I'm trying to embed it in an extremely thin enclosure and need it to be as thin as possible. Oddly I can't find a version of it without the soldered on headers. Does anyone happen to know where to get that?
And in what sense is this a "development board"? Is there a stripped down pro version somewhere?
The "development board" adds a few other convenient features - voltage regulator, USB UART, user-friendly form-factor etc. I suppose, yeah, if you can solder surface mount (kind of fiddly but not that hard if you take your time) you could go it alone with just the ESP32.
wrybread:
If that board (or similar) is too 'thick' then you will need to uses the bare bones ESP32 WROOM as suggested by @GypsumFantastic.
You will need to add a regulator\capacitors and a couple of switches. You done need a USB\Serial converter, just use an external one.
A bare module needs supporting parts. No way around that,and that could make thing bulky again.
You could ofcourse remove the pinstrips.
The plastic part slides off with a bit of gentle force, and then you can remove the pins one by one with a soldering iron and tweezers.
Leo..
