CAN_frame_t rx_frame;
//check if there are any new clients
digitalWrite(WIFI_COMM_OK_LED, HIGH); //WiFi connected so turn ON led
#endif
if (server.hasClient()) {
for (i = 0; i < MAX_SRV_CLIENTS; i++) {
//find free/disconnected spot
if (!serverClients[i] || !serverClients[i].connected()) {
if (serverClients[i]) serverClients[i].stop();
serverClients[i] = server.available();
if (!serverClients[i]) Serial.println("available broken");
Serial.print("New client: ");
Serial.print(i);
Serial.print(' ');
Serial.println(serverClients[i].remoteIP());
if (i >= MAX_SRV_CLIENTS) {
//no free/disconnected spot so reject
server.available().stop();
//check clients for data
if (serverClients[i] && serverClients[i].connected()) {
#endif
if (serverClients[i].available()) {
//printf("\n");
Serial.println("WiFi Data Received");
size_t len = serverClients[i].available();
Serial.print("len=");
Serial.println(len);
uint8_t sbuf[len];
serverClients[i].readBytes(sbuf, len);
Serial.println("check length");
// Send CAN Message
if (len == 13)
CAN_frame_t tx_frame;
ESP32Can.CANInit();
Serial.println("Can initialize");
tx_frame.FIR.B.FF = CAN_frame_std;
tx_frame.MsgID = sbuf[0] << 8 | sbuf[1]; //
reqId = tx_frame.MsgID;
resId = sbuf[2] << 8 | sbuf[3];
tx_frame.FIR.B.DLC = sbuf[4];
DLC = sbuf[4];
SID = sbuf[6];
tx_frame.data.u8[0] = sbuf[5]; //
tx_frame.data.u8[1] = sbuf[6]; //
tx_frame.data.u8[2] = sbuf[7]; //
tx_frame.data.u8[3] = sbuf[8]; //
tx_frame.data.u8[4] = sbuf[9]; //
tx_frame.data.u8[5] = sbuf[10]; //
tx_frame.data.u8[6] = sbuf[11]; //
tx_frame.data.u8[7] = sbuf[12]; //
Serial.println("Going to send...");
//CAN_cfg.rx_queue = xQueueCreate(rx_queue_size, sizeof(CAN_frame_t));
resLenRecv = 0;
resLen = 0;
int Stat= ESP32Can.CANWriteFrame(&tx_frame);
Serial.print("Tx Stat=");
Serial.println(Stat);
uint32_t freeheap=ESP.getFreeHeap();
Serial.print("freeheap=");
Serial.println(freeheap);
printf(" Request to 0x%08X, DLC %d, Data ", tx_frame.MsgID, tx_frame.FIR.B.DLC);
for (int i = 0; i < tx_frame.FIR.B.DLC; i++) {
printf("0x%02X ", tx_frame.data.u8[i]);
printf("\n");
Serial.println("Data Sent.");
else {
digitalWrite(CLIENT_CONN_LED, LOW);
#endif
if (serverClients[i]) {
// Receive next CAN frame from queue
if (xQueueReceive(CAN_cfg.rx_queue, &rx_frame, 3 * portTICK_PERIOD_MS) == pdTRUE) {
digitalWrite(CAN_RX_LED, HIGH); //received some frame on CAN so blink led
#endif
//filter out messages based on the receive ID set
// if ( rx_frame.MsgID == 0x0778 || rx_frame.MsgID == 0x07ED || rx_frame.MsgID == 0x0748 ||
// rx_frame.MsgID == 0x077F || rx_frame.MsgID == 0x07AB || rx_frame.MsgID == 0x0758 ||
// rx_frame.MsgID == 0x07EF || rx_frame.MsgID == 0x07BA || rx_frame.MsgID == 0x07AA ) {
if ( rx_frame.MsgID == resId ) {
if (rx_frame.FIR.B.FF == CAN_frame_std) {
printf("New standard frame");
else {
printf("New extended frame");
if (rx_frame.FIR.B.RTR == CAN_RTR) {
printf(" RTR from 0x%08X, DLC %d\r\n", rx_frame.MsgID, rx_frame.FIR.B.DLC);
else {
printf(" Response from 0x%08X, DLC %d, Data ", rx_frame.MsgID, rx_frame.FIR.B.DLC);
for (int i = 0; i < rx_frame.FIR.B.DLC; i++) {
printf("0x%02X ", rx_frame.data.u8[i]);
printf("\n");
if (rx_frame.data.u8[0] == 0x10) {
//Serial.println("In equal to 0x10");
//First frame of multi-part response received.
resLen = rx_frame.data.u8[1];
for (int i = 1; i < rx_frame.FIR.B.DLC; i++) {
resp[resLenRecv] = rx_frame.data.u8[i];
resLenRecv++;
//Send flow control message
tx_frame.MsgID = reqId;
tx_frame.FIR.B.DLC = DLC;
tx_frame.data.u8[0] = 0x30;
tx_frame.data.u8[1] = 0x00;
tx_frame.data.u8[2] = 0x00;
tx_frame.data.u8[3] = 0x00;
tx_frame.data.u8[4] = 0x00;
tx_frame.data.u8[5] = 0x00;
tx_frame.data.u8[6] = 0x00;
tx_frame.data.u8[7] = 0x00;
printf("\n");
else if (rx_frame.data.u8[0] < 0x10) {
//Serial.println("In less than 0x10");
resLen = rx_frame.data.u8[0];
if (rx_frame.data.u8[1] == 0x7F) {
//NACK received
if ((rx_frame.data.u8[2] == SID) && (rx_frame.data.u8[3] == 0x78)) {
//Serial.println("NRC received. Waiting for positive response.");
else {
resLenRecv++;
else {
resLenRecv++;
// for (int i = 1; i < rx_frame.FIR.B.DLC; i++) {
// resp[resLenRecv] = rx_frame.data.u8[i];
// resLenRecv++;
else if (rx_frame.data.u8[0] > 0x20) {
//Serial.println("In greater than 0x20");
resLenRecv++;
if (resLenRecv > resLen) {
//push UART data to all connected telnet clients
// byte MsgID_DLC[3] = { highByte(rx_frame.MsgID), lowByte(rx_frame.MsgID), rx_frame.FIR.B.DLC };
// serverClients[i].write(MsgID_DLC, 3);
//serverClients[i].write(rx_frame.data.u8, rx_frame.FIR.B.DLC);
//serverClients[i].write(resp, resLenRecv);
serverClients[i].write(resp, resLenRecv); //SID
delay(1);
resLenRecv = 0;
resLen = 0;
digitalWrite(CAN_RX_LED, LOW); //received some frame on CAN so blink led
#endif
else{
// Serial.println("Data not received...");
// &rx_frame=0;
else {
digitalWrite(WIFI_COMM_OK_LED, LOW); //WiFi not connected so turn OFF led
#endif
Serial.println("WiFi not connected!");
