FQBN: esp32:esp32:esp32da:UploadSpeed=512000
Using board 'esp32da' from platform in folder: C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0
Using core 'esp32' from platform in folder: C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0
cmd /c if exist "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\partitions.csv" COPY /y "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\partitions.csv" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\partitions.csv"
cmd /c if not exist "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\partitions.csv" if exist "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\variants\\esp32da\\partitions.csv" COPY "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\variants\\esp32da\\partitions.csv" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\partitions.csv"
cmd /c if not exist "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\partitions.csv" COPY "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\tools\\partitions\\default.csv" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\bootloader.bin" ( COPY /y "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\bootloader.bin" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\ESP32.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\variants\\esp32da\\bootloader.bin" ( COPY "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\variants\\esp32da\\bootloader.bin" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\ESP32.ino.bootloader.bin" ) ELSE ( "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\ESP32.ino.bootloader.bin" "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\build_opt.h" COPY /y "C:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32\\build_opt.h" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\build_opt.h"
cmd /c if not exist "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\build_opt.h" type nul > "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\build_opt.h"
cmd /c type nul > "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5/file_opts"
cmd /c COPY /y "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32\\sdkconfig" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\sdkconfig"
1 file(s) copied.
Detecting libraries used...
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5\sketch\ESP32.ino.cpp -o nul
Alternatives for Nextion.h: [ITEADLIB_Arduino_Nextion-master]
ResolveLibrary(Nextion.h)
-> candidates: [ITEADLIB_Arduino_Nextion-master]
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5\sketch\ESP32.ino.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexButton.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexCheckbox.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexCrop.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexDualStateButton.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexGauge.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexGpio.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexHardware.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexHotspot.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexNumber.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexObject.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexPage.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexPicture.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexProgressBar.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRadio.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexScrolltext.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexSlider.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexText.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexTimer.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexTouch.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexVariable.cpp -o nul
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexWaveform.cpp -o nul
Generating function prototypes...
C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/defines -IC:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32 -iprefix C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/include/ @C:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/flags/includes -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32/qio_qspi/include -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\cores\esp32 -IC:\Users\hmontesino\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0\variants\esp32da -Ic:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h @C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5/file_opts C:\Users\hmontesino\AppData\Local\arduino\sketches\830CE1DF3B15DEB91D0E9159854699A5\sketch\ESP32.ino.cpp -o C:\Users\hmontesino\AppData\Local\Temp\4004908208\sketch_merged.cpp
C:\Users\hmontesino\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\hmontesino\AppData\Local\Temp\4004908208\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=512000,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32/flags/defines" "-IC:\\Users\\hmontesino\\OneDrive - Vector Power\\Documents\\Electronic\\Arduino-Nextion\\ESP32" -iprefix "C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32/include/" "@C:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32/flags/includes" "-IC:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-083aad99-v2\\esp32/qio_qspi/include" "-IC:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\cores\\esp32" "-IC:\\Users\\hmontesino\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.0\\variants\\esp32da" "-Ic:\\Users\\hmontesino\\Documents\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "@C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5/build_opt.h" "@C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5/file_opts" "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\sketch\\ESP32.ino.cpp" -o "C:\\Users\\hmontesino\\AppData\\Local\\arduino\\sketches\\830CE1DF3B15DEB91D0E9159854699A5\\sketch\\ESP32.ino.cpp.o"
C:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32\ESP32.ino: In function 'void setup()':
C:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32\ESP32.ino:61:15: error: invalid conversion from 'void (*)()' to 'NexTouchEventCb' {aka 'void (*)(void*)'} [-fpermissive]
61 | on.attachPush(ledOn);
| void (*)()
In file included from c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master/Nextion.h:22,
from C:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32\ESP32.ino:7:
c:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master/NexTouch.h:74:37: note: initializing argument 1 of 'void NexTouch::attachPush(NexTouchEventCb, void*)'
74 | void attachPush(NexTouchEventCb push, void *ptr = NULL);
C:\Users\hmontesino\OneDrive - Vector Power\Documents\Electronic\Arduino-Nextion\ESP32\ESP32.ino:62:16: error: invalid conversion from 'void (*)()' to 'NexTouchEventCb' {aka 'void (*)(void*)'} [-fpermissive]
62 | off.attachPush(ledOff);
| void (*)()
Using library ITEADLIB_Arduino_Nextion-master in folder: C:\Users\hmontesino\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master (legacy)
exit status 1
Compilation error: invalid conversion from 'void (*)()' to 'NexTouchEventCb' {aka 'void (*)(void*)'} [-fpermissive]
