ESP32: Wrong boot mode detected
I have just purchased an ESP32 Cam module. I set it up and loaded two separate sketches which worked first time. When I loaded a third program (time lapse) that worked but I couldn't load anything after that one. I get the error message:
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0xb)! The chip needs to be in download mode.
I think it might have something to do with the code of that final, third program:
 *   ESP32 Hacks (c) 2021 Marcio Teixeira                                   *
 *   https://github.com/marciot/esp32-hacks                                 *
 *   This program is free software: you can redistribute it and/or modify   *
 *   it under the terms of the GNU General Public License as published by   *
 *   the Free Software Foundation, either version 3 of the License, or      *
 *   (at your option) any later version.                                    *
 *   This program is distributed in the hope that it will be useful,        *
 *   but WITHOUT ANY WARRANTY; without even the implied warranty of         *
 *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the          *
 *   GNU General Public License for more details.                           *
 *   To view a copy of the GNU General Public License, go to the following  *
 *   location: <http://www.gnu.org/licenses/>.                              *
#include <SD_MMC.h>
#include "esp_camera.h"
#define MINUTES_BETWEEN_PHOTOS 0.5
// Pins for ESP32-CAM
#define FLASH_PIN         4
// Camera pins
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
bool startMicroSD() {
  Serial.print("Starting microSD... ");
  // Pin 13 needs to be pulled-up
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/sd_pullup_requirements.html#pull-up-conflicts-on-gpio13
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  if(SD_MMC.begin("/sdcard", true)) {
    Serial.println("OKAY");
    return true;
    Serial.println("FAILED");
    return false;
bool startCamera() {
  // Turn off the flash
  pinMode(FLASH_PIN, OUTPUT);
  digitalWrite(FLASH_PIN, LOW);
  // Initialize the camera hardware
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // Set resolution based on whether we have extra memory
  if(psramFound()){
    Serial.println("PSRAM found. Maximum XGA resolution supported.");
    config.frame_size = FRAMESIZE_XGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    Serial.println("PSRAM not found. Maximum SVGA resolution supported.");
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Start the camera
  Serial.print("Starting camera... ");
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    return false;
    return true;
void takePhoto(String filename) {
  // Take a photo and get the data
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Unable to take a photo");
    return;
  // Make sure it is a JPEG
  if (fb->format != PIXFORMAT_JPEG) {
     Serial.println("Capture format not JPEG");
     esp_camera_fb_return(fb); // Return the photo data
     return;
  // Save the picture to the SD card
  File file = SD_MMC.open(filename.c_str(), "w");
  if(file) {
    Serial.println("Saving " + filename);
    file.write(fb->buf, fb->len);
    file.close();
    // Momentarily blink the flash
    digitalWrite(FLASH_PIN, HIGH);
    delay(100);
    Serial.println("Unable to write " + filename);
  // Return the picture data
  // Initialize the peripherals
  while(!Serial) delay(100);
  startMicroSD();
  startCamera();
  delay(5000); // Delay 5 seconds before first photo
  // Keep a count of the number of photos we have taken
  static int number = 0;
  number++;
  // Construct a filename that looks like "/photo_0001.jpg"
  String filename = "/photo_";
  if(number < 1000) filename += "0";
  if(number < 100)  filename += "0";
  if(number < 10)   filename += "0";
  filename += number;
  filename += ".jpg";
  takePhoto(filename);
  // Delay until the next photo
  delay(MINUTES_BETWEEN_PHOTOS * 60 * 1000);
I've searched the web and lots of people are saying to press the "boot" button when uploading a sketch. My module doesn't have one!
Here's a link to the one that I bought:
https://www.ebay.co.uk/itm/254810284860
Any help will be greatly appreciated
Thanks
Certain I/O pins have to be in specific states for boot to work. If you added hardware which violates this the boot will fail. I would check for hardware attached to these pins. See for example
https://docs.espressif.com/projects/esptool/en/latest/esp32/advanced-topics/boot-mode-selection.html
or any of the other search results.
Same problem:
first attempt with an ESP32 having previously used the ESP8266 with no issues - or at least none that were not of my own making. Google and you will find many posts of others with the same problem - cannot upload to an esp32.
I'm using an esp32 from AZDelivery, generating my code with VScode, compiling and uploading using the arduino IDE 1.8.19 running under linux mint.
I had uploaded a couple of example sketches without issue, but then I found I could not upload with the stated error.
Online suggestions are pressing the boot and reset buttons on upload - didn't work, connecting a 1 - 3uF capacitor between EN and Gnd - didn't work.
What did work:
DO NOT USE GPIO2
I had a simple sketch using analogread on a potentiometer connected to GPIO2.
After much head-scratching (a couple of days). I found this:
https://docs.espressif.com/projects/esptool/en/latest/esp32/advanced-topics/boot-mode-selection.html#boot-mode
It says:
GPIO2 must also be either left unconnected/floating, or driven Low, in order to enter the serial bootloader.
Which was not true in my case. Changed to using GPIO15 and leaving GPIO2 disconnected - the problem went away, no problem uploading sketches.
Posted in the hope that it will prevent someone else spending a couple of WTF days on why can't I upload?
Now my next problem, use an MS wireless 3500 mouse and MS ergonomic wireless keyboard - yes in spite of running linux, I like some M$ hardware :slightly_smiling_face:. With the esp32 plugged in the keyboard is verging on the un-usable - missing keystrokes or deciding to auto repeat (or worse auto-delete). Not a problem I had with the esp8266. This on a ThinkCentre M720Q. Probably should be subject to another post on another forum, but open to offers...
I found that sketches wouldn't upload if there was a micro SD card in the module. Removing this, the sketches would upload seamlessly. Sorted!
