ESP32 -W5500 WebServer_ESP32_W5500 Library
Hi to all
I want to use a ESP32 module with a W5500 lite.
The problem that I have is when I to try compile any example, I get a compiller error
libraries\WebServer_ESP32_W5500\src/w5500/esp32_w5500.h:28:27: fatal error: hal/spi_types.h: No such file or directory
compilation terminated.
I found a library called esp-idf master that has a lot of modules, and I wrote them into folder that the compiller say, but it did not work
Can you tell me where can be the issue ???
Thanks a lot in advance
As your topic is not a tutorial, it has been moved to a more suitable location on the forum.
Feel free to write a tutorial once you have mastered your problem.
have a look at w5500-lite-problem-in-esp32-solved
So sorry Sterretje . In did not find the correct class for this post.
Thank you Horace,
but the problem I have is that I can not compile any samples.
For example, after install the WebServer_ESP32_W5500
https://github.com/khoih-prog/WebServer_ESP32_W5500
(Them problem occurs with others libraries)
I try compile any sample program. for example: Hello Server
but I can not compile it.
I have this error:
In file included from C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500\src/WebServer_ESP32_W5500.h:88:0,
from C:\Users\Omar\AppData\Local\Temp.arduinoIDE-unsaved2023121-11192-12jwqc3.cg1m\HelloServer\HelloServer.ino:39:
C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500\src/w5500/esp32_w5500.h:28:27: fatal error: hal/spi_types.h: No such file or directory
I think that it must have a very simple solution, but I tired to find it for 4 days without results
Thanks in advance
Omar
I can build C:\Users\bb\Documents\Arduino\libraries\WebServer_ESP32_W5500-main\examples\HelloServer without problems, e.g.
Using library WebServer_ESP32_W5500 at version 1.5.3 in folder: C:\Users\bb\Documents\Arduino\libraries\WebServer_ESP32_W5500-main
Using library WiFi at version 2.0.0 in folder: C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\libraries\WiFi
Using library WebServer at version 2.0.0 in folder: C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\libraries\WebServer
Using library FS at version 2.0.0 in folder: C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\libraries\FS
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch5/bin/xtensa-esp32-elf-size" -A "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino-sketch-D28855BCA7D78E9A0BD3073F43A394C7/HelloServer.ino.elf"
Sketch uses 778133 bytes (59%) of program storage space. Maximum is 1310720 bytes.
Global variables use 44068 bytes (13%) of dynamic memory, leaving 283612 bytes for local variables. Maximum is 327680 bytes.
what Tools>Board have you selected? I used
in the Arduino IDE select File>Preferences and enable "Verbose output during Compiling and upload" then compile your program again
upload the full error messages as text
what ESP32 board are you using?
can you upload and run a simple program such as blink?
Hi Horace
I have select ESP32 Dev Module too
I ussing ESP-WROOM-32 module and a W5500 Lite
The compiler result is this
Using board 'esp32' from platform in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3
Using core 'esp32' from platform in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3
Detecting libraries used...
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-54325A7B9ED70F1EED630E962782E944\\sketch\\HelloServer.ino.cpp" -o nul
Alternatives for WebServer_ESP32_W5500.h: [WebServer_ESP32_W5500@1.5.3]
ResolveLibrary(WebServer_ESP32_W5500.h)
  -> candidates: [WebServer_ESP32_W5500@1.5.3]
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "-IC:\\Users\\Omar\\Documents\\Arduino\\libraries\\WebServer_ESP32_W5500\\src" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-54325A7B9ED70F1EED630E962782E944\\sketch\\HelloServer.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.0]
ResolveLibrary(WiFi.h)
  -> candidates: [WiFi@1.0]
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "-IC:\\Users\\Omar\\Documents\\Arduino\\libraries\\WebServer_ESP32_W5500\\src" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\libraries\\WiFi\\src" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-54325A7B9ED70F1EED630E962782E944\\sketch\\HelloServer.ino.cpp" -o nul
                 from C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-868-186ulsd.vnchf\HelloServer\HelloServer.ino:39:
Alternatives for hal/spi_types.h: []
ResolveLibrary(hal/spi_types.h)
  -> candidates: []
Using library WebServer_ESP32_W5500 at version 1.5.3 in folder: C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500
Using library WiFi at version 1.0 in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3\libraries\WiFi
exit status 1
Compilation error: exit status 1
but....oops !
When I try compile a Examples -> Built in examples ->01.Basics -> Blink
i get this
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-3A5CCF7F5C3198D21248C6075240A41B\\sketch\\Blink.ino.cpp.o"
C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-868-1g8596p.qhzd\Blink\Blink.ino: In function 'void setup()':
C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-868-1g8596p.qhzd\Blink\Blink.ino:28:11: error: 'LED_BUILTIN' was not declared in this scope
   pinMode(LED_BUILTIN, OUTPUT);
C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-868-1g8596p.qhzd\Blink\Blink.ino: In function 'void loop()':
C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-868-1g8596p.qhzd\Blink\Blink.ino:33:16: error: 'LED_BUILTIN' was not declared in this scope
   digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
exit status 1
Compilation error: 'LED_BUILTIN' was not declared in this scope
If I try for example
Examples -> Examples for ESP 32 Dev Modules -> ESP32 -> Time -> SimpleTime
The program compiles OK and run on the module too (it connect to wifi and get de time)
I wait for you comments
Im am very confused at this time. :roll_eyes:
Omar
Don't worry; it's corrected. The two categories that most of us are sensitive about are (description from the "about topic" in each)
  1. Installation and Troubleshooting
  1. Introductory Tutorials
it appears LED_BUILTIN is not defined for the ESP32 - you can define it so
#define LED_BUILTIN 2
and attach a LED to GPIO2
did you instal the WebServer_ESP32_W5500-main.zip library using Sketch>Include Library>Add ZIP library, e.g.
also have a look at the documentation WebServer_ESP32_W5500
what version of the Arduino IDE are you using?
yes !!!!
was resolve the "created by own issue" with blink sketch. :ok_hand:
I am ussing the IDE version 2.0.3
About Library, I have installed some WebServer_ESP32_W5500-mail versions with the same results.
I have downloaded again the WebServer_ESP32_W5500-mail from
then add it with Sketchs -> Include Library -> add .ZIP library menu option
And then it was installed into libraries folder
C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500-main
imagen
But again, the compiler error persists when I compile "HelloServer" example)
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-76149ACDC4C269DA38C6F7D202449B24\\sketch\\HelloServer.ino.cpp" -o nul
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "-IC:\\Users\\Omar\\Documents\\Arduino\\libraries\\WebServer_ESP32_W5500-main\\src" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-76149ACDC4C269DA38C6F7D202449B24\\sketch\\HelloServer.ino.cpp" -o nul
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/config" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_trace" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/app_update" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/asio" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bootloader_support" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/bt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/coap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/console" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/driver" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-tls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_event" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_client" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_http_server" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ethernet" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/expat" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fatfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freemodbus" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/freertos" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/heap" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/idf_test" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/jsmn" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/json" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/libsodium" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/log" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/lwip" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mbedtls" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mdns" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/micro-ecc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/mqtt" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/newlib" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nghttp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/nvs_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/openssl" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protobuf-c" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/protocomm" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/pthread" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/sdmmc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/soc" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spi_flash" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/spiffs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcp_transport" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/ulp" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/vfs" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wear_levelling" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp32-camera" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/esp-face" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\cores\\esp32" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\variants\\esp32" "-IC:\\Users\\Omar\\Documents\\Arduino\\libraries\\WebServer_ESP32_W5500-main\\src" "-IC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.3\\libraries\\WiFi\\src" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-76149ACDC4C269DA38C6F7D202449B24\\sketch\\HelloServer.ino.cpp" -o nul
  -> candidates: []
In file included from C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500-main\src/WebServer_ESP32_W5500.h:88:0,
                 from C:\Users\Omar\AppData\Local\Temp\.arduinoIDE-unsaved2023121-876-4jj48m.nh63f\HelloServer\HelloServer.ino:39:
C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500-main\src/w5500/esp32_w5500.h:28:27: fatal error: hal/spi_types.h: No such file or directory
compilation terminated.
Using library WebServer_ESP32_W5500 at version 1.5.3 in folder: C:\Users\Omar\Documents\Arduino\libraries\WebServer_ESP32_W5500-main
exit status 1
it sound as any related library is not installed into my Arduino ide, because it can not find the hal/spi_types.h file, but I can not say if it is true
By the way this line says thay can not find the file under hal/ folder, but /hal is not created into library
imagen
The includes into ..\src/w5500/esp32_w5500.h is
imagen
For this I have changed <hal/spi_types.h> with "hal/spi_types.h" but the file cannot be found by compiller
Thanks a lot @horace for you assistance
Omar
as an experiment I deleted the Documents>Arduino folder
I then reinstalled WebServer_ESP32_W5500-main.zip so it is the only library in the libraries folder
the HelloServer compiles and starts OK
Start HelloServer on ESP32_DEV with ESP32_W5500
WebServer_ESP32_W5500 v1.5.3 for core v2.0.0+
[EWS] Default SPI pinout:
[EWS] SPI_HOST: 2
[EWS] MOSI: 23
[EWS] MISO: 19
[EWS] SCK: 18
[EWS] CS: 5
[EWS] INT: 4
[EWS] SPI Clock (MHz): 25
[EWS] =========================
ETH Started
E (3414239) w5500.mac: w5500_send_command(186): Send command timeout
E (3414239) w5500.mac: emac_w5500_start(399): Issue OPEN command failed
E (3414240) w5500.mac: emac_w5500_set_link(589): W5500 start failed
I don't have a W5500 connected so so it then gives timeout errors etc
perhaps you have corrupt or conflicting libraries installed
try deleting the Documents>Arduino folder and reinstalling WebServer_ESP32_W5500-main.zip
Hi @horace ..Thank you !
I deleted the arduino folder and create a new and inslall the library
I have the same result: HelloServer.ino (and others WebServer_ESP32_W5000 Examples sketcks, cannot be compiled).
the only library I have now is WebServer_ESP32_W5500-main
imagen
The "error" is when file esp32_w5500.h call to spi_types.h shows this into line 28
imagen
#include <hal/spi_types.h>
but i can not find spi_types.h file (and hal\folder neither) under WebServer_ESP21_W5500-main folder
imagen
Please, can you send an image from ? Do you have the same ???
..\Documents\Arduino\libraries\WebServer_ESP32_W5500-main\src/w5500/esp32_w5500.h
And make a search for
spi_types.h
to see where is this file into your ide
I think that you have this file but I do not
Thank you !!!
Omar
the <hal/spi_types.h> file appears to be in
C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\tools\sdk\esp32\include\hal\include\hal\spi_types.h
perhaps you need to uninstal the IDE and reinstal it?
Yes, @horace I have progressed thanks you !!!
I have installed the ide again and now I have this file (and others) in that folder Thank you again
Now The problem is that the program esptools.exe is not into the folder
C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5\
The compiller "says" that need this exe file, but it is not there....
I read that the ESP Installer board bust install esptools too but it do not do it
I am trying install the esptools.exe outside the IDE but I did not can do it
I will tell you if I can resolve this new issue
Thanks a lot !!
have a look at Install esptool.exe on Windows
...Thanks Horace...Again and again
but as I can see, I never will finish install all that I need to run this :no_mouth:
My python/linux knowleges are less than the Arduino IDE
But I'll try
Into link you sent me says that i must run this command into cmd windows
rmdir /s /q build_tmp
mkdir build_tmp
C:\Python35\scripts\pyinstaller ^
--onefile ^
--specpath build_tmp ^
--workpath build_tmp\build ^
--distpath build_tmp\dist ^
C:\esp-idf\components\esptool_py\esptool\esptool.py
Then I install first pyinstaller (because I did not have this) and then run the command. I have copy esptool.py into my folder
'C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5
and then run
mkdir build_tmp
C:\Users\Omar\pyinstaller ^
--onefile ^
this create a folder
C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5\build_tmp\dist
where esptool.exe is create
If I run the compiller thay says
Using board 'esp32' from platform in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
Using core 'esp32' from platform in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
cmd /c if exist "C:\\Users\\Omar\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023122-18068-b4cabg.4yxg\\HelloServer\\partitions.csv" COPY /y "C:\\Users\\Omar\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023122-18068-b4cabg.4yxg\\HelloServer\\partitions.csv" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\partitions.csv"
cmd /c if not exist "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\partitions.csv" if exist "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\partitions.csv" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\partitions.csv"
cmd /c if not exist "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\partitions.csv" COPY "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\tools\\partitions\\default.csv" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\partitions.csv"
        1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\Omar\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023122-18068-b4cabg.4yxg\\HelloServer\\bootloader.bin" ( COPY /y "C:\\Users\\Omar\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023122-18068-b4cabg.4yxg\\HelloServer\\bootloader.bin" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\HelloServer.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\bootloader.bin" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\HelloServer.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-C8A029F18E246B2E454F63B4C06A17DE\\HelloServer.ino.bootloader.bin" "C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
'C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5/esptool.exe' is not recognized as an internal or external command,
operable program or batch file.
exit status 1
Then I try by copy esptool.exe into the folder where the compiller go to look
but the compiller freeze when run
after that estool.exe is erased from folder
imagen
I'm so sorry if my questions are very dumb and for the posts extensions.
But I really lost with this
Omar
think it would be worth attempting to move this to Instalation and Troubleshooting
Hi @horace
I have insalles a cleaned IDE version (by erase the Arduino15 folder) , and the compile make a lot of steps more.
It is a great advance But now I get this compiler error
Compiling core...
Using precompiled core: C:\Users\Omar\AppData\Local\Temp\arduino-core-cache\core_c124052a3ebdbbed37100a91051abdef.a
Linking everything together...
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E/HelloServer.ino.map" "-LC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7/tools/sdk/esp32/lib" "-LC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7/tools/sdk/esp32/ld" "-LC:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7/tools/sdk/esp32/qio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\sketch\\HelloServer.ino.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer_ESP32_W5500-main\\w5500\\esp32_w5500.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer_ESP32_W5500-main\\w5500\\esp_eth\\esp_eth_mac_w5500.c.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer_ESP32_W5500-main\\w5500\\esp_eth\\esp_eth_phy_w5500.c.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer_ESP32_W5500-main\\w5500\\esp_eth\\esp_eth_spi_w5500.c.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiClient.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiServer.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WiFi\\WiFiUdp.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer\\Parsing.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer\\WebServer.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\WebServer\\detail\\mimetable.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\FS\\FS.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E\\libraries\\FS\\vfs_api.cpp.o" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-core-cache\\core_c124052a3ebdbbed37100a91051abdef.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp_diagnostics -lrtc_store -lesp_insights -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lesp_insights -lcbor -lesp_diagnostics -lrmaker_common -lmqtt -lrtc_store -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E/HelloServer.ino.elf"
"C:\\Users\\Omar\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 8MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E/HelloServer.ino.bin" "C:\\Users\\Omar\\AppData\\Local\\Temp\\arduino-sketch-57404CE1743BBC09F56464635446603E/HelloServer.ino.elf"
usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]
               [--before {default_reset,no_reset}]
               [--after {hard_reset,soft_reset,no_reset}] [--no-stub]
               [--trace]
               {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}
esptool: error: unrecognized arguments: --elf-sha256-offset C:\Users\Omar\AppData\Local\Temp\arduino-sketch-57404CE1743BBC09F56464635446603E/HelloServer.ino.elf
Using library WiFi at version 2.0.0 in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\WiFi
Using library WebServer at version 2.0.0 in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\WebServer
Using library FS at version 2.0.0 in folder: C:\Users\Omar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\FS
exit status 2
it sound as syntax line is not good created....I have search with google and some say that the problem can be for any additional space into sentence line. Have you any idea over this ???
I'm thinking that I never will can work with this modules :pensive:
Hi to all !
I want to tell to all that after a lot of try, I have been able to install the ESP32/W5500 libraries, and can work with them
Step to install
1- Clear Arduino IDE (ver 2.0.3) by delete the forders library,
2- Go to Espressif site, go to Window (manual installation)
and follow all steps thay this section shows.
Important: At least for me, the step 2 has had an important delay to start. Be patient.
After that I installed the W5500 as library as allways, and all works fine.
I would like this can be useful to someone
Omar
