I ordered 2 led strips, 5m+3m ESP8266 (60 LEDs in meter), and set up the regular Arduino, it worked fine with it, but then I moved from regular Arduino to ESP8266, and I got this weird issue, the right side is aqua in tho all the LEDs should be white, (the Arduino is connected from the right side) and it happened with almost every color, you can see the difference between the strips.
That's not voltage drop because It should display the first LEDs white too, but it starts showing the white LEDs where I connected the 2 led strips.
Also its really buggy and flickering, I was trying to load 1 led per second, but it started flickering on the other side of the leds (even tho it shouldn't do it)
