Hello,
I’m facing an high consumption with an esp32s3 board (brand : SIINST) : 2,5 ma in deepsleep where it shouldn’t be more than 10 µa…
In order to identify the issue, I tried to use the simplest code and hardware, and also compared it with some esp32c3:
-I used the Arduino IDE Deepsleep exemple (without wake up pin, no wifi, no ADC).
-I only wired the +3v3, En and GND pin and added a single capacitor (I previously tried with a complete pcb with pullup resistors), using POGO pins.
-I did exactly the same thing with esp32c3 : only 8 µa in deepsleep.
-I tried with 3 esp32s3 and 2 esp32c3
As the same code and wiring are giving the expected consumption with the esp32c3 and not with the esp32s3, I really don’t have any idea of the issue…
On the French forum, someone suggested it could be linked with the flash memory not shutting down in deepsleep.
Could anyone give me any advice/tips ? I don’t find any guidance on the web
The final project (which is working- excepted the high consumption-) is a soil moisture sensor using the capacitive touch pin of the esp32, working on battery in Home assistant/Esphome – esp32C3 isn’t suitable.
I hope my English isn't too bad.
Thanks by advance for any help !
Simple Deep Sleep with Timer Wake Up
ESP32 offers a deep sleep mode for effective power
saving as power is an important factor for IoT
applications. In this mode CPUs, most of the RAM,
and all the digital peripherals which are clocked
from APB_CLK are powered off. The only parts of
the chip which can still be powered on are:
RTC controller, RTC peripherals ,and RTC memories
This code displays the most basic deep sleep with
a timer to wake it up and how to store data in
RTC memory to use it over reboots
This code is under Public Domain License.
Author:
Pranav Cherukupalli <cherukupallip@gmail.com>
#define uS_TO_S_FACTOR 1000000ULL /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 60 /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason() {
esp_sleep_wakeup_cause_t wakeup_reason;
wakeup_reason = esp_sleep_get_wakeup_cause();
switch (wakeup_reason) {
case ESP_SLEEP_WAKEUP_EXT0: Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case ESP_SLEEP_WAKEUP_EXT1: Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case ESP_SLEEP_WAKEUP_TIMER: Serial.println("Wakeup caused by timer"); break;
case ESP_SLEEP_WAKEUP_TOUCHPAD: Serial.println("Wakeup caused by touchpad"); break;
case ESP_SLEEP_WAKEUP_ULP: Serial.println("Wakeup caused by ULP program"); break;
default: Serial.printf("Wakeup was not caused by deep sleep: %d\n", wakeup_reason); break;
delay(1000); //Take some time to open up the Serial Monitor
//Increment boot number and print it every reboot
++bootCount;
Serial.println("Boot number: " + String(bootCount));
//Print the wakeup reason for ESP32
print_wakeup_reason();
First we configure the wake up source
We set our ESP32 to wake up every 5 seconds
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) + " Seconds");
Next we decide what all peripherals to shut down/keep on
By default, ESP32 will automatically power down the peripherals
not needed by the wakeup source, but if you want to be a poweruser
this is for you. Read in detail at the API docs
http://esp-idf.readthedocs.io/en/latest/api-reference/system/deep_sleep.html
Left the line commented as an example of how to configure peripherals.
The line below turns off all RTC peripherals in deep sleep.
//esp_deep_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
//Serial.println("Configured all RTC Peripherals to be powered down in sleep");
Now that we have setup a wake cause and if needed setup the
peripherals state in deep sleep, we can now start going to
deep sleep.
In the case that no wake up sources were provided but deep
sleep was started, it will sleep forever unless hardware
reset occurs.
Serial.println("Going to sleep now");
Serial.flush();
esp_deep_sleep_start();
Serial.println("This will never be printed");
//This is not going to be called
https://fr.aliexpress.com/item/1005006658846474.html?spm=a2g0o.order_list.order_list_main.352.60e95e5bd6vU8B&gatewayAdapt=glo2fra
