ESP32cam access pixeldata
Im using ESP32cam and are trying to access the pixeldata. I cannot figure out how.
Basically I want to downsample the image to say 50 x 50 pixels then access the pixeldata for further processing in an arduino sketch.
This is my code so far:
#include "esp_camera.h"
#include <WiFi.h>
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char *ssid = "******";
const char *password = "******";
void startCameraServer();
void setupLedFlash(int pin);
void getPixels();
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_CIF;
  config.pixel_format = PIXFORMAT_GRAYSCALE;
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if (config.pixel_format == PIXFORMAT_JPEG)
    if (psramFound())
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK)
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t *s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID)
    s->set_vflip(s, 1);       // flip it back
    s->set_brightness(s, 1);  // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
  s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash(LED_GPIO_NUM);
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  getPixels();
void getPixels()
  // disable white balance and white balance gain
  sensor_t *sensor = esp_camera_sensor_get();
  sensor->set_whitebal(sensor, 0); // 0 = disable , 1 = enable
  sensor->set_awb_gain(sensor, 0); // 0 = disable , 1 = enable
  camera_fb_t *fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  if (!fb)
    Serial.println("Camera capture failed");
    return;
  for (int i = 0; i < fb->len; i++)
    Serial.print(fb->buf[i]);
    Serial.print(",");
  Serial.println(F("\n\n---------------------\nPREPARE TO CAPTURE TO FILE\n"));
  delay(600);
  esp_camera_fb_return(fb);
The pixels are in the 'fb->buf' array. What problem are you having?
if you can go higher than 50x50, then look at the existing frame size formats, you possibly won't have to down sample yourself (FRAMESIZE_96X96 will be 96 x 96 pixels)
First of all I get a lot of numbers ... 57600 numbers to be exact. When using settings like this:
Second is that Im not sure how to read it. Ideal would be to get it in Decimal Code RGB values or in this case grayscale values. But that is indeed not the case. (but I eventually need it in color rather then grayscale though).
I cannot see any direct difference in the output if I hold my hand over the camera lens and pointing it straight into a lamp. Ideal that would return the grayscale color of 0 or something very bright.
So how shall I read it? I actually want to read it on every frame to be able to analyse the image. I basically are going to use the image to trigger ledstripes.
Yes perfect in my case would be to downsample the image all the way down to something like 15 x 15 pixels. Not sure how to do it though.
Actually, the buffer size for those settings is 118400 bytes.
Take a look in 'sensor.h' for the framesize_t enum:
typedef enum {
    FRAMESIZE_96X96,    // 96x96
    FRAMESIZE_QQVGA,    // 160x120
    FRAMESIZE_QCIF,     // 176x144
    FRAMESIZE_HQVGA,    // 240x176
    FRAMESIZE_240X240,  // 240x240
    FRAMESIZE_QVGA,     // 320x240
    FRAMESIZE_CIF,      // 400x296
    FRAMESIZE_HVGA,     // 480x320
    FRAMESIZE_VGA,      // 640x480
    FRAMESIZE_SVGA,     // 800x600
    FRAMESIZE_XGA,      // 1024x768
    FRAMESIZE_HD,       // 1280x720
    FRAMESIZE_SXGA,     // 1280x1024
    FRAMESIZE_UXGA,     // 1600x1200
    // 3MP Sensors
    FRAMESIZE_FHD,      // 1920x1080
    FRAMESIZE_P_HD,     //  720x1280
    FRAMESIZE_P_3MP,    //  864x1536
    FRAMESIZE_QXGA,     // 2048x1536
    // 5MP Sensors
    FRAMESIZE_QHD,      // 2560x1440
    FRAMESIZE_WQXGA,    // 2560x1600
    FRAMESIZE_P_FHD,    // 1080x1920
    FRAMESIZE_QSXGA,    // 2560x1920
    FRAMESIZE_INVALID
} framesize_t;
So, 'FRAMESIZE_CIF' is 400x296 pixels.
Next, find the pixformat_t enum in the same file:
typedef enum {
    PIXFORMAT_RGB565,    // 2BPP/RGB565
    PIXFORMAT_YUV422,    // 2BPP/YUV422
    PIXFORMAT_YUV420,    // 1.5BPP/YUV420
    PIXFORMAT_GRAYSCALE, // 1BPP/GRAYSCALE
    PIXFORMAT_JPEG,      // JPEG/COMPRESSED
    PIXFORMAT_RGB888,    // 3BPP/RGB888
    PIXFORMAT_RAW,       // RAW
    PIXFORMAT_RGB444,    // 3BP2P/RGB444
    PIXFORMAT_RGB555,    // 3BP2P/RGB555
} pixformat_t;
So, 'PIXFORMAT_GRAYSCALE' is 1 byte per pixel gray scale.
Once a picture is taken, you can get the size info from the camera_fb_t struct pointed to by your 'fb' pointer variable. See esp_camera.h for the declaration of that struct:
typedef struct {
    uint8_t * buf;              /*!< Pointer to the pixel data */
    size_t len;                 /*!< Length of the buffer in bytes */
    size_t width;               /*!< Width of the buffer in pixels */
    size_t height;              /*!< Height of the buffer in pixels */
    pixformat_t format;         /*!< Format of the pixel data */
    struct timeval timestamp;   /*!< Timestamp since boot of the first DMA buffer of the frame */
} camera_fb_t;
So, with the settings you used, fb->buf will point to a buffer of 118400 bytes each of which specifies the gray scale of a single pixel (400 x 296 = 118400).
There are various ways of downsampling an image - some are more picture aware than others.
Say you have a picture of 300x300,
One very crude algorithm is just to throw away data ➜ read every 20th pixel horizontally and vertically. That’s quick and would do if there are not lots of changes happening in your original picture.
Another option would be to read a 20x20 square and do some math over those pixels to extract the dominant color of the samples window - for example just taking the average of the 400 components. Again that would be somewhat OK if there are no huge variations in the samples.
There are tons of math techniques being applied - it’s quite a field of study especially for upsampling (here is an article about this) and you can find tons more on line and also code implementation for the various techniques like averaging, maximum, or minimum pooling which are often used. These methods involve grouping several pixels together and calculating a single value to represent that group in the downsampled image.
The choice of the "best" downsampling algorithm depends on your specific requirements and the trade-offs you are willing to make between computational complexity and image quality.
Thanks for replys! Thanks for these hints for downsampling. But I am still a bit confused about the result. I cannot see that the result vary at all when I am for example holding my hand over the lense.
What, exactly, are you looking at?
You print out the captured grey scale values for each pixel in each frame, so what are those values?
It is useful to collect and print a histogram for a frame. This code does so, and also shows you how to calculate the (x,y) position of each pixel (not used in this code):
  // for each pixel in image
long  npix = 0;
unsigned long histogram[256] = {0};
  for (size_t i = 0; i < frame->len; i++) {
    x = i % WIDTH;                   // x position in image
    y = floor(i / WIDTH);            // y position in image
    unsigned int pixel = frame->buf[i];                     // pixel value
    histogram[pixel]++;
    // show data
    //  Serial.print((unsigned int)pixel);
    //  Serial.print("\n");
    npix++;
  Serial.print("***** ");  //separator
  Serial.print(npix);
  Serial.print(" data lines\n");
  for (int i = 0; i < 256; i++) {
    Serial.print(i);
    Serial.print("\t");
    Serial.println(histogram[i]);
These are the result from the camera looking straight into a white, bright part of a screen. The length is 96*96=9216
77,76,76,78,81,81,82,78,85,86,86,87,88,90,90,93,94,94,93,93,95,94,100,94,99,98,99,99,103,104,103,106,101,107,106,105,106,107,104,107,109,110,108,110,108,109,110,114,111,112,114,112,113,108,112,114,110,110,110,110,110,104,101,100,97,94,100,100,99,96,99,103,104,103,97,95,86,78,69,65,55,49,42,49,58,74,83,97,87,65,48,25,18,16,17,18,78,85,86,86,88,90,91,92,93,94,98,98,100,103,104,104,107,109,111,111,114,116,117,119,122,123,123,126,128,129,130,132,132,133,135,135,136,136,137,139,140,140,141,141,142,145,142,142,145,147,147,147,147,147,147,146,147,147,146,145,143,141,140,137,135,137,139,142,142,140,139,139,138,132,124,112,99,88,75,70,60,57,57,64,82,111,127,133,127,105,67,36,20,18,17,17,82,84,84,85,88,89,92,94,94,96,98,100,104,102,105,105,109,111,112,115,116,118,120,121,124,125,126,129,129,130,133,135,136,137,138,139,139,140,142,142,143,143,145,146,146,148,140,120,149,149,151,150,150,151,150,149,152,151,151,148,146,145,146,144,145,146,147,150,150,146,144,141,131,122,106,89,78,73,66,63,63,64,68,76,90,114,132,143,138,126,91,52,26,18,17,17,92,94,97,97,98,102,104,105,109,109,112,112,114,115,117,120,121,125,125,126,127,130,131,132,137,138,138,140,143,144,145,146,149,150,150,151,153,155,155,155,157,156,158,158,159,161,162,174,163,162,163,162,163,163,163,164,164,164,163,161,160,159,160,161,160,161,161,159,156,150,139,128,112,101,87,73,67,65,69,70,78,87,98,103,112,128,142,150,152,142,114,72,28,21,19,18,99,102,104,106,107,109,111,113,116,116,119,119,121,123,123,126,127,129,131,131,133,135,136,138,140,144,144,145,147,149,151,152,152,155,156,156,157,159,159,160,160,160,160,162,164,164,165,165,167,166,166,166,167,166,166,166,167,167,167,164,164,163,165,165,163,163,158,152,143,131,115,100,81,75,69,66,65,66,70,80,92,107,117,120,125,133,144,150,153,148,127,86,44,24,18,18,101,102,106,107,109,111,112,114,116,118,120,119,122,123,124,125,127,129,131,132,134,135,137,139,141,142,143,145,147,149,150,152,154,153,156,155,156,157,158,159,160,160,161,161,163,163,164,163,163,163,164,164,164,164,165,165,164,165,163,163,162,161,161,158,154,146,137,124,107,91,81,70,64,63,64,63,67,69,75,88,102,116,124,127,127,131,137,143,146,143,129,93,55,26,16,17,93,95,98,100,101,102,102,102,107,105,107,108,110,111,114,115,116,119,120,122,124,126,126,128,131,133,134,136,137,138,139,141,142,145,144,145,146,147,148,149,151,151,152,151,153,152,153,153,154,154,153,154,154,154,154,154,155,154,155,154,153,150,144,137,126,112,101,84,70,65,61,61,56,55,56,63,72,77,85,99,109,118,122,123,122,125,129,132,138,136,127,101,58,30,18,16,87,88,90,92,94,96,95,97,102,101,101,103,106,108,110,111,112,116,118,120,120,124,124,126,128,131,132,133,135,135,136,137,140,142,141,143,144,144,146,148,148,149,149,149,151,151,150,152,152,152,152,152,154,153,153,154,154,154,154,154,152,145,134,120,103,89,77,68,60,59,58,58,58,58,62,72,90,100,108,114,120,126,125,126,125,126,129,133,137,140,135,117,74,42,22,16,90,90,92,97,98,100,102,103,101,107,111,110,112,114,115,117,119,122,124,126,128,129,131,134,136,139,140,143,143,144,144,145,148,150,151,151,153,154,155,155,158,158,158,159,159,160,161,162,163,162,163,165,165,165,164,165,164,165,166,166,161,153,138,117,101,92,82,75,68,66,63,65,72,76,84,100,114,123,129,129,131,133,135,137,138,137,137,143,149,152,149,138,110,61,28,18,103,106,109,111,112,115,116,117,118,119,121,123,125,126,128,130,132,134,135,138,140,141,143,145,147,149,151,153,154,155,156,157,159,159,161,162,163,164,165,166,166,167,169,169,169,169,171,172,172,172,173,173,173,173,174,173,173,174,173,174,169,159,143,126,116,105,92,80,71,69,72,77,88,97,106,115,123,130,132,131,132,135,138,142,141,141,142,146,152,155,155,146,124,79,36,21,108,108,113,114,114,116,117,119,120,121,123,124,128,130,131,132,134,136,137,140,142,143,146,147,148,152,153,155,156,157,158,158,161,163,164,165,165,166,166,168,168,169,172,172,172,173,173,174,174,174,175,175,175,175,175,176,176,176,176,177,172,162,150,136,128,115,99,86,78,79,86,96,111,118,121,123,124,124,123,122,123,127,133,137,140,141,140,145,149,152,154,150,131,96,47,24,106,107,109,112,112,113,116,116,119,120,122,121,123,125,126,129,132,132,134,136,138,140,142,143,146,147,148,150,150,154,156,155,156,157,157,159,159,160,161,163,161,163,163,163,163,164,166,166,165,165,167,167,167,167,167,168,167,167,166,166,165,157,147,132,121,108,95,83,79,83,94,108,119,123,121,116,112,111,108,107,109,111,113,117,124,127,128,131,136,140,143,142,130,98,54,26,93,96,98,98,100,99,102,104,108,106,109,112,114,116,117,120,122,123,124,127,128,130,132,134,135,136,138,140,141,144,146,148,149,148,149,152,152,152,154,154,154,156,156,157,156,158,158,158,160,160,159,159,160,160,159,160,160,159,159,159,159,153,143,129,112,96,90,84,89,102,113,122,126,123,119,112,107,105,104,103,104,102,106,110,114,117,121,125,130,135,138,138,130,110,64,33,92,92,94,96,96,100,101,102,104,105,108,111,113,113,116,118,120,123,125,126,128,129,129,133,135,138,139,140,142,144,145,147,148,149,150,152,152,153,153,155,155,156,157,158,159,158,160,160,159,160,161,161,161,162,161,161,163,163,162,163,163,160,150,135,110,92,91,97,110,124,128,134,131,126,118,113,110,110,108,108,107,107,108,110,113,117,121,127,133,137,144,143,139,124,83,49,100,106,104,105,109,109,111,113,114,116,120,121,123,125,128,129,131,135,136,137,140,142,145,146,148,151,151,154,155,156,156,158,160,162,163,165,165,165,166,167,169,170,170,172,172,172,173,176,173,175,175,175,176,176,177,176,176,177,176,177,177,174,167,150,126,106,108,127,142,148,151,150,141,134,128,125,124,124,122,121,121,120,118,119,120,123,130,137,146,151,154,157,153,142,115,68,113,113,115,115,118,118,120,121,124,124,127,128,130,133,134,137,139,141,141,143,146,148,150,152,154,156,158,158,162,162,163,165,164,166,167,169,169,171,171,172,174,174,175,176,177,177,178,180,179,181,181,182,181,182,181,181,182,182,181,181,180,180,175,158,133,115,123,141,151,155,154,149,140,133,129,127,127,126,125,124,123,123,121,121,122,126,135,144,151,155,156,157,156,147,128,87,113,114,115,117,117,120,121,122,124,126,128,129,131,133,136,138,141,142,144,147,149,150,150,151,155,156,158,159,162,163,164,165,166,167,167,169,170,172,173,173,175,174,176,176,176,178,180,178,178,180,180,179,180,180,180,180,180,180,179,178,179,178,174,161,146,132,134,146,152,155,150,145,134,127,126,125,124,124,121,121,120,120,122,126,130,134,140,146,148,150,150,150,150,146,131,95,104,104,106,110,110,110,111,114,115,115,118,120,124,125,127,129,131,133,135,138,139,141,143,144,145,147,149,150,151,152,153,153,156,156,157,159,159,159,161,163,163,164,164,163,165,167,167,167,166,168,167,167,167,166,168,168,167,166,167,167,167,166,164,155,145,135,134,141,143,144,140,133,123,118,116,116,115,114,113,115,117,120,124,128,132,135,137,137,135,135,134,135,139,138,127,101,95,97,97,100,101,104,105,106,108,110,112,115,117,119,121,125,126,128,130,133,134,137,139,139,142,142,144,147,147,148,149,150,152,152,153,155,155,155,156,158,159,160,160,160,161,162,162,162,164,163,164,165,165,165,164,164,165,164,164,164,163,162,161,158,152,146,143,143,143,142,139,132,121,117,117,116,115,117,120,123,128,133,136,137,138,137,132,127,118,116,123,128,135,138,131,114,98,99,100,103,103,107,109,110,114,116,115,118,122,123,124,127,129,132,134,137,138,142,143,144,147,149,149,150,152,152,154,155,158,158,161,160,160,162,165,165,166,167,168,169,168,169,170,171,172,172,173,173,174,176,174,173,175,174,175,175,174,173,172,172,168,163,156,156,156,154,148,141,131,128,127,132,135,140,145,148,152,152,151,147,142,135,124,112,100,100,112,128,142,148,146,131,110,113,115,117,117,119,123,124,124,127,129,131,134,135,139,141,143,145,147,150,151,153,155,157,158,161,162,163,164,166,167,168,170,172,172,174,175,176,177,178,180,181,181,181,182,183,184,184,186,185,186,186,187,187,187,186,186,186,186,187,186,185,185,184,180,174,168,165,163,163,157,151,145,145,148,151,155,158,161,161,160,154,148,139,128,113,97,88,83,79,97,121,141,152,154,143,115,116,118,119,121,122,126,127,127,130,133,133,137,140,141,143,146,149,151,153,154,156,158,159,160,162,165,166,167,168,169,171,173,174,175,176,177,179,179,180,182,183,184,184,185,185,186,187,188,189,189,189,189,188,189,189,188,189,189,189,187,187,187,186,182,177,170,167,164,164,162,159,156,157,161,163,163,164,160,155,145,134,122,111,97,84,81,75,74,74,91,115,135,149,154,148,117,117,118,120,122,123,125,127,129,130,131,134,136,140,141,142,146,147,148,150,152,153,154,157,159,161,162,162,164,164,167,168,167,169,171,173,173,175,175,176,176,176,177,178,179,180,180,180,179,182,183,182,182,181,182,180,181,181,180,178,178,177,177,178,175,170,165,160,160,160,159,159,158,159,157,154,149,142,131,118,104,84,75,69,65,66,66,65,68,73,83,103,122,135,143,141,105,100,104,109,110,111,113,115,118,119,122,123,126,127,130,132,135,136,136,139,141,142,145,147,149,150,151,152,153,155,155,157,158,158,159,162,161,163,163,164,166,165,166,166,167,168,169,169,170,170,170,170,171,171,171,169,171,171,170,170,169,168,168,168,166,164,160,157,156,157,157,156,153,148,139,136,121,104,86,70,66,63,60,59,59,61,64,67,77,84,89,102,115,126,135,136,99,98,101,106,107,108,110,113,115,116,119,120,124,125,128,129,132,134,133,138,140,141,143,145,146,147,148,150,151,152,153,154,156,157,158,159,160,160,162,162,163,164,165,166,166,166,168,168,168,169,169,170,171,170,170,169,172,171,170,171,170,169,169,166,168,168,164,162,161,159,156,150,141,132,117,103,86,74,66,61,58,63,61,63,62,65,74,86,100,108,109,109,116,124,135,140,107,110,109,113,115,116,117,121,123,125,126,130,131,135,137,139,141,144,146,148,149,151,153,154,156,158,159,161,162,164,165,166,168,170,171,172,172,175,176,175,178,178,179,180,182,181,183,183,184,184,185,185,185,185,185,185,186,186,186,185,185,185,184,184,184,183,181,175,168,159,149,142,123,111,91,81,75,74,74,75,75,75,76,76,82,93,109,122,133,136,133,125,126,132,143,150,118,119,120,122,123,125,127,130,131,134,137,139,141,144,145,147,149,153,154,156,157,159,160,163,164,165,167,169,171,172,173,175,176,178,179,180,180,183,183,183,184,185,186,187,188,188,189,190,191,190,191,192,192,192,192,192,191,192,192,191,190,190,190,189,190,189,184,172,157,140,122,105,85,79,76,74,74,81,82,83,83,85,87,95,101,113,128,138,145,145,139,130,129,133,143,151,120,120,122,125,125,126,129,131,133,135,138,139,142,145,148,150,152,154,155,157,159,161,161,165,165,167,168,169,171,173,175,175,177,177,179,181,182,183,184,185,186,187,187,188,188,189,190,190,190,191,191,191,193,192,192,192,191,191,190,190,190,189,189,188,190,187,181,164,141,102,80,77,75,72,74,74,78,82,84,90,96,105,111,118,124,130,136,142,144,143,139,131,126,127,136,146,113,115,117,118,120,121,124,126,129,130,130,133,136,137,139,142,145,147,149,149,151,153,154,155,157,158,159,159,160,162,163,164,166,166,168,169,168,169,169,172,173,175,176,175,174,175,176,177,176,177,179,178,177,179,178,178,177,178,176,178,176,176,176,175,173,174,167,151,123,73,65,64,65,62,60,64,69,74,79,92,106,115,120,125,129,129,132,133,133,131,128,123,115,116,123,132,104,106,106,108,109,112,114,116,119,121,124,126,128,130,132,135,137,140,141,142,143,145,147,148,151,151,151,153,155,155,157,159,161,160,161,162,163,164,164,167,168,168,167,169,171,171,170,171,172,172,173,174,172,174,173,173,173,173,171,172,172,172,170,170,171,168,165,152,131,85,66,62,61,61,63,67,70,73,85,109,121,129,133,135,135,135,133,133,131,130,129,123,116,117,121,128,106,106,107,110,113,116,117,119,122,123,126,127,131,133,135,138,141,143,145,146,146,148,150,151,152,155,154,157,159,159,161,162,164,165,165,167,167,170,170,169,172,173,174,175,175,176,178,178,178,178,179,180,180,181,180,179,179,179,178,179,179,179,179,178,178,179,176,164,144,107,73,69,66,73,76,78,81,81,99,124,138,146,147,147,146,142,143,143,141,139,137,135,129,129,132,139,116,118,121,123,126,127,130,130,135,137,138,141,144,146,148,150,153,155,156,158,160,162,162,164,164,166,169,170,171,172,173,174,177,178,179,181,183,184,185,186,187,190,190,190,191,191,193,193,194,193,194,195,195,195,195,194,194,194,194,193,194,194,193,192,192,190,189,180,161,132,88,82,85,92,101,106,104,111,123,140,151,155,156,156,154,154,153,153,150,149,146,146,142,140,143,147,123,125,127,129,131,131,134,135,138,142,142,146,148,151,153,154,157,159,160,162,163,165,166,167,168,170,172,175,175,177,177,179,180,182,183,184,186,188,189,190,191,192,192,194,195,195,195,195,197,198,197,198,198,198,198,197,197,198,197,198,197,197,195,196,194,193,191,187,168,147,106,92,97,110,125,132,132,130,137,148,154,157,157,156,154,154,154,153,151,149,149,146,145,143,144,147,122,125,126,128,129,132,134,135,138,139,142,145,148,149,151,153,155,157,158,160,161,163,164,165,167,169,170,171,172,174,175,176,178,179,181,181,183,185,185,187,188,188,187,189,190,191,191,191,191,191,191,191,192,191,193,192,193,191,191,191,189,189,188,186,188,186,186,183,170,151,119,104,112,126,136,141,142,140,140,145,147,146,147,145,144,144,143,144,142,140,140,138,136,134,135,136,109,113,115,118,120,122,123,125,129,129,130,134,136,138,140,142,145,146,148,150,151,152,154,154,157,156,158,158,160,162,164,164,165,167,168,169,170,171,171,173,173,176,175,176,177,177,177,177,178,178,178,178,178,179,178,179,177,177,178,178,177,177,176,174,175,174,173,171,164,150,134,122,125,132,140,142,141,137,137,136,136,134,133,131,131,131,133,134,133,131,131,129,128,126,125,128,105,107,110,113,114,118,120,121,124,126,128,132,133,135,137,138,142,142,144,146,148,148,150,151,152,154,155,155,158,160,160,160,162,163,164,165,166,168,168,169,170,171,172,172,173,174,174,174,175,174,175,175,175,175,175,176,175,175,176,175,175,175,174,174,172,172,171,171,167,159,146,138,139,144,146,143,140,136,134,132,131,129,127,125,126,127,129,131,132,133,132,132,129,127,130,131,110,113,115,118,121,123,124,128,131,134,135,138,139,142,144,146,148,149,150,154,156,156,157,159,162,161,164,166,166,168,170,170,173,175,177,176,177,179,180,180,184,184,184,186,186,187,187,187,187,189,189,190,189,190,189,190,189,190,190,190,188,189,188,188,187,187,187,186,183,179,170,165,161,160,158,152,146,143,139,139,137,133,132,130,130,132,136,139,143,147,149,148,147,147,148,148,123,124,126,128,130,131,135,138,141,144,147,147,149,152,153,155,157,158,160,161,164,165,166,168,170,171,173,175,176,177,178,180,181,184,185,185,187,188,189,190,191,192,193,194,194,195,195,196,195,197,197,198,199,198,197,197,197,197,197,196,195,195,195,194,193,193,192,191,190,187,180,174,168,165,159,154,147,143,141,139,137,134,134,133,132,133,138,142,148,152,155,154,155,155,154,154,126,128,128,131,132,134,137,139,142,145,147,149,152,153,155,157,159,160,161,164,166,167,169,170,173,173,175,177,177,179,179,182,183,187,186,187,188,190,191,192,194,194,196,196,195,196,198,198,198,198,199,199,200,200,200,201,199,199,199,198,198,197,197,196,195,195,192,193,192,190,184,176,168,162,156,148,143,143,140,139,137,135,135,134,135,137,142,148,153,156,158,159,158,158,157,156,121,124,126,125,128,131,133,136,137,140,141,144,147,149,150,152,154,155,156,159,159,160,160,162,166,167,167,169,168,171,171,173,173,173,176,176,176,177,179,179,181,180,184,182,184,184,186,185,184,184,184,183,185,185,185,185,183,183,182,183,181,181,181,181,180,179,178,178,176,175,172,164,154,146,138,134,130,130,129,128,126,129,131,134,136,140,142,145,149,150,149,149,148,147,146,145,112,114,115,116,119,121,124,126,128,129,132,133,135,138,139,141,144,146,147,148,150,151,153,154,155,156,159,159,160,161,163,164,164,165,167,168,169,170,171,173,173,174,174,174,175,175,176,177,177,177,177,178,178,176,177,178,178,177,176,176,175,176,176,176,174,173,171,170,171,170,167,160,149,138,133,127,127,127,129,131,133,136,139,141,145,147,148,149,150,148,148,146,144,141,139,139,110,114,114,117,119,123,125,126,129,129,133,135,136,140,141,142,144,146,147,149,150,152,154,156,156,156,159,160,162,163,164,166,166,167,170,172,171,172,172,174,174,176,176,178,179,179,179,181,182,181,183,182,183,181,181,181,181,180,180,180,180,180,180,180,181,177,176,176,176,175,171,164,153,141,136,136,136,141,145,147,151,153,155,158,157,158,158,157,158,156,154,152,148,145,143,141,122,125,125,128,130,133,134,137,140,143,146,146,148,151,153,154,156,158,160,161,164,166,165,167,169,171,173,175,175,176,178,180,182,182,184,186,188,188,189,189,190,192,193,195,196,196,197,197,198,198,198,198,199,199,200,199,200,198,198,198,197,195,196,195,195,193,192,192,192,191,188,181,171,162,159,161,163,166,169,170,172,173,174,174,173,172,171,170,168,167,165,161,156,152,152,151,128,130,133,134,137,139,140,144,145,149,151,152,154,156,157,159,162,163,164,167,169,170,172,173,174,177,179,179,181,182,184,185,187,187,188,191,191,193,193,195,195,197,198,198,198,200,201,201,201,203,202,203,203,202,202,204,203,202,201,201,201,200,199,199,197,196,195,194,195,193,192,187,180,173,172,174,176,178,180,179,180,178,178,177,175,174,173,172,170,169,166,161,157,153,152,153,129,131,133,135,137,138,141,144,146,148,152,153,155,155,158,160,161,163,165,166,167,169,170,172,174,175,177,179,181,181,182,183,185,186,188,190,189,191,192,193,193,194,195,195,197,196,198,198,198,199,199,199,200,198,199,200,199,199,197,196,196,196,195,194,192,192,191,190,189,187,187,185,180,177,176,176,177,177,177,177,174,175,173,170,170,169,167,166,163,161,159,156,152,150,149,148,116,120,122,124,124,127,131,131,135,136,140,143,144,145,147,149,149,151,153,153,155,156,158,159,162,161,163,164,166,168,168,170,171,173,172,173,174,175,174,177,179,179,180,179,180,181,182,181,182,184,183,184,184,182,182,182,182,182,181,180,179,180,179,177,178,177,177,174,174,173,172,172,168,163,160,160,163,164,164,164,163,161,159,158,158,156,155,154,151,150,148,146,144,142,140,140,112,113,117,119,121,123,125,128,131,132,135,137,137,138,142,144,146,147,150,150,151,153,153,154,156,158,158,159,161,163,164,165,166,167,168,169,170,171,171,172,174,174,175,175,176,175,177,178,177,178,178,179,178,178,178,177,178,177,177,177,176,176,174,175,174,172,173,172,171,170,169,168,163,156,150,151,158,161,161,161,161,159,158,157,156,155,153,152,150,148,146,145,143,143,141,140,116,118,121,123,125,129,130,133,135,138,139,141,143,145,146,149,152,153,153,154,156,158,158,159,163,164,165,167,167,169,171,171,174,175,176,177,178,179,180,181,183,184,185,186,187,186,187,187,189,189,189,188,188,191,191,190,190,189,190,189,189,187,187,186,187,185,185,184,184,182,180,181,174,162,152,151,165,172,173,173,171,170,170,169,167,166,165,164,161,159,157,155,154,155,153,151,126,130,131,133,136,137,140,144,146,147,150,152,153,155,157,158,161,162,163,165,167,169,170,170,173,175,176,178,179,180,182,183,185,186,187,188,190,191,191,193,194,195,196,197,197,197,198,198,200,200,200,201,201,200,200,200,199,199,199,199,199,198,197,197,195,193,193,193,192,191,190,189,182,166,153,151,168,179,181,177,175,176,177,175,173,171,170,169,166,164,162,161,159,160,158,156,129,132,134,135,138,141,142,146,148,149,153,154,157,158,159,160,163,164,165,167,169,171,170,172,175,177,178,180,181,182,185,186,186,189,189,190,192,193,193,194,196,197,199,199,199,199,201,200,202,202,202,202,202,202,203,201,201,201,201,200,199,199,197,197,195,195,194,193,191,192,190,190,184,169,154,149,160,175,178,174,171,173,176,174,170,169,170,170,167,164,163,161,160,160,158,154,126,129,132,134,135,138,139,142,144,145,148,151,153,154,155,157,159,160,161,162,164,165,167,168,170,171,172,174,174,173,177,179,179,181,182,183,181,184,185,186,187,186,186,188,189,188,188,188,189,190,190,191,190,191,190,190,188,189,186,186,185,184,184,182,181,181,180,179,177,177,176,175,171,164,147,137,143,160,163,158,157,159,160,159,156,153,157,157,156,154,151,149,149,148,146,142,115,118,120,123,125,127,130,132,134,136,138,139,142,144,144,145,149,151,151,153,153,155,157,158,158,160,161,163,162,164,166,165,168,168,170,171,171,172,173,175,175,175,177,177,178,178,178,179,180,180,180,181,182,180,180,179,179,180,179,177,177,177,176,176,174,173,172,172,170,169,168,168,167,160,143,132,133,149,156,152,149,151,154,152,148,148,150,150,149,147,144,142,142,141,139,137,115,118,119,122,123,126,128,130,131,134,137,139,141,141,144,144,148,149,150,151,152,154,156,156,158,159,160,162,162,163,163,165,166,168,170,171,171,172,173,174,175,176,177,176,178,179,179,180,180,180,181,181,181,180,181,182,179,178,179,178,176,176,175,175,176,175,176,175,171,171,171,171,168,166,150,135,132,145,157,155,152,152,155,155,150,149,152,153,151,148,147,143,141,142,141,140,125,127,128,132,133,134,137,139,143,144,147,148,152,152,155,155,157,159,161,163,164,165,166,167,169,171,172,175,177,178,179,179,181,184,184,185,186,188,188,190,190,190,192,192,195,195,194,195,196,196,196,197,197,196,198,197,197,196,196,195,195,193,193,194,192,190,190,189,188,187,186,186,184,182,168,152,145,153,168,171,166,164,166,166,163,162,163,165,164,161,158,154,153,154,154,153,131,133,136,138,141,143,145,147,150,151,153,155,158,158,159,160,163,165,167,168,169,172,172,172,175,177,177,180,182,183,184,186,187,188,190,191,192,193,194,193,194,195,197,199,198,198,201,200,200,201,201,202,201,200,201,200,199,200,199,199,198,197,196,196,196,194,193,192,191,190,190,189,187,185,176,158,147,151,167,173,169,166,166,169,166,163,164,165,165,161,159,157,155,154,154,154,133,133,136,138,141,142,146,147,150,152,154,155,158,159,161,163,164,165,166,168,169,172,171,173,174,176,177,179,181,182,183,186,187,187,189,190,191,191,193,194,194,194,196,197,198,198,198,198,198,198,200,200,200,199,198,198,197,197,196,196,195,194,194,193,191,190,189,189,190,187,186,184,183,180,176,162,146,144,157,167,166,163,161,166,163,159,158,160,158,157,155,154,153,151,151,149,124,126,128,128,131,134,136,137,140,142,145,144,147,148,150,152,153,155,157,158,158,159,159,161,162,165,166,165,167,168,169,171,171,173,175,175,174,175,175,177,180,181,182,179,180,182,182,182,182,182,182,182,182,182,182,182,181,180,181,180,179,179,177,176,176,175,174,173,173,172,169,169,167,166,164,154,137,131,139,153,153,149,149,151,151,148,146,147,146,146,143,141,140,138,138,136,116,118,120,123,124,127,129,130,132,134,136,137,140,141,143,144,146,148,149,151,152,152,153,155,157,158,160,161,162,162,163,164,165,167,168,168,169,169,170,171,172,174,174,174,175,175,175,176,176,177,177,177,178,176,176,177,174,175,174,174,173,172,172,171,170,169,169,167,167,166,165,165,164,162,160,154,137,129,131,147,150,147,146,147,148,146,144,145,143,141,138,138,136,135,135,133,118,119,122,125,127,128,129,134,135,137,138,140,143,144,146,148,149,152,152,154,156,156,156,157,159,162,162,163,165,165,167,168,170,170,171,172,174,174,176,176,177,177,179,180,180,181,181,181,182,182,181,182,183,183,183,183,182,183,181,182,181,180,179,180,177,177,178,176,176,175,173,172,173,171,170,166,151,137,135,149,159,159,157,158,157,155,152,154,153,151,148,146,146,146,146,145,129,131,133,136,139,139,142,144,147,148,150,151,153,153,155,157,159,160,161,164,165,167,167,169,172,172,175,176,178,178,180,181,182,184,185,186,187,188,188,189,191,190,192,192,193,193,193,194,195,195,194,194,195,196,195,194,194,193,193,194,193,192,190,189,188,188,189,187,186,185,185,183,182,180,180,176,163,146,140,151,167,169,168,168,166,164,162,162,161,160,157,154,155,154,153,152,132,135,135,139,140,142,146,147,147,149,153,153,155,157,158,161,162,162,164,166,167,168,169,171,174,174,176,177,179,181,182,182,184,185,187,187,189,189,190,191,192,193,193,194,194,195,195,195,196,197,196,196,196,196,197,196,195,194,194,195,193,193,191,191,191,190,189,188,188,187,185,183,182,181,180,178,167,150,140,145,162,172,171,169,167,164,163,162,162,160,158,156,156,154,153,153,130,130,132,135,137,138,141,143,145,147,149,151,152,153,155,156,159,159,161,161,163,164,165,166,168,170,170,172,173,175,175,176,178,181,180,181,182,182,184,185,185,185,187,186,188,187,188,188,189,188,188,188,188,187,187,187,186,186,185,185,185,181,181,182,181,181,180,179,176,176,174,173,171,170,169,168,162,147,134,133,146,159,161,159,156,154,153,153,152,150,147,146,145,143,142,143,118,119,120,124,125,126,128,130,134,135,137,139,140,142,144,144,146,149,150,150,152,153,153,154,156,158,159,159,161,163,163,163,165,165,166,168,169,169,169,170,172,170,173,173,172,172,173,173,174,174,174,174,175,174,174,175,173,172,172,171,171,170,170,168,168,167,167,167,167,164,164,164,162,161,160,159,156,144,130,128,138,150,153,150,149,148,146,146,144,142,141,138,138,136,135,135,116,117,119,121,123,124,126,128,130,133,134,134,138,140,141,141,143,146,148,150,149,150,151,152,154,155,157,158,158,159,160,161,163,163,165,166,167,167,168,168,169,168,170,171,171,171,171,172,172,172,172,172,173,171,172,172,171,171,171,171,170,170,169,167,167,166,165,165,164,163,163,162,162,161,160,159,157,149,140,134,143,150,151,150,149,148,147,145,144,142,143,141,139,139,137,135,124,126,127,129,130,132,135,139,141,142,143,145,149,149,150,152,154,156,158,159,160,159,161,164,166,167,168,169,171,171,173,174,175,178,178,179,179,179,181,182,183,183,185,186,187,187,188,188,187,188,188,187,188,189,187,187,186,185,186,186,186,186,184,184,183,182,181,181,179,177,177,177,176,175,173,173,171,169,163,160,161,164,165,163,163,161,160,159,158,158,157,155,153,152,152,150,131,133,135,137,138,141,143,144,148,149,151,153,155,156,158,159,160,162,163,166,166,167,168,170,173,174,174,174,178,179,178,180,182,183,184,184,185,186,187,188,190,189,190,191,192,192,193,192,194,193,193,193,193,193,192,192,192,192,190,191,190,189,188,188,188,186,185,185,183,180,180,179,180,178,177,176,175,174,172,168,165,165,165,167,165,165,164,163,160,159,158,157,155,155,154,152,131,133,136,137,140,142,143,145,149,149,151,153,155,156,158,160,161,162,164,166,167,168,168,171,171,173,175,176,177,177,179,179,180,181,183,184,185,186,186,187,189,190,189,189,191,190,191,192,192,192,191,191,192,192,190,191,191,191,190,189,188,188,187,186,185,184,185,182,180,178,178,177,177,176,174,174,172,171,169,162,157,155,158,162,163,162,162,159,158,157,155,154,153,151,150,148,124,125,126,129,131,134,135,137,138,140,143,144,147,147,148,151,152,153,154,155,156,157,159,159,160,162,161,164,164,166,167,166,168,169,170,170,171,172,171,172,174,173,172,175,176,175,176,176,177,177,176,177,176,176,174,173,176,174,173,173,172,171,172,172,168,170,168,167,166,164,162,161,163,162,160,160,159,158,155,143,133,130,139,149,150,150,148,146,145,144,142,141,139,139,137,136,115,117,117,120,122,124,127,128,130,130,133,135,138,139,139,141,142,144,145,146,147,150,151,151,152,153,154,155,156,158,159,159,159,161,162,162,163,164,164,164,165,166,167,166,168,168,168,168,169,167,168,168,168,169,168,167,167,168,167,166,165,164,165,165,162,162,161,160,160,158,157,158,157,156,154,154,152,151,148,137,123,117,128,141,145,142,141,140,139,138,136,135,135,134,132,130,114,117,119,121,122,124,126,129,130,130,133,134,137,139,139,141,144,146,147,148,149,149,152,154,154,155,157,157,158,159,159,161,161,162,162,165,165,166,166,167,166,167,168,169,169,171,172,171,171,171,171,171,172,172,172,170,170,171,170,170,169,168,168,168,167,166,166,165,164,163,162,162,161,160,159,159,157,157,154,144,128,120,128,145,149,145,144,144,145,144,142,141,140,139,138,138,126,128,129,133,134,133,135,138,141,142,144,145,147,149,150,153,153,156,158,159,159,160,162,164,165,165,167,167,169,170,172,173,174,175,175,176,177,177,177,180,181,182,182,181,182,183,183,183,185,184,184,184,184,184,183,182,183,183,183,182,181,181,180,180,179,177,176,176,175,175,174,173,172,172,170,169,169,166,165,157,140,129,132,149,156,154,150,151,154,152,150,148,148,148,149,147,129,131,132,135,135,137,139,141,144,146,148,148,149,151,153,156,157,159,160,161,162,164,165,166,167,169,170,171,172,174,175,175,176,177,177,179,180,179,179,182,182,182,183,183,183,184,184,186,186,186,186,186,185,186,185,185,185,185,184,184,183,182,182,180,180,179,178,176,177,176,175,174,173,172,171,170,169,167,167,161,146,130,130,143,154,153,149,148,151,151,148,146,146,147,148,147,127,129,129,132,133,134,137,139,142,143,144,146,149,149,151,152,155,156,157,159,160,162,161,162,164,166,167,168,169,170,171,172,171,173,173,174,175,177,177,178,176,178,179,178,178,179,180,180,181,181,180,180,181,180,179,180,178,177,177,176,176,175,174,174,173,173,172,170,168,169,169,165,166,165,162,162,161,160,158,157,145,128,119,129,144,144,141,139,140,141,137,136,136,138,139,139,114,117,117,119,121,122,126,128,129,132,132,133,135,136,138,139,142,143,145,146,145,147,149,150,151,151,152,154,155,156,157,156,158,159,159,160,161,161,162,162,163,164,165,164,165,165,166,166,165,165,165,165,165,164,165,164,163,163,162,162,162,161,160,159,160,159,158,158,157,156,155,154,154,153,152,151,149,149,147,146,137,122,110,114,129,134,131,128,129,130,128,126,126,128,128,127,112,113,115,117,118,119,122,124,126,128,129,130,132,133,135,135,138,137,142,143,143,144,146,148,147,149,150,151,152,153,154,154,156,157,157,157,157,158,158,159,161,160,159,161,162,162,163,163,161,162,162,162,161,162,162,162,161,160,160,160,159,159,159,158,157,157,156,156,155,155,154,153,152,152,150,149,148,147,146,146,140,125,111,109,124,132,130,127,127,129,127,124,124,126,126,126,116,116,122,124,125,126,128,130,133,133,136,138,138,141,143,144,146,147,148,148,150,152,153,153,155,157,158,159,160,160,160,160,163,164,165,166,166,167,169,170,171,171,171,172,172,172,174,172,173,174,173,174,174,173,174,173,174,173,172,172,171,170,170,171,169,169,169,168,167,167,165,165,163,162,161,160,160,159,158,157,153,139,123,117,127,141,144,139,137,140,141,137,135,136,136,135,126,128,130,131,132,135,136,139,141,143,144,145,147,148,152,151,152,154,155,156,157,159,160,161,162,164,166,166,166,167,168,169,170,171,172,173,174,175,176,177,178,178,178,179,178,178,180,180,181,181,180,181,180,180,180,179,179,180,179,179,177,177,177,176,175,175,175,173,172,172,171,170,168,167,167,165,164,163,163,161,158,147,130,121,127,143,148,144,141,142,143,141,138,139,138,138,127,128,130,131,132,135,137,138,141,143,146,147,148,149,152,153,154,154,156,158,158,159,161,163,163,165,168,167,167,169,170,169,170,171,172,172,174,174,176,177,177,176,178,179,179,179,180,179,180,180,181,180,180,178,179,179,178,178,178,177,176,176,176,176,174,173,172,173,171,170,168,168,167,165,165,164,163,162,160,159,158,151,135,120,121,136,145,143,138,138,141,139,135,136,135,136,119,122,124,124,127,129,131,132,134,137,138,138,139,142,143,145,146,146,147,150,151,151,152,154,155,155,155,159,158,157,159,160,160,159,161,163,164,164,164,166,164,167,166,167,167,167,167,167,168,166,167,168,167,167,166,167,165,164,163,164,163,163,163,161,159,159,158,158,157,157,157,156,153,152,152,150,150,149,147,146,144,140,128,112,104,118,131,131,127,126,128,128,125,124,125,125,107,111,111,115,115,118,118,121,121,124,128,128,129,131,131,133,135,136,136,138,140,140,140,143,144,146,147,148,147,148,149,150,151,151,153,152,153,154,155,154,156,157,156,156,157,158,158,158,157,158,157,158,158,157,157,157,157,156,156,155,155,154,154,154,153,151,151,151,149,149,149,148,146,146,145,143,143,143,141,139,137,136,126,110,99,105,123,127,123,123,125,123,119,120,120,119,108,111,111,115,116,116,117,118,122,123,127,127,128,129,130,133,134,136,136,138,139,139,141,142,143,145,146,147,147,147,149,150,150,152,153,153,152,154,155,156,154,157,157,156,157,158,159,158,158,158,158,158,159,158,159,159,157,157,156,156,157,156,155,154,155,154,154,152,152,152,153,150,148,148,146,144,146,145,143,143,141,139,133,119,103,104,121,130,130,130,129,126,125,124,125,122,118,119,121,124,127,126,128,129,132,133,135,136,138,139,139,142,144,146,148,148,150,150,151,152,153,155,156,156,157,158,160,161,161,161,163,164,164,165,166,167,168,168,168,168,168,169,169,169,170,170,169,169,171,169,169,170,169,168,168,169,168,168,166,166,166,164,163,162,162,162,161,160,160,160,158,157,155,155,153,153,152,150,146,132,117,112,125,140,143,142,141,136,135,134,133,134,123,125,127,128,130,131,133,133,136,137,140,141,142,142,144,146,149,149,149,152,153,153,154,155,156,158,159,161,160,161,163,163,164,164,165,166,167,168,167,169,170,170,171,171,171,171,170,171,172,172,172,172,173,171,171,172,171,171,170,170,170,170,167,167,168,166,166,164,163,164,163,161,161,161,158,158,157,155,154,153,152,151,149,139,122,112,121,137,145,144,141,138,137,135,136,135,122,123,125,127,127,129,131,133,135,135,138,140,139,141,143,146,145,147,148,149,151,152,152,153,154,156,157,158,158,159,160,160,162,162,163,163,165,165,164,166,166,165,167,166,168,169,168,168,168,168,168,167,167,168,168,166,167,165,165,166,165,163,163,162,163,162,161,159,158,159,157,157,156,154,153,153,152,151,149,149,147,146,146,137,125,116,118,129,139,137,136,134,133,132,130,130,109,110,111,114,114,115,119,122,122,123,124,125,127,129,130,131,132,134,136,136,137,139,139,139,141,143,144,145,145,147,146,148,149,150,150,150,151,151,151,152,153,153,153,154,154,154,154,154,155,154,153,154,154,154,153,153,152,152,152,152,152,152,150,150,149,148,148,147,146,145,145,145,143,142,140,139,138,137,137,135,134,133,133,129,120,114,111,118,126,124,123,122,118,116,112,108,102,104,104,108,109,111,115,115,116,117,120,121,123,126,126,126,128,130,130,132,133,134,134,135,137,137,139,139,140,142,143,143,144,145,146,147,147,148,148,148,147,148,148,150,149,150,149,150,150,150,151,150,150,150,149,150,149,148,148,148,148,148,147,145,146,144,144,143,142,141,140,140,138,137,138,136,134,133,134,132,131,130,129,127,123,119,117,118,120,119,114,109,101,95,85,76,107,109,111,114,116,116,117,120,122,125,126,125,127,130,129,131,133,134,136,137,138,139,141,142,141,143,144,145,146,146,147,148,149,149,151,151,153,153,154,153,154,154,155,154,155,155,155,155,156,157,157,156,156,156,156,156,156,156,155,155,155,153,154,155,152,153,152,151,151,151,150,148,148,147,146,145,144,144,143,141,142,139,137,137,136,133,128,123,119,113,103,94,78,69,60,52,116,119,118,122,124,126,128,129,130,132,135,134,136,138,138,139,142,142,145,146,146,148,149,150,150,151,153,154,154,155,156,156,157,158,159,160,161,160,161,161,163,162,162,163,162,163,163,163,164,164,165,164,164,164,163,163,164,164,162,163,162,162,163,161,160,159,158,158,157,157,156,154,155,154,152,151,151,151,149,148,146,145,145,143,142,138,129,115,101,88,78,63,48,36,29,26,117,119,120,124,126,126,129,130,130,132,134,134,137,139,140,140,144,143,146,146,147,149,150,151,151,152,153,154,155,155,156,158,159,159,159,160,161,161,160,162,163,163,163,164,163,164,165,163,165,165,165,165,164,163,163,164,163,163,163,163,163,163,162,161,160,159,158,157,156,155,155,155,154,153,152,151,150,150,148,148,147,145,145,143,142,136,121,95,70,63,54,43,29,21,17,17,113,113,116,118,120,120,122,124,126,127,128,128,131,133,136,136,138,138,138,139,141,141,143,144,144,145,146,147,149,148,149,150,150,151,152,152,151,154,154,154,154,154,155,154,155,154,154,155,156,156,154,154,155,155,154,154,154,152,152,152,153,151,149,151,151,148,147,147,147,145,144,142,141,140,138,139,138,139,138,135,135,134,133,133,130,123,106,72,53,49,47,38,26,18,16,15,98,99,100,102,105,108,110,111,115,114,115,116,119,120,120,122,124,126,127,128,128,129,130,131,132,133,134,134,135,135,134,136,138,138,139,139,140,141,140,141,141,141,142,143,143,143,143,143,145,144,143,144,143,143,142,142,141,142,140,139,141,140,139,139,138,138,137,135,134,134,133,133,132,132,131,130,130,129,128,127,126,125,123,124,123,117,100,69,50,46,45,40,29,20,14,13,95,97,99,100,104,105,108,107,112,112,112,114,117,118,120,121,123,123,126,126,127,128,129,129,131,132,132,132,133,135,133,134,135,136,136,137,138,138,138,139,140,140,141,142,141,141,141,142,142,141,142,141,141,142,141,140,139,141,140,140,141,140,139,138,138,137,136,135,135,134,134,132,132,132,131,131,129,129,128,128,126,125,125,125,123,120,105,71,52,48,48,44,33,23,16,14,104,109,108,110,112,114,115,119,119,120,122,124,124,126,129,129,132,132,133,136,136,138,138,139,139,140,141,142,143,144,144,144,146,147,148,148,148,148,149,149,150,149,151,150,150,151,151,152,151,152,153,152,152,152,152,151,151,151,151,151,151,150,149,149,148,148,149,146,146,145,145,144,143,143,142,142,142,139,137,137,136,136,135,134,133,132,123,101,65,53,54,49,40,27,17,14,110,112,113,115,117,120,120,122,124,125,127,129,131,131,133,133,135,137,138,139,139,140,142,142,144,144,145,146,146,147,149,148,150,150,151,151,150,151,152,153,153,152,153,153,153,154,154,154,155,155,156,155,155,155,155,154,154,153,153,153,153,152,150,151,150,150,150,149,148,148,147,146,146,145,144,145,142,143,141,140,138,137,135,135,135,133,127,108,73,57,51,49,41,30,20,15,108,110,112,114,117,119,119,121,124,124,126,127,129,130,132,132,133,134,137,136,138,139,140,141,142,143,143,143,144,146,145,146,148,149,148,149,150,150,150,151,151,150,151,152,151,153,153,151,153,152,152,152,152,152,152,151,151,151,151,150,150,149,148,149,147,147,146,146,145,145,144,143,142,141,141,140,137,138,137,137,135,133,133,132,132,130,126,112,80,57,48,47,41,31,21,16,96,99,100,99,104,105,107,109,111,113,114,115,117,118,120,122,121,125,125,124,127,127,128,129,130,129,131,131,133,133,132,133,133,134,135,135,136,137,137,137,138,137,139,137,138,139,139,138,139,139,140,138,139,139,138,138,138,136,136,138,136,136,136,134,135,133,133,133,132,131,131,130,129,128,128,128,127,126,126,125,123,121,122,120,119,119,116,106,78,53,41,38,37,30,20,15, Length: 9216
and this is when I put my finger over the lense. It should be black then ...
39,36,35,36,36,30,32,43,38,38,40,34,41,35,38,34,34,44,40,36,43,42,43,41,32,38,42,43,39,43,44,47,34,39,49,37,36,41,42,43,37,41,41,40,40,36,40,39,34,36,38,37,40,39,40,35,37,33,36,34,42,39,35,28,39,44,45,39,39,34,39,34,38,33,35,37,34,33,31,34,37,37,32,33,33,33,32,27,27,29,27,27,28,38,30,25,46,49,54,48,45,44,48,51,53,47,53,57,55,54,55,53,54,47,46,50,50,53,54,55,49,50,50,53,55,52,54,52,52,54,55,57,50,55,55,54,55,53,54,52,54,54,53,53,55,55,55,50,53,52,46,51,50,50,49,54,52,52,48,47,52,53,46,47,50,48,49,47,44,45,44,44,47,39,43,44,40,42,42,47,42,42,40,42,41,37,46,41,40,37,34,36,52,54,43,45,55,49,47,51,47,50,54,53,49,53,50,38,51,33,54,52,55,56,54,50,51,54,51,51,47,52,55,53,57,55,55,62,57,52,52,45,54,49,54,54,53,52,46,38,52,52,52,52,54,50,50,50,40,50,52,55,51,55,49,51,49,50,52,48,49,50,49,53,46,47,42,45,47,47,44,45,45,43,41,45,40,41,43,39,42,40,41,41,36,37,39,35,51,47,45,44,48,51,59,50,53,53,54,55,52,50,52,55,58,58,51,51,53,56,55,53,45,56,53,56,57,53,50,53,53,54,38,58,71,56,56,52,56,55,52,55,57,70,58,50,52,54,54,51,55,53,51,51,53,53,52,51,52,53,48,51,50,47,49,49,53,50,50,50,42,47,45,41,44,42,36,46,44,42,45,42,44,43,43,38,43,38,42,38,34,39,40,37,42,49,51,47,47,51,53,54,49,54,52,53,45,54,55,52,63,51,52,60,57,59,54,52,55,56,54,56,56,49,55,55,49,52,47,51,50,54,55,54,56,53,54,53,55,51,55,54,56,56,54,54,55,53,48,51,52,54,56,53,53,45,57,49,47,48,51,49,48,47,47,45,40,43,45,45,47,50,46,43,41,41,44,43,43,44,41,41,38,40,38,40,37,37,41,37,51,48,52,45,49,53,48,51,58,55,61,58,57,59,59,55,53,53,54,54,56,54,54,55,52,54,52,55,58,54,54,61,51,56,50,54,54,58,57,59,59,58,58,56,52,55,54,52,55,48,57,54,56,54,58,48,56,58,53,57,50,52,54,50,45,49,49,47,50,49,46,51,47,49,52,49,53,43,45,44,44,41,44,44,42,45,40,41,38,42,41,41,38,38,38,40,45,48,49,50,50,51,51,45,59,50,50,54,51,55,53,56,58,52,56,54,58,56,50,60,55,53,54,58,59,56,56,56,57,59,57,55,55,61,53,57,55,59,57,55,58,55,57,56,56,57,53,52,51,56,58,56,56,55,55,56,53,51,44,52,56,51,50,49,51,51,50,48,49,49,48,53,47,43,43,45,45,44,42,43,44,41,43,42,37,41,43,41,39,39,45,42,54,48,50,52,51,49,62,51,58,50,57,52,52,57,54,52,53,54,51,57,56,54,55,53,60,58,57,53,56,60,57,54,57,49,58,56,52,56,59,56,58,59,59,59,56,57,55,59,57,57,56,54,52,55,56,53,46,54,53,55,53,51,49,52,52,51,49,51,51,52,52,49,50,50,48,47,46,46,47,43,43,41,44,42,43,44,43,42,40,45,38,40,40,40,41,40,51,48,47,48,50,47,50,59,49,53,55,51,55,56,57,50,54,54,56,55,53,59,56,55,59,54,59,55,55,50,55,55,58,56,53,60,57,54,55,56,56,58,58,58,58,58,55,59,59,58,57,56,57,61,55,54,52,55,54,55,57,55,52,54,55,51,51,49,50,50,51,50,51,51,50,46,47,46,48,31,41,42,43,46,41,43,38,42,45,43,40,40,37,40,42,41,49,53,54,52,50,52,56,56,51,54,57,54,56,55,54,55,55,56,58,58,39,57,56,56,57,57,57,53,54,63,62,59,57,58,61,58,62,55,58,55,58,58,56,59,59,59,59,58,58,61,58,55,56,56,57,58,53,58,55,47,56,56,54,55,55,51,48,53,54,52,49,51,44,49,45,54,46,45,47,45,46,43,46,40,43,46,46,42,42,41,43,42,42,45,43,42,56,50,50,49,52,52,53,53,53,45,56,53,56,56,59,55,51,56,56,56,54,56,56,60,59,58,58,57,58,61,59,59,59,57,58,57,58,57,58,57,60,61,60,60,60,58,60,62,59,57,53,53,58,58,57,57,52,55,60,53,58,57,54,55,51,52,53,52,53,51,51,48,49,56,47,52,51,46,45,44,44,45,44,41,44,43,45,40,43,44,41,41,42,42,42,40,52,53,52,53,54,52,54,56,52,58,51,54,53,57,49,53,55,58,56,58,60,50,58,61,57,56,60,59,59,60,60,61,58,59,46,58,58,60,58,61,63,61,56,58,57,63,62,58,61,64,60,56,58,60,59,55,57,59,51,54,59,54,53,54,55,55,54,53,54,50,47,49,52,48,50,48,48,48,47,49,43,44,46,46,46,44,45,47,44,45,44,43,44,42,39,42,43,39,53,52,50,55,54,53,57,50,58,55,52,56,55,57,55,62,56,56,58,59,56,56,65,62,55,61,61,60,59,60,59,62,59,57,66,62,60,60,48,60,62,61,59,58,65,63,61,62,65,57,54,59,59,60,59,59,61,57,58,55,55,55,51,55,53,52,50,53,53,52,52,50,51,51,48,50,48,47,46,41,44,48,46,45,44,44,42,41,42,40,43,43,40,39,54,56,54,52,49,53,54,53,54,52,50,53,54,52,57,54,52,60,56,59,52,51,58,63,61,58,64,69,60,60,60,65,58,52,61,60,63,60,63,59,63,65,60,60,60,59,61,61,65,60,53,60,57,59,60,62,60,62,60,59,58,56,58,56,57,55,56,55,54,57,50,54,51,49,53,51,49,49,48,48,48,48,48,53,46,44,47,45,44,43,43,43,40,41,42,43,57,52,50,54,57,49,47,53,50,55,48,59,54,57,58,52,33,61,58,57,61,57,58,56,60,61,70,68,62,63,57,57,60,57,58,61,65,66,59,62,63,63,58,62,58,62,62,62,65,61,58,62,58,59,61,61,53,65,57,59,56,57,59,57,55,53,53,59,56,53,52,54,52,54,56,43,53,52,49,46,48,50,45,44,47,48,43,43,45,46,44,43,41,44,38,42,49,52,54,51,56,58,57,56,53,55,54,49,53,56,58,56,55,61,60,62,59,63,59,57,60,62,63,62,61,62,63,63,65,61,61,62,62,63,65,65,61,66,59,64,61,60,58,65,68,64,59,62,63,62,60,59,59,60,55,60,58,66,56,56,55,54,53,58,56,54,53,54,51,50,50,56,53,50,55,50,49,52,45,48,48,45,46,47,58,41,43,42,44,42,41,43,52,51,57,56,55,57,53,54,54,62,60,56,67,60,54,58,59,61,55,62,64,59,59,62,61,61,61,63,60,64,64,61,62,62,62,65,64,60,68,67,65,62,59,60,63,65,63,64,68,62,64,59,68,62,60,63,58,59,56,58,58,59,57,58,61,55,55,59,53,53,56,55,52,54,48,56,54,52,49,47,49,62,51,51,46,43,45,44,46,46,45,44,41,42,42,42,57,45,38,59,50,50,52,55,55,58,60,55,58,64,61,61,58,58,56,61,62,53,60,61,58,64,64,61,62,62,61,61,61,64,65,61,66,63,61,62,89,71,62,62,61,68,63,65,64,75,63,61,61,62,60,60,60,57,57,60,58,60,59,57,58,56,58,57,57,57,58,55,60,52,53,53,54,50,49,41,50,51,49,45,48,40,43,46,46,45,46,45,41,45,41,41,55,47,57,54,55,54,53,58,55,53,60,57,60,59,58,58,60,60,61,59,62,61,58,60,63,59,64,63,59,64,61,64,63,65,66,66,66,66,62,67,78,75,63,66,67,63,64,67,65,62,66,66,64,64,65,62,58,61,59,58,56,57,58,60,58,59,58,58,58,52,58,58,55,57,51,54,51,51,52,52,48,51,45,49,48,46,47,40,45,46,47,45,41,44,42,37,58,52,54,57,52,56,57,55,56,59,59,61,63,57,61,61,63,63,58,60,67,58,55,62,62,71,61,65,64,64,62,66,62,64,63,66,66,65,65,65,67,67,67,67,68,66,68,62,68,65,64,64,66,67,60,61,69,67,62,62,64,61,62,61,61,63,55,59,59,59,55,57,60,54,54,54,54,53,51,51,49,51,47,51,48,49,45,45,44,45,50,45,45,44,44,43,56,51,61,55,54,56,59,55,55,56,57,56,58,63,58,60,57,60,61,61,61,61,63,65,61,60,70,60,66,65,66,64,66,62,64,66,66,67,66,67,66,69,66,67,66,66,68,65,71,67,64,64,63,65,66,66,60,60,63,62,63,63,63,62,61,60,58,56,58,60,57,58,57,54,57,56,53,54,51,51,47,52,51,51,50,47,48,49,45,43,44,45,41,44,45,44,53,54,59,57,57,59,64,58,57,57,57,57,59,60,64,63,59,61,60,62,65,62,64,64,61,68,64,63,67,65,66,61,68,65,69,70,66,66,68,69,69,64,61,66,68,69,66,66,71,69,68,67,65,68,63,64,63,64,62,64,64,64,63,62,61,60,63,58,59,58,56,57,64,59,56,54,56,54,50,53,50,51,54,50,51,48,47,48,46,44,44,46,44,42,44,41,50,54,60,60,54,57,58,60,54,58,53,57,57,61,61,61,61,73,66,63,64,61,64,64,62,62,58,63,64,66,70,66,62,68,69,68,65,69,64,62,60,67,69,66,66,71,66,68,72,63,67,66,65,69,59,64,64,63,60,62,63,62,61,64,60,61,58,57,62,60,56,57,65,55,57,56,54,55,51,52,51,50,49,47,48,47,45,49,45,47,46,46,49,41,43,42,54,62,55,59,55,59,57,53,72,57,50,60,56,61,59,60,59,65,73,62,62,62,63,65,61,65,62,62,62,69,69,66,64,61,66,62,67,68,62,70,68,69,66,70,65,67,65,66,68,67,64,67,66,65,64,62,65,66,63,62,61,62,63,62,62,62,58,58,60,60,60,56,57,56,53,57,54,53,52,53,52,50,50,49,49,50,46,53,45,47,46,45,47,44,43,42,59,57,55,60,58,55,55,56,55,59,59,62,62,62,58,61,57,58,68,65,63,62,65,67,67,71,60,67,67,68,65,64,67,55,69,67,67,67,69,68,68,72,69,69,68,67,66,72,71,71,70,69,67,66,69,66,64,50,66,65,62,63,68,63,61,61,62,62,59,59,60,57,59,60,59,54,60,54,47,47,51,52,51,47,49,48,47,48,46,47,47,45,44,41,43,44,56,54,58,58,52,59,58,59,56,61,60,62,61,62,63,60,58,63,64,62,60,63,61,69,68,57,65,67,68,58,53,68,78,69,71,69,70,65,69,71,71,70,66,66,68,68,70,68,69,72,71,70,70,67,68,65,65,63,68,67,67,64,69,66,64,59,61,60,61,63,62,59,56,55,55,57,57,53,53,53,55,50,50,49,52,50,51,50,47,44,46,46,46,43,45,44,57,59,62,57,58,60,59,58,59,60,58,69,59,63,67,65,61,56,58,66,65,65,61,66,63,66,72,70,72,69,69,69,72,71,69,72,70,65,71,71,71,72,72,71,72,69,67,68,69,71,69,67,65,67,67,66,67,64,66,63,65,64,63,65,62,62,65,61,59,60,63,59,58,58,60,57,56,55,54,54,53,49,52,53,53,48,51,48,48,48,46,47,49,45,44,45,42,59,62,58,59,60,60,64,57,59,62,61,63,64,59,69,57,67,63,65,64,64,67,63,66,69,69,68,69,67,67,65,84,65,71,68,76,69,68,70,70,68,73,70,68,71,67,70,71,70,70,70,68,64,72,64,66,62,66,66,67,67,67,63,64,66,62,59,61,62,59,61,64,62,57,49,57,56,50,55,50,52,52,50,50,51,48,48,47,47,48,49,46,46,43,47,59,59,60,52,59,58,60,60,60,61,60,59,65,66,74,59,64,67,63,66,65,65,67,66,64,67,62,68,65,68,70,71,72,70,71,69,69,71,70,72,72,70,72,73,73,71,70,72,67,68,71,72,69,68,68,69,67,62,65,66,66,68,64,65,61,61,61,61,59,63,58,57,58,58,58,56,61,55,55,55,52,53,54,51,52,51,48,49,47,52,55,46,43,48,45,43,57,56,62,60,60,54,58,62,58,59,62,61,63,64,64,64,65,65,63,66,67,65,65,67,65,62,74,65,72,66,69,66,69,71,71,70,73,73,68,67,75,68,70,71,72,73,71,69,67,68,67,67,68,71,66,70,70,64,69,67,68,65,63,65,65,66,63,61,60,63,60,61,59,58,56,55,56,54,56,55,52,57,54,50,50,49,47,47,45,45,48,47,48,46,44,44,59,56,56,64,55,56,63,59,57,61,61,62,61,62,60,60,63,70,68,66,65,66,66,67,69,67,69,73,70,70,66,71,72,74,66,72,72,72,72,71,69,70,72,71,69,72,71,71,69,70,69,70,69,68,67,71,69,63,69,70,68,64,65,64,67,63,67,62,62,63,58,64,61,58,58,57,56,57,56,55,55,55,48,53,51,50,50,48,48,47,49,46,44,49,45,41,59,57,63,44,54,60,56,62,60,54,73,60,64,66,64,64,64,68,64,64,66,64,69,67,68,68,69,69,68,71,71,68,69,70,71,70,75,72,73,73,71,71,66,70,74,72,73,70,88,71,67,73,70,68,70,68,70,71,69,68,67,67,65,70,68,65,65,64,61,63,61,60,60,63,60,59,56,54,53,53,51,54,52,54,53,52,49,50,48,48,45,44,46,49,44,43,50,60,58,61,60,61,72,69,60,61,61,69,64,62,64,67,66,65,71,80,66,64,62,69,67,67,67,69,70,69,72,73,69,70,70,72,68,70,72,75,74,75,72,73,71,73,75,72,73,71,72,75,70,70,69,73,70,69,70,67,68,68,65,66,65,65,66,66,64,63,61,61,60,59,59,59,59,57,57,55,57,55,53,54,52,53,52,48,47,48,49,47,46,45,44,44,60,52,58,60,60,57,64,64,64,55,62,62,62,66,67,66,65,64,69,65,71,68,65,69,69,67,69,70,71,70,72,69,71,72,68,71,76,74,72,72,75,73,73,70,74,74,75,70,72,73,72,69,73,67,70,68,68,65,68,67,69,68,68,67,65,66,65,62,63,64,60,64,63,61,59,56,56,56,58,51,56,54,52,54,52,52,52,52,50,51,51,50,45,46,45,45,64,57,54,55,58,61,60,65,59,59,63,63,66,66,66,64,62,67,68,68,67,70,67,71,73,69,70,70,67,72,72,71,70,71,72,71,74,70,72,72,75,75,73,74,75,75,71,75,72,70,69,71,72,69,70,71,71,70,67,67,70,68,68,67,65,67,66,62,64,66,62,63,64,61,62,61,60,60,59,58,54,56,56,54,52,53,52,51,50,49,48,51,44,46,48,46,55,57,58,60,60,60,60,63,63,61,63,63,63,65,67,67,68,68,70,66,70,72,69,69,69,72,71,76,73,72,73,71,71,74,72,75,71,68,72,74,71,75,72,72,73,69,71,75,72,74,73,72,73,73,71,69,70,72,70,69,65,67,70,68,65,66,63,65,65,64,65,61,63,62,64,60,59,60,61,58,59,50,57,55,53,53,52,53,52,47,49,49,48,48,47,46,60,61,64,60,64,63,58,65,55,66,64,65,66,64,63,63,70,66,67,70,68,71,68,70,72,71,71,70,75,67,73,69,72,69,73,73,75,75,75,75,75,80,71,71,74,75,76,73,74,75,70,72,73,71,74,72,71,72,69,71,69,71,70,68,67,66,67,67,64,65,63,62,63,61,61,59,58,58,57,58,54,55,57,54,53,53,52,51,48,51,50,50,50,44,47,45,63,58,63,61,61,61,62,62,64,62,65,67,65,68,71,69,63,70,70,66,72,70,69,67,70,70,70,73,70,69,73,73,72,71,72,75,72,75,75,77,74,70,68,79,73,76,76,75,75,74,71,75,75,73,73,72,70,72,70,70,70,71,70,70,71,68,66,67,65,63,62,64,65,61,62,61,59,60,56,59,55,55,56,58,51,52,53,53,45,54,48,50,47,49,47,46,62,56,60,63,63,61,62,64,64,65,65,68,68,68,67,65,59,70,69,66,69,68,70,67,71,74,73,74,77,73,72,71,75,72,72,72,74,74,72,74,78,72,71,77,67,72,74,74,72,75,76,75,71,73,76,74,71,71,72,69,69,70,70,70,66,70,68,68,68,64,64,66,61,60,63,61,61,60,59,60,57,58,56,54,53,53,52,52,54,49,51,49,47,47,47,47,59,57,61,63,64,62,62,64,65,62,67,66,67,69,66,68,69,66,68,71,70,70,71,74,75,72,72,72,74,74,74,74,73,69,76,76,75,77,75,78,76,74,73,73,75,75,75,75,75,72,72,77,75,75,76,73,74,65,70,70,67,72,70,67,69,67,67,65,68,66,64,62,60,63,63,61,61,62,62,60,57,57,58,54,55,55,54,51,52,49,50,50,49,49,47,45,72,68,58,59,59,64,64,63,61,62,67,68,70,69,70,64,65,70,69,66,70,74,71,72,71,75,70,72,73,76,76,74,71,72,77,76,75,74,78,78,80,77,79,78,77,79,74,73,75,76,76,74,73,75,73,73,71,69,72,73,71,72,71,69,69,71,68,70,66,64,68,67,64,65,63,59,60,61,60,58,58,59,57,54,55,55,53,57,48,51,52,49,46,49,47,47,59,60,59,63,62,61,66,67,63,64,66,62,68,68,69,70,67,71,73,71,71,74,67,74,66,74,74,74,72,74,77,76,72,76,73,74,76,75,78,78,78,77,78,76,77,78,80,62,77,76,76,75,76,75,75,76,73,70,73,73,71,68,71,69,67,68,66,70,66,66,65,68,63,64,64,61,59,60,60,59,60,57,55,54,55,54,56,55,54,56,53,52,49,47,49,44,61,60,61,66,65,63,58,66,63,65,64,68,65,69,69,67,72,69,72,74,69,70,71,77,71,71,71,74,76,73,74,73,78,70,75,76,76,70,76,76,72,78,76,77,75,77,77,93,74,73,75,73,73,72,72,72,74,72,69,72,73,77,71,71,68,70,68,70,64,67,66,66,63,60,60,60,60,59,63,60,57,58,57,54,57,55,53,54,47,50,52,52,50,48,47,44,53,59,61,58,55,64,64,64,62,63,66,66,66,66,65,72,67,70,70,71,61,77,73,70,69,74,72,71,74,72,75,74,72,74,76,79,75,74,75,74,74,79,76,75,76,75,73,74,77,75,73,75,75,73,73,77,74,74,73,73,73,72,72,69,68,67,71,69,68,69,64,62,64,62,62,63,60,62,60,58,57,58,54,56,56,53,53,54,54,48,50,50,50,49,44,46,58,64,56,60,61,67,59,61,68,70,66,64,67,66,63,73,68,69,70,70,73,73,74,70,77,76,73,73,74,73,74,74,75,76,75,74,72,76,71,76,76,78,67,79,80,75,77,72,77,69,76,71,75,72,73,75,76,75,72,73,71,70,71,70,71,69,69,69,70,67,66,63,65,63,64,60,59,62,60,58,59,58,57,56,57,53,54,55,53,51,51,50,49,47,46,47,59,65,67,62,63,61,62,63,66,69,65,67,68,66,67,66,66,67,73,70,70,70,73,73,69,73,75,79,72,75,71,71,75,89,73,75,77,74,75,74,76,78,70,77,77,76,78,78,78,74,72,77,75,74,75,75,76,74,71,74,73,72,70,71,72,70,67,71,68,65,66,67,64,64,65,60,61,62,60,59,60,63,57,57,56,56,55,53,53,54,52,49,47,47,48,49,60,59,60,63,62,60,59,64,72,65,62,69,70,71,68,69,71,69,68,72,71,74,69,73,84,71,72,77,75,75,84,77,78,78,76,76,76,75,74,76,78,76,76,76,74,76,76,78,76,74,72,75,77,76,76,77,74,76,73,76,72,69,71,71,76,73,68,70,67,67,67,68,60,62,63,63,61,62,60,59,58,55,54,56,57,54,51,54,52,52,52,49,50,48,49,47,62,61,61,63,62,61,62,65,66,66,67,67,67,68,66,69,66,67,72,74,72,73,72,73,84,74,70,75,77,75,75,75,76,75,74,75,76,76,78,74,79,81,77,80,75,77,78,78,76,82,80,78,76,76,76,74,76,76,70,74,76,72,75,74,73,70,70,69,65,66,66,67,63,62,67,60,60,63,63,60,58,58,59,57,56,59,54,52,51,51,49,51,49,49,47,49,64,62,62,63,66,64,61,65,66,64,67,71,68,66,67,69,71,71,71,70,72,73,71,75,71,75,70,70,73,73,74,75,79,77,74,76,79,80,78,75,78,77,76,75,76,77,79,77,77,79,78,78,69,75,78,76,74,74,73,75,75,70,74,72,72,68,68,68,68,68,67,66,66,65,61,57,60,60,60,59,57,59,59,60,54,54,53,54,54,52,54,52,50,49,47,46,58,60,58,64,63,75,63,63,64,65,65,68,69,66,71,67,70,68,70,73,72,72,73,73,74,72,74,72,69,75,76,76,75,75,77,77,78,76,76,76,78,79,76,77,79,81,77,77,79,79,78,76,76,76,75,75,76,75,73,74,74,71,71,72,70,71,68,69,67,68,65,64,66,63,62,63,61,61,59,59,60,57,58,55,57,57,56,53,52,52,52,53,49,49,47,47,58,61,62,62,63,64,62,66,64,65,66,65,68,69,70,67,80,72,73,70,72,73,72,73,72,72,73,74,74,74,74,78,75,77,76,75,79,78,75,74,77,78,72,78,78,76,78,76,79,78,78,77,78,76,77,76,77,73,73,75,72,71,73,71,68,71,70,68,71,66,67,67,64,66,65,66,62,60,59,60,58,59,57,57,58,51,54,55,54,50,48,54,51,49,50,47,59,61,64,63,63,68,62,67,66,62,65,64,70,66,67,73,71,71,72,73,73,70,72,75,73,75,73,76,75,76,74,77,74,73,76,75,79,78,77,78,79,76,76,76,77,75,75,78,80,76,77,78,77,77,77,74,74,73,74,73,73,71,73,74,73,70,71,69,71,65,68,67,67,66,63,63,66,62,59,57,57,58,58,56,55,60,53,54,53,53,48,51,52,50,48,48,62,58,64,64,64,61,64,64,64,66,67,68,67,70,70,71,70,70,67,72,70,76,72,73,72,74,74,78,70,77,73,77,77,76,75,69,76,77,77,76,76,78,78,78,78,80,70,75,78,79,78,77,77,79,74,74,71,73,70,73,74,71,73,73,72,73,71,70,69,67,64,73,65,65,65,62,61,61,62,59,58,61,59,51,56,56,55,56,54,53,53,50,49,48,49,48,59,59,62,62,64,66,63,64,66,65,67,64,67,68,70,67,72,70,71,75,71,70,70,72,74,76,74,76,77,73,75,76,80,72,75,78,76,75,77,79,77,78,76,83,79,77,80,75,79,78,80,79,77,77,75,74,75,72,75,74,73,74,71,70,70,69,69,63,69,68,66,62,66,63,62,64,63,62,63,58,59,59,61,54,56,56,55,53,57,53,49,51,49,48,49,49,62,58,61,61,65,63,63,64,65,71,68,68,69,69,68,68,72,73,78,76,73,69,76,74,75,73,74,74,76,74,73,77,74,78,79,78,78,77,78,76,76,78,76,79,79,77,73,80,75,76,74,74,76,75,71,77,76,73,75,73,75,70,70,70,71,69,72,71,69,66,67,68,65,64,69,61,63,61,59,59,59,59,59,56,55,54,55,54,55,54,50,49,49,48,50,49,64,60,59,64,60,62,64,63,66,67,66,69,66,70,72,71,67,70,66,76,74,72,75,72,72,74,74,74,75,78,76,75,77,82,76,76,74,76,79,83,79,76,74,76,77,78,78,79,75,75,77,73,78,76,75,79,77,76,75,75,73,70,70,72,72,71,70,71,68,67,65,68,65,66,64,62,63,60,61,60,58,57,58,59,54,55,54,56,56,54,53,50,49,47,48,47,60,61,59,61,62,64,62,67,67,69,66,68,68,70,67,68,67,72,71,64,74,75,71,74,73,73,73,75,75,76,72,72,74,79,78,75,76,77,78,74,77,78,75,76,78,78,76,77,77,76,78,74,76,75,75,75,75,75,74,71,72,73,71,71,72,71,69,71,67,64,66,66,66,65,66,62,62,59,61,59,59,57,56,55,55,54,53,56,55,52,52,49,50,48,46,47,46,61,60,71,56,65,63,66,68,71,66,68,69,69,68,68,71,69,69,70,67,72,74,72,75,72,73,71,73,76,74,83,76,79,76,73,76,77,76,75,75,82,77,78,75,76,76,78,76,77,77,77,78,74,73,73,74,75,75,74,70,73,73,70,70,70,68,70,67,65,64,65,64,65,66,62,61,61,59,59,59,58,57,57,53,57,54,53,53,53,52,50,50,49,46,45,63,60,60,65,66,59,59,60,67,65,68,69,67,67,71,70,70,72,69,69,70,74,72,73,73,73,74,74,72,73,72,74,76,78,75,75,76,76,73,76,77,75,74,77,77,75,74,78,77,73,76,76,76,75,73,73,74,76,75,73,73,72,73,73,71,66,69,68,66,69,66,68,66,63,60,62,59,60,60,57,61,57,59,55,54,56,54,53,51,51,51,51,47,48,49,47,59,62,64,65,64,65,63,66,67,62,61,63,67,68,66,70,70,70,70,70,72,74,72,72,74,73,76,76,75,76,74,73,73,75,76,76,77,77,76,75,73,77,79,78,78,76,78,76,77,76,77,75,75,76,73,78,78,74,73,73,73,71,71,71,71,70,69,67,65,67,64,66,67,65,64,62,60,61,61,61,61,57,58,57,55,51,54,52,52,50,52,50,49,48,46,45,57,61,60,58,63,65,66,63,63,63,67,66,69,69,70,76,68,71,70,70,70,72,72,72,74,71,75,74,75,74,74,77,78,76,74,77,78,77,77,75,75,77,72,77,73,78,76,74,79,77,76,76,76,74,73,73,73,72,73,73,74,70,72,69,72,69,68,67,65,64,65,65,65,65,62,65,63,59,61,58,60,57,56,56,53,55,55,53,54,52,52,50,50,48,50,48,60,58,59,62,58,64,62,66,64,64,63,65,65,66,61,67,70,64,67,71,69,71,71,73,71,71,72,72,72,74,74,69,76,75,75,72,75,76,77,79,75,78,76,73,76,77,75,78,76,76,77,74,74,71,74,72,73,74,71,73,71,67,72,69,68,70,69,68,68,67,65,65,63,66,62,64,63,62,60,59,59,56,58,58,52,54,53,50,51,50,52,53,48,47,47,46,56,62,60,61,60,60,59,64,58,65,64,63,67,65,68,69,73,73,69,70,71,71,74,73,71,73,75,73,73,74,76,74,75,73,76,80,75,75,76,74,77,76,73,74,75,75,74,75,76,76,75,71,76,77,73,71,73,75,71,70,73,70,70,70,70,67,69,69,67,66,64,66,66,63,62,61,64,59,60,58,59,59,56,56,53,53,53,53,53,52,48,51,48,49,50,49,58,58,60,62,66,69,53,64,60,63,65,66,66,69,69,68,69,68,70,68,69,71,70,70,73,71,72,71,72,73,75,74,75,74,75,75,75,75,75,78,73,75,73,74,74,74,77,75,75,76,75,74,76,74,71,72,74,76,74,73,72,71,75,64,69,66,67,67,67,66,64,65,66,62,60,62,61,59,59,59,58,57,55,56,56,53,54,55,52,51,49,48,48,48,46,51,60,62,61,61,61,58,58,64,64,57,65,63,65,69,69,69,62,63,70,71,69,72,74,69,73,72,75,73,73,74,76,69,73,73,74,74,73,75,74,75,73,77,77,76,81,74,74,73,74,76,73,72,73,74,70,74,72,73,70,70,70,69,63,69,71,71,68,64,68,67,67,64,64,62,62,60,59,59,59,59,56,60,59,58,57,56,53,53,47,50,52,48,49,48,47,46,61,59,61,63,63,57,65,59,65,63,66,66,66,66,69,68,64,66,69,70,71,72,65,70,68,72,70,74,70,75,73,70,72,75,76,74,76,75,76,77,76,75,77,77,74,76,76,74,72,74,77,72,73,71,68,71,74,74,73,70,76,68,68,66,69,71,67,68,66,68,65,63,63,63,65,60,59,58,57,57,58,56,56,57,58,56,53,53,47,52,53,51,50,51,49,48,57,58,62,63,62,62,61,62,61,66,63,62,66,64,65,69,72,69,66,67,70,72,72,70,66,72,74,74,77,72,71,64,73,75,75,75,75,77,72,72,72,74,75,74,75,75,73,76,76,76,71,74,70,74,73,68,69,68,71,72,72,72,68,67,68,69,66,66,68,64,65,63,63,62,61,62,58,58,59,59,58,56,55,55,50,54,55,51,51,51,48,50,47,50,48,46,59,60,62,65,61,62,63,63,42,59,64,63,65,63,62,66,65,63,66,68,68,69,70,71,69,68,68,67,73,74,71,71,73,68,71,74,74,76,72,74,76,73,72,74,74,75,75,74,74,75,76,73,73,70,69,71,73,67,71,71,72,70,67,67,67,66,64,64,66,65,62,65,64,62,60,58,59,58,59,57,58,54,47,55,53,51,50,52,47,51,51,49,49,42,47,46,59,62,61,57,60,62,62,61,66,60,63,64,64,67,67,65,68,69,70,65,67,68,70,70,69,70,73,70,72,73,72,72,75,70,73,74,72,71,75,73,76,74,74,73,71,77,74,76,75,72,72,72,71,70,74,74,74,71,70,67,70,67,67,68,67,67,66,66,67,61,65,63,60,61,63,61,57,59,58,57,54,54,56,58,54,54,54,50,49,49,51,49,46,47,44,46,59,62,57,64,59,66,63,65,61,61,65,68,66,67,63,66,67,69,64,71,70,68,70,69,68,71,71,69,71,67,72,74,75,74,73,72,71,75,70,73,74,74,74,73,74,81,72,76,72,72,71,74,71,72,70,74,73,71,70,70,69,69,68,68,67,66,66,65,64,63,66,64,63,62,59,64,60,58,59,58,54,55,53,57,55,51,52,51,49,52,51,47,47,49,43,46,56,58,60,61,58,59,60,63,60,60,60,60,62,65,64,64,65,66,66,69,68,66,68,69,76,70,67,70,78,70,71,72,73,72,73,75,73,74,73,69,73,70,70,72,73,75,71,74,72,72,74,72,72,71,72,71,68,71,70,68,68,69,69,66,68,67,69,63,62,62,62,62,60,61,57,56,56,58,59,57,55,54,54,53,53,53,51,52,51,51,49,46,47,47,47,44,58,61,59,61,60,59,58,60,62,65,64,63,66,64,65,64,66,69,66,69,68,67,68,70,70,68,68,67,70,70,70,72,71,68,70,73,70,75,73,73,72,72,72,72,70,74,72,71,73,73,71,72,72,69,69,71,71,69,68,67,66,67,68,68,67,65,64,61,63,61,62,63,62,63,59,59,58,59,57,55,56,50,53,53,52,49,51,49,52,51,49,48,46,47,48,44,60,57,59,56,64,62,62,61,60,60,65,63,63,65,63,64,65,62,64,66,68,69,70,63,65,68,70,69,71,68,70,72,72,71,72,69,69,69,72,74,70,70,69,71,70,74,65,71,74,73,72,70,71,71,70,72,71,70,68,66,66,68,67,64,68,65,64,62,62,63,64,62,61,58,60,58,56,58,53,54,56,52,53,53,53,50,52,50,50,49,44,47,47,45,46,45,56,60,59,60,60,60,61,59,62,62,61,62,63,63,62,64,70,64,65,68,69,65,69,67,67,61,68,72,71,73,70,70,70,68,73,72,72,71,69,69,69,72,75,70,70,73,73,70,72,71,70,71,72,68,68,70,67,69,68,68,68,67,66,66,64,66,65,63,60,58,62,60,60,59,61,59,58,55,55,56,56,54,52,51,52,53,48,49,47,48,47,45,45,45,43,43,56,58,57,58,62,57,57,60,60,63,62,63,64,63,66,63,64,66,67,70,67,68,69,69,75,69,69,69,68,67,71,68,69,70,69,72,72,71,70,71,71,70,70,73,71,73,73,72,69,70,69,71,72,71,68,70,66,70,68,67,69,64,63,69,68,64,67,65,63,63,60,62,61,59,61,59,59,54,55,57,56,57,53,50,49,49,50,47,51,48,47,46,45,45,45,46,56,55,57,55,55,61,59,60,60,63,59,62,63,59,63,61,63,64,65,65,66,69,68,66,68,68,65,70,66,69,70,76,70,68,68,69,71,71,71,70,71,69,68,70,70,70,69,68,70,67,68,70,70,69,69,68,66,65,63,66,65,65,67,64,63,65,63,63,63,62,62,60,69,57,59,60,55,56,55,55,56,52,55,52,50,50,48,48,47,45,45,46,44,43,43,44,56,35,58,56,56,57,59,58,60,51,59,63,61,61,68,65,59,64,63,64,65,65,69,65,67,68,67,67,69,68,68,68,66,71,72,71,71,72,67,69,69,69,70,69,69,68,67,69,68,67,69,68,70,67,68,68,67,68,66,67,63,65,66,65,63,62,60,62,62,59,60,59,56,56,57,58,55,54,55,54,54,52,49,48,49,48,47,46,44,46,44,44,43,43,41,44,52,64,61,60,62,56,58,59,54,66,59,61,61,62,62,64,61,66,63,74,68,66,66,68,62,69,69,74,70,61,68,69,71,69,70,65,69,71,67,65,70,72,71,70,68,69,71,69,70,70,68,71,67,67,66,66,69,67,65,64,64,61,66,57,66,64,61,62,62,59,59,57,58,56,58,56,54,55,54,50,54,51,51,51,48,47,49,47,48,47,46,45,42,43,45,45,54,57,57,58,59,59,60,56,59,60,59,60,62,60,62,62,62,62,62,61,63,69,60,61,63,63,67,62,68,70,69,69,66,71,68,69,93,68,68,67,70,68,69,69,69,70,70,68,69,67,69,67,67,68,67,66,67,67,63,65,65,64,64,66,65,63,62,62,61,61,59,60,58,57,56,54,54,51,52,53,50,51,54,49,49,47,46,46,50,45,47,46,42,43,43,44,49,54,53,57,56,57,58,60,60,59,59,60,59,59,61,58,62,56,64,64,62,65,56,62,66,67,66,63,65,62,65,66,69,65,67,69,67,66,68,66,66,70,67,68,68,68,66,66,70,68,65,68,65,66,64,63,64,68,64,63,62,62,64,60,60,59,61,60,58,58,59,59,56,56,55,53,54,54,50,53,49,51,52,49,47,46,49,47,47,46,46,45,42,42,40,43,57,57,59,58,57,57,55,57,57,61,57,57,54,58,65,68,61,64,64,65,65,63,63,64,67,66,66,67,65,65,65,65,66,68,70,68,67,65,66,68,67,68,72,66,65,67,67,66,68,69,68,68,67,68,65,66,66,65,63,64,64,63,63,62,63,58,59,60,59,57,58,57,55,57,56,56,53,54,54,52,52,48,50,46,48,47,45,47,48,47,44,43,42,43,43,42,55,55,59,57,56,58,60,59,59,58,57,58,60,55,58,61,59,63,63,64,64,55,67,63,64,65,66,64,64,63,65,63,65,64,68,68,67,64,68,57,65,68,68,66,65,64,67,66,65,65,65,68,71,68,65,63,63,66,64,59,64,63,65,60,61,60,59,60,58,58,59,59,54,55,56,57,53,55,51,51,49,50,50,47,47,46,45,45,45,44,44,42,41,43,43,43,55,57,56,55,57,59,58,52,58,59,54,56,58,54,59,59,62,60,57,63,62,63,63,64,59,65,65,63,62,64,64,61,65,65,68,64,64,66,66,68,68,64,67,67,65,66,61,57,65,66,67,63,64,65,65,62,61,63,60,62,65,65,61,62,61,59,56,59,58,59,57,56,59,57,57,54,55,53,51,50,47,50,49,49,47,47,47,45,43,42,41,43,43,42,41,42,55,53,53,54,59,58,60,59,55,59,60,59,58,58,60,62,62,59,61,59,58,61,62,64,62,60,64,63,65,65,58,66,69,67,65,65,65,64,66,66,67,69,66,65,64,66,64,64,66,62,64,65,61,62,63,59,58,65,61,59,62,60,60,59,63,59,58,59,59,60,55,55,52,51,51,52,52,52,48,51,48,48,49,45,46,45,48,45,45,42,41,42,42,40,39,42,53,53,53,58,53,58,57,56,60,57,58,58,62,61,61,60,60,57,60,57,56,62,65,57,69,58,65,62,62,62,61,61,57,64,64,69,65,64,63,64,68,66,66,65,66,67,66,65,63,64,64,63,62,62,63,60,61,60,61,59,61,59,60,61,57,55,57,56,59,57,54,56,54,54,54,51,54,50,47,52,47,46,49,42,45,46,46,46,44,42,43,42,40,41,40,42,53,54,52,57,58,56,61,57,62,56,61,57,61,57,58,60,60,60,59,59,59,61,63,65,62,62,59,63,65,64,64,62,63,67,64,64,66,64,65,65,64,62,67,64,62,64,64,60,60,66,65,63,64,60,62,61,62,63,62,58,59,55,58,59,58,58,57,56,57,56,54,54,53,56,51,51,52,52,50,50,46,47,47,45,47,46,44,46,44,45,44,42,39,39,41,40,51,52,54,56,58,55,54,53,51,58,57,57,58,60,60,47,55,65,60,60,59,60,59,56,61,61,61,64,61,60,64,63,63,61,62,64,68,63,63,65,63,61,64,62,63,63,63,63,62,63,61,63,63,60,61,62,58,60,61,57,58,57,58,57,58,57,56,57,58,56,55,55,52,52,50,50,49,49,50,47,45,46,45,45,45,44,43,44,43,42,43,43,41,39,40,40,50,52,53,54,52,52,57,52,57,40,58,59,60,55,57,60,59,57,56,57,57,60,58,62,61,60,59,61,60,59,63,60,63,62,61,63,64,63,64,63,64,63,62,59,58,58,63,63,63,62,63,61,61,58,59,60,58,59,59,55,57,58,58,57,56,53,57,56,56,53,53,53,52,51,52,52,50,49,48,45,45,38,45,45,43,43,43,43,43,46,44,41,40,39,40,39,54,55,54,57,52,55,58,58,53,53,54,57,56,57,58,57,60,56,57,56,60,59,53,56,58,54,60,58,61,62,65,63,63,61,61,61,70,62,61,61,64,63,63,59,60,59,62,60,63,62,61,60,60,60,61,59,58,59,58,56,58,58,60,59,58,57,57,54,55,56,51,53,52,50,51,51,48,49,47,45,46,49,47,44,45,44,42,41,42,42,42,42,43,39,41,24,52,56,50,54,51,53,58,56,58,57,54,53,58,58,58,58,59,57,58,54,57,56,53,58,61,58,59,63,63,59,57,59,61,59,62,60,61,65,59,60,63,60,59,59,59,62,64,62,62,61,60,60,59,62,59,58,59,57,57,54,58,56,58,58,57,51,53,54,54,52,53,53,49,48,49,51,49,46,46,48,45,48,46,46,46,45,42,44,41,43,39,41,40,41,38,41,47,59,53,53,53,53,51,55,53,52,55,49,55,55,54,56,54,52,58,56,58,57,59,58,58,60,60,59,57,60,59,60,59,59,61,62,62,60,60,60,62,60,56,58,61,60,57,61,61,60,59,58,61,58,58,58,57,57,59,57,55,55,51,54,56,53,54,54,52,53,52,52,49,51,49,46,44,45,48,44,44,45,44,43,46,44,44,44,34,41,39,40,40,39,38,39,51,48,53,53,52,54,55,56,58,53,53,56,57,56,53,54,57,58,58,59,57,53,57,57,56,59,58,57,60,60,59,60,60,57,59,61,59,63,59,59,60,58,57,58,60,56,60,59,59,60,61,58,60,58,59,58,55,57,57,54,53,54,56,56,57,55,53,55,56,52,52,50,52,50,49,48,50,47,44,43,44,43,42,44,44,44,40,43,41,43,40,39,39,38,38,38,54,51,52,53,55,49,55,56,54,51,55,55,51,54,52,48,58,53,53,56,56,59,60,57,58,56,58,59,55,60,57,57,55,58,59,61,63,60,61,59,58,57,58,57,61,60,61,59,59,59,60,58,56,56,59,56,54,56,54,56,57,52,54,54,54,48,53,55,53,51,49,45,50,49,43,47,50,48,48,45,47,44,46,43,44,40,41,41,40,41,41,39,42,41,39,35,47,54,50,55,52,52,52,56,58,54,56,56,52,54,55,50,57,54,58,54,56,59,59,59,61,59,58,58,54,61,57,55,57,59,60,61,57,59,56,55,59,58,58,58,59,59,58,58,58,55,57,57,57,58,58,57,56,56,57,57,55,53,54,54,53,53,53,52,53,53,48,48,51,46,48,48,47,46,45,46,46,45,44,42,42,42,43,40,43,41,41,39,40,38,37,37,46,49,49,49,49,52,55,50,50,54,54,54,55,54,54,53,54,53,54,54,55,56,57,58,54,56,57,53,56,57,61,53,58,56,53,53,55,58,58,56,58,57,58,57,54,56,56,56,55,55,55,57,55,55,46,56,54,51,54,54,53,53,52,51,51,51,52,49,50,47,48,45,46,46,50,50,46,48,49,45,44,43,42,43,41,42,42,41,41,39,38,38,40,37,39,37,46,53,48,53,48,49,54,57,51,50,53,53,53,53,52,55,53,54,54,56,57,57,52,55,54,57,57,60,56,57,57,56,56,56,57,55,57,58,56,58,57,53,58,60,57,59,56,55,55,54,57,55,56,52,50,52,57,54,52,51,53,52,52,52,53,53,50,49,49,49,51,49,47,47,47,47,44,46,44,41,43,43,41,42,41,39,41,40,40,40,38,39,37,37,37,36, Length: 9216
there are some difference but the result seem to vary and I expected the result to be only 0 or very close to 0 when I was holding my finger over the lense.
This is the code I am using:
#include "esp_camera.h"
#include <WiFi.h>
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#include "camera_pins.h"
const char *ssid = "********";
const char *password = "********";
void startCameraServer();
void setupLedFlash(int pin);
void getPixels();
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.frame_size = FRAMESIZE_96X96;
  config.pixel_format = PIXFORMAT_GRAYSCALE;
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  if (config.pixel_format == PIXFORMAT_JPEG)
    if (psramFound())
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      // config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
    // Best option for face detection/recognition
    // config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK)
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t *s = esp_camera_sensor_get();
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash(LED_GPIO_NUM);
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  getPixels();
void getPixels()
  // disable white balance and white balance gain
  sensor_t *sensor = esp_camera_sensor_get();
  sensor->set_whitebal(sensor, 0); // 0 = disable , 1 = enable
  sensor->set_awb_gain(sensor, 0); // 0 = disable , 1 = enable
  camera_fb_t *fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  if (!fb)
    Serial.println("Camera capture failed");
    return;
  for (int i = 0; i < fb->len; i++)
    Serial.print(fb->buf[i]);
    Serial.print(",");
  Serial.print(" Length: ");
  Serial.println(fb->len);
  Serial.println(F("\n\n---------------------\nPREPARE TO CAPTURE TO FILE\n"));
  delay(2000);
  esp_camera_fb_return(fb);
pick just one
if you try one example (like this), do you get the picture ?
No, there is always background sensor noise, even in pitch darkness. And a surprising amount of light gets through your finger.
Your camera is working. Try the histogram.
yes this is working. Im now isolating that code to just be able to grab rgb (or grayscale) values. Basically I want to grab the values on every frame. Im not sure however esp32cam is intended for this?
I implemented this histogram function in the loop but I get this error:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Code:
void histogram()
  // for each pixel in image
  long npix = 0;
  unsigned long histogram[256] = {0};
  int WIDTH = 96;
  int x;
  int y;
  for (size_t i = 0; i < fb->len; i++)
    x = i % WIDTH;                   // x position in image
    y = floor(i / WIDTH);            // y position in image
    unsigned int pixel = fb->buf[i]; // pixel value
    histogram[pixel]++;
    // show data
    //  Serial.print((unsigned int)pixel);
    //  Serial.print("\n");
    npix++;
  Serial.print("***** "); // separator
  Serial.print(npix);
  Serial.print(" data lines\n");
  for (int i = 0; i < 256; i++)
    Serial.print(i);
    Serial.print("\t");
    Serial.println(histogram[i]);
The error is in the code that you forgot to post.
You're dereferencing a null pointer, you for got the call to esp_camera_fb_get().
You don't need to do any "grabbing". The esp_camera_fb_get() does it all for you. Assuming it succeeds, the returned value points to the complete frame information structure, as I already explained in Post #5.
Ahh, yes. The OP made up some variable names and added them to the (working) code I posted earlier.
The working code is intended to be in line with the code that reads the image frame.
Here is the complete function:
bool capture_still() {
  Serial.print("***** greyscale image histogram\n");
  camera_fb_t *frame = esp_camera_fb_get();
  if (!frame)
    return false;
  int npix = 0;
  for (size_t i = 0; i < frame->len; i++) {
    unsigned int pixel = frame->buf[i];                     // pixel value
    histogram[pixel]++;
    // show data
    npix++;
  Serial.print("***** ");  //separator
  Serial.print(npix);
  Serial.print(" data\n");
  for (int i = 0; i < 256; i++) {
    Serial.print(i);
    Serial.print("\t");
  esp_camera_fb_return(frame);                      // return storage space
  return true;
