Hey!
I'm getting the following error while trying to flash anything on my esp01, even the templates.
Sketch uses 257016 bytes (26%) of program storage space. Maximum is 958448 bytes.
Global variables use 27612 bytes (33%) of dynamic memory, leaving 54308 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.7
Serial port COM4
Connecting........_____....._____....._____....._____....._____....._____....._____
Traceback (most recent call last):
File "C:\Users\Eduardo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0/tools/upload.py", line 25, in <module>
esptool.main(fakeargs)
File "C:/Users/Eduardo/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2841, in main
esp.connect(args.before)
File "C:/Users/Eduardo/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Failed uploading: uploading error: exit status 1
Does anyone know what might be causing? It is a brand new esp01s with a CH340G usb adaptor, and never had anything load into it.
Thank you very much!
