Failed uploading: uploading error: exit status 1
First, I tried uploading my code:
#include <WiFi.h>
#include <esp_wifi.h>
void readMacAddress(){
  uint8_t baseMac[6];
  esp_err_t ret = esp_wifi_get_mac(WIFI_IF_STA, baseMac);
  if (ret == ESP_OK) {
    Serial.printf("%02x:%02x:%02x:%02x:%02x:%02x\n",
                  baseMac[0], baseMac[1], baseMac[2],
                  baseMac[3], baseMac[4], baseMac[5]);
    Serial.println("Failed to read MAC address");
void setup(){
  WiFi.mode(WIFI_STA);
  WiFi.STA.begin();
  Serial.print("[DEFAULT] ESP32 Board MAC Address: ");
  readMacAddress();
void loop(){
It's for an ESP32 dev board and it's to find the MAC address of them to use esp32 now. It gave me this error message:
FQBN: esp32:esp32:esp32:UploadSpeed=115200
Using board 'esp32' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
Using core 'esp32' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
cmd /c if exist "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\partitions.csv" COPY /y "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\partitions.csv"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\partitions.csv" if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\partitions.csv"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\partitions.csv" COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\partitions\\default.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\partitions.csv"
cmd /c IF EXIST "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\bootloader.bin" ( COPY /y "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\Code_Drone.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\Code_Drone.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\Code_Drone.ino.bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
cmd /c if exist "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\build_opt.h" COPY /y "G:\\Disques partagés\\Drone\\Code\\Code_Drone\\build_opt.h" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\build_opt.h"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\build_opt.h" type nul > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\build_opt.h"
cmd /c type nul > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts"
cmd /c COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\sdkconfig" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\sdkconfig"
        1 fichier(s) copi�(s).
Detecting libraries used...
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2\sketch\Code_Drone.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@3.2.0]
ResolveLibrary(WiFi.h)
  -> candidates: [WiFi@3.2.0]
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2\sketch\Code_Drone.ino.cpp -o nul
Alternatives for Network.h: [Networking@3.2.0]
ResolveLibrary(Network.h)
  -> candidates: [Networking@3.2.0]
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2\sketch\Code_Drone.ino.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\AP.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\STA.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFi.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFiAP.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFiGeneric.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFiMulti.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFiSTA.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src\WiFiScan.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkClient.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkEvents.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkInterface.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkManager.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkServer.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src\NetworkUdp.cpp -o nul
Generating function prototypes...
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IG:\Disques partagés\Drone\Code\Code_Drone -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network\src @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2\sketch\Code_Drone.ino.cpp -o C:\Users\Utilisateur\AppData\Local\Temp\2312711516\sketch_merged.cpp
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Utilisateur\AppData\Local\Temp\2312711516\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\sketch\\Code_Drone.ino.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\sketch\\Code_Drone.ino.cpp.o"
Compiling libraries...
Compiling library "WiFi"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFiScan.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiScan.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFiSTA.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiSTA.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\AP.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\AP.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFiMulti.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiMulti.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFi.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFi.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFiGeneric.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiGeneric.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\WiFiAP.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiAP.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src\\STA.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\STA.cpp.o"
Compiling library "Networking"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkServer.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkServer.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkInterface.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkInterface.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkUdp.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkUdp.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkManager.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkManager.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkClient.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkClient.cpp.o"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IG:\\Disques partagés\\Drone\\Code\\Code_Drone" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\WiFi\\src" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\libraries\\Network\\src\\NetworkEvents.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkEvents.cpp.o"
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts"
Using precompiled core: C:\Users\Utilisateur\AppData\Local\arduino\cores\c5e283ef6a66c76f8239ddb799dfcf89\core.a
cmd /c type nul > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/file_opts"
Linking everything together...
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.map" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/lib" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/ld" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi" -Wl,--wrap=esp_panic_handler "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_flags" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_scripts" -Wl,--start-group "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\sketch\\Code_Drone.ino.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\AP.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\STA.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkClient.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkEvents.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkInterface.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkManager.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkServer.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Network\\NetworkUdp.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\cores\\c5e283ef6a66c76f8239ddb799dfcf89\\core.a" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.elf"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.elf"
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\gen_esp32part.exe" -q "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.partitions.bin"
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\Insights" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\gen_insights_package.exe" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2" Code_Drone.ino "G:\\Disques partagés\\Drone\\Code\\Code_Drone"
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\libraries\\ESP_SR" if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\esp_sr\\srmodels.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2\\srmodels.bin"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32 merge_bin -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.bootloader.bin" 0x8000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.partitions.bin" 0xe000 "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.bin"
esptool.py v4.8.1
Wrote 0x400000 bytes to file C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.merged.bin, ready to flash to offset 0x0
Using library WiFi at version 3.2.0 in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi
Using library Networking at version 3.2.0 in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Network
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-size" -A "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.elf"
Sketch uses 881370 bytes (67%) of program storage space. Maximum is 1310720 bytes.
Global variables use 44960 bytes (13%) of dynamic memory, leaving 282720 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3/esptool.exe" --chip esp32 --port "COM6" --baud 115200  --before default_reset --after hard_reset write_flash  -z --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.bootloader.bin" 0x8000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.partitions.bin" 0xe000 "C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\9F670241A68C702222364935E85C8CA2/Code_Drone.ino.bin"
esptool.py v4.8.1
Serial port COM6
Connecting...
A serial exception error occurred: Write timeout
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed uploading: uploading error: exit status 1
Then I tried with a new sketch:
And it gave me this error message:
FQBN: esp32:esp32:esp32:UploadSpeed=115200
Using board 'esp32' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
Using core 'esp32' from platform in folder: C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\partitions.csv" COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\partitions.csv"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\partitions.csv" if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\partitions.csv"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\partitions.csv" COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\partitions\\default.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\bootloader.bin" ( COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch_apr8b.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch_apr8b.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch_apr8b.ino.bootloader.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.8.1
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\build_opt.h" COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b\\build_opt.h" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\build_opt.h"
cmd /c if not exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\build_opt.h" type nul > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\build_opt.h"
cmd /c type nul > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/file_opts"
cmd /c COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\sdkconfig" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sdkconfig"
        1 fichier(s) copi�(s).
Detecting libraries used...
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IC:\Users\Utilisateur\AppData\Local\Temp\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\sketch_apr8b -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 @C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1\sketch\sketch_apr8b.ino.cpp -o nul
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2411/bin/xtensa-esp32-elf-g++ -c @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/defines -IC:\Users\Utilisateur\AppData\Local\Temp\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\sketch_apr8b -iprefix C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/include/ @C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/flags/includes -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.4-2f7dcd86-v1\esp32/qio_qspi/include -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32 -IC:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\variants\esp32 @C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/build_opt.h @C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/file_opts C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1\sketch\sketch_apr8b.ino.cpp -o C:\Users\Utilisateur\AppData\Local\Temp\3095078487\sketch_merged.cpp
C:\Users\Utilisateur\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Utilisateur\AppData\Local\Temp\3095078487\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=115200,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/defines" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b" -iprefix "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/include/" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/includes" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi/include" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\cores\\esp32" "-IC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/build_opt.h" "@C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/file_opts" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch\\sketch_apr8b.ino.cpp" -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch\\sketch_apr8b.ino.cpp.o"
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/file_opts"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.map" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/lib" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/ld" "-LC:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/qio_qspi" -Wl,--wrap=esp_panic_handler "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_flags" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_scripts" -Wl,--start-group "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\sketch\\sketch_apr8b.ino.cpp.o" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\cores\\c5e283ef6a66c76f8239ddb799dfcf89\\core.a" "@C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.elf"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.elf"
esptool.py v4.8.1
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\gen_esp32part.exe" -q "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/partitions.csv" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.partitions.bin"
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\libraries\\Insights" "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\gen_insights_package.exe" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1" sketch_apr8b.ino "C:\\Users\\Utilisateur\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202538-11356-15xjxiw.pwr4\\sketch_apr8b"
cmd /c if exist "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\libraries\\ESP_SR" if exist "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\esp_sr\\srmodels.bin" "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1\\srmodels.bin"
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32 merge_bin -o "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.bootloader.bin" 0x8000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.partitions.bin" 0xe000 "C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.bin"
esptool.py v4.8.1
Wrote 0x400000 bytes to file C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.merged.bin, ready to flash to offset 0x0
"C:\\Users\\Utilisateur\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2411/bin/xtensa-esp32-elf-size" -A "C:\\Users\\Utilisateur\\AppData\\Local\\arduino\\sketches\\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.elf"
Sketch uses 278758 bytes (21%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20500 bytes (6%) of dynamic memory, leaving 307180 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3/esptool.exe" --chip esp32 --port "COM6" --baud 115200  --before default_reset --after hard_reset write_flash  -z --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.bootloader.bin" 0x8000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.partitions.bin" 0xe000 "C:\Users\Utilisateur\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\Utilisateur\AppData\Local\arduino\sketches\663F4C42FC53DBFD1953F09D69C187D1/sketch_apr8b.ino.bin"
esptool.py v4.8.1
Serial port COM6
Connecting...
Hi, @zachary_13
The first code compiled:
Sketch uses 885072 bytes (67%) of program storage space. Maximum is 1310720 bytes.
Global variables use 44380 bytes (13%) of dynamic memory, leaving 283300 bytes for local variables. Maximum is 327680 bytes.
If a blank will not compile it sounds like the IDE has a problem, I would delete the IDE and re-install it.
Tom.... :smiley: :+1: :coffee: :australia:
Thanks for the advice. I will try it tomorrow.
I don't know much, I have just started. But on the IDE it said that both code compiled but they didn't upload on the esp32 dev board. I downloaded the IDE an hour before the test. Also, I have tried the first code on an other computer and in a different location (i don't know if it makes a difference).
Finally, it was a driver issue. everything works fine now.
