I am getting this error while uploading the code to the 8266 card. What is the solution ?
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
What makes you think that you have an error ?
." Variables and constants in RAM (global, static), used 31384 / 80192 bytes (39%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1616 initialized variables
╠══ RODATA 3200 constants
╚══ BSS 26568 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61287 / 65536 bytes (93%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 28519 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 363440 / 1048576 bytes (34%)
╚══ IROM 363440 code in flash "
That is not an error, rather it is information about how memory is being used by your sketch
I assume that after upload your sketch does not do what you want. What should it do and what does it do ?
