Hey, I am not a total beginner with Arduino programming, but neither am I an expert. I am trying to use tensorflow-lite on a esp32_cam to classify images. I defined the following sub-tasks that i need to solve:
- Take photo
- Reduce size of photo to (e.g.) 28x28 pixels grayscale
- run inference with trained model
For now I am stuck between point 1 and 2 and cannot get it solved. What i have done so far: I save an image into buffer using esp_camera_fb_get().
Afterwards I put the values from the buffer inside a 2D array. However, when I print out some of these values, they never become 0 nor 255, even though I coverd the whole lens or put a bright light source close to it.
I have four questions:
- How do I correctly record an image?
- How can I convert it into a 2D array?
- How can I downsample the size from (e.g.) 160x120 to 28x28?
- how can I correctly Serial.print() each pixel value to copy the values and plot them on my computer (e.g. with python matplotlib) and check if everything works alright?
#define CAMERA_MODEL_AI_THINKER
#include <esp_camera.h>
#include "camera_pins.h"
#define FRAME_SIZE FRAMESIZE_QQVGA
#define WIDTH 160
#define HEIGHT 120
uint16_t img_array [HEIGHT][WIDTH] = { 0 };
bool setup_camera(framesize_t);
void frame_to_array(camera_fb_t * frame);
void print_image_shape(camera_fb_t * frame);
bool capture_image();
Serial.println(setup_camera(FRAME_SIZE) ? "OK" : "ERR INIT");
if (!capture_image()) {
Serial.println("Failed capture");
delay(2000);
return;
//print_features();
delay(3000);
bool setup_camera(framesize_t frameSize) {
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_GRAYSCALE;
config.frame_size = frameSize;
config.jpeg_quality = 12;
config.fb_count = 1;
bool ok = esp_camera_init(&config) == ESP_OK;
sensor_t *sensor = esp_camera_sensor_get();
sensor->set_framesize(sensor, frameSize);
return ok;
bool capture_image() {
camera_fb_t * frame = NULL;
frame = esp_camera_fb_get();
print_image_shape(frame);
frame_to_array(frame);
esp_camera_fb_return(frame);
if (!frame)
return false;
return true;
void print_image_shape(camera_fb_t * frame){
// print shape of image and total length (=heigth*width)
Serial.print("Width: ");
Serial.print(frame->width);
Serial.print("\tHeigth: ");
Serial.print(frame->height);
Serial.print("\tLength: ");
Serial.println(frame->len);
void frame_to_array(camera_fb_t * frame){
int len = frame->len;
char imgBuffer[frame->len];
int counter = 0;
int h_counter = 0;
int w_counter = 0;
// write values from buffer into 2D Array
for (int h=0; h < HEIGHT; h++){
//Serial.println(h);
for (int w=0; w < WIDTH; w++){
//Serial.println(w);
int position = h*(len/HEIGHT)+w;
//Serial.println(position);
img_array[h][w] = {frame->buf[position]};
//Serial.print(img_array[h][w]);
//Serial.print(",");
//delay(2);
//Serial.println("Current frame:");
Serial.println("=====================");
camera_pin.h:
#if defined(CAMERA_MODEL_WROVER_KIT)
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 21
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 19
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 5
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#elif defined(CAMERA_MODEL_ESP_EYE)
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define RESET_GPIO_NUM 15
#define XCLK_GPIO_NUM 27
#define SIOD_GPIO_NUM 25
#define Y9_GPIO_NUM 19
#define Y8_GPIO_NUM 36
#define Y7_GPIO_NUM 18
#define Y5_GPIO_NUM 5
#define Y4_GPIO_NUM 34
#define Y3_GPIO_NUM 35
#define Y2_GPIO_NUM 32
#define VSYNC_GPIO_NUM 22
#define HREF_GPIO_NUM 26
#define PCLK_GPIO_NUM 21
#elif defined(CAMERA_MODEL_M5STACK_WIDE)
#define SIOD_GPIO_NUM 22
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#else
#error "Camera model not selected"
#endif
